Old 07-14-2009, 07:28 PM   #1
Sti_Boxer
Member#: 213046
1998 Impreza
Default What is the Function of Fender Braces?
I got a newsletter from morejapan and they featured the nagisa fender
braces that caught my interest. I read through it but couldn't quite grasp
the concept of the function of the fender braces. I'm guessing it gives the
car more steering response?
http://www.more-japan.com/product.ph...cat=614&page=2
Sti_Boxer is offline   Reply With Quote
Old 07-14-2009, 07:34 PM   #2
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
If you take off your fender and look at what Subaru did to tie the whole front of the car together it will make perfect sense. Yes, it adds much needed rigidity to a thoroughly weak aspect of our cars. The same with the subframe, just about every single bushing, the mounts, etc., etc. I love my car, but out of the box these cars need so much done to really tighten it up. Until you get into the $68,000 range cars lack quite a bit. It is what it is.
UFOpilot is offline   Reply With Quote
Old 07-14-2009, 07:35 PM   #3
sigurd
Member#: 128721
2002 impreza WRX
psm
Tic explains it well so I will just quote them from their site.
what they do
Tie the lower a-pillar frame member to the upper front frame member for triangulation of the junction between to two to make it stronger. There are braces there in the stock config, but those are stamped steel, and about as strong as a wet noodle. Ours are much stiffer.
why you want them
Stiffer is better!! Seriously, people who have installed them have been amazed at what a drastic change such a small part can make. Instead of making your car's frame act like a spring let your spring act like a spring. Afterall, that's what it's supposed to do.
Oh, and for the guys who still don't believe us. You're selling yourself short, and you'll learn it the hard way at the track when your competition enters and exits corners faster than you. Heck, you know what, don't buy them. Our customers will just enjoy beating you around the track that much more.
I have the Turn in concepts braces and they are a great product.
http://www.turninconcepts.com/produc...products_id=56
sigurd is offline   Reply With Quote
Old 07-15-2009, 03:03 AM   #4
fastwrx25
Member#: 126441
03 bugeye
one of my fav mods, easy to install too.
other fav mods are bushings and mounts but much more pain to install
fastwrx25 is offline   Reply With Quote
Old 07-15-2009, 04:13 AM   #5
KLBO
Member#: 217211
2013 Limited
ISM
I would definitely look into TiC.
I installed mine a couple months back and I must say that the difference a pretty noticeable. Before installed the fender brace the steering wheel often felt sloppy and loose. This was more obvious when driving on the freeways. But since the install, steering has been more alot more precise.
For the money and install time it was definitely worth it. Though if you plan on doing the install your self, be patient the fenders are very thin in our cars and make sure you have the right tools for the job.
KLBO is offline   Reply With Quote
Old 07-15-2009, 12:31 PM   #6
Sti_Boxer
Member#: 213046
1998 Impreza
what tools do i need to install these?
Old 07-15-2009, 01:42 PM   #7
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
screwdriver and 10mm socket for the pop tabs and screw for the fender liner.
14mm wrench for the bolts.
Old 07-15-2009, 02:06 PM   #8
Sti_Boxer
Member#: 213046
1998 Impreza
do i need to drill any holes into the fender itself?
Old 07-15-2009, 02:12 PM   #9
Turn in Concepts
Member#: 93646
Many Track Records
No.
there are some text instructions under the product description on our site, and a ton of people have done some on here as well.
Q: What is the benefit of Fender Braces ? jason2004STI Interior & Exterior Modification 36 08-21-2006 06:19 PM
what is the function of the "scroll lock" key? alacrity024 Off-Topic 12 05-11-2006 11:38 AM
what is the name of the time machine that is on the back of the car crowbar Off-Topic 17 10-24-2004 08:30 PM
what is the name of the dragstrip that is north of Waco? AWDball Texas Impreza Club Forum -- TXIC 9 12-27-2002 07:06 PM
('93-'01) What is the function of a "waist spoiler" fungo phil Impreza Forum 22 08-19-2001 01:11 PM
