Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 07-14-2009, 07:52 PM   #1
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Default whistle sound coming down from boost
I searched and can't find anything quite like I hear.
I just installed a list of parts last night
Grimmspeed phenolic spacers
APS 3" inlet
TGV deletes
I run the stock BPV
Everything went as planned until I took it for a test drive. When I get into boost (anythigng over 5lb) when I let off the throttle there is a whistle noise that kind of sounds like a whining cat. The more boost I push when I let off the throttle louder the sound. I get 19lb of vacuum at idle and can hit full boost of 17lb. The car seems to act fine but that sound is LOUD and does not sound natural.
Kink in the BPV hose that connects to the inlet?
Thanks
medamullet is offline   Reply With Quote
Old 07-14-2009, 10:47 PM   #2
firsttimetunner
Member#: 184964
2003 WRX
well first off are you sure thats not your turbo spoiling down? sorry but thats just a funny question cause thats what turbos do you know, they make whistleing sounds.
firsttimetunner is offline   Reply With Quote
Old 07-15-2009, 12:02 AM   #3
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Ya its really loud. I run a ewg setup and it as loud as that. Besides I have driven/riden in lots of cars with an aps inlet and have never heard this noise.
Old 07-15-2009, 12:08 PM   #4
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
serious, I am the ONLY 1 who has had this problem????
Old 07-15-2009, 01:04 PM   #5
magicstop
Member#: 206853
2004 WRX Wagon
TXS Stage 4
Hard to know w/out hearing the noise... "Whistling" is sort of generic. Could you post a video to YouTube?
magicstop is offline   Reply With Quote
Old 07-15-2009, 01:17 PM   #6
lehaitien
Member#: 217270
2007 STi
...x2
lehaitien is offline   Reply With Quote
Old 07-15-2009, 01:17 PM   #7
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
You don't have 19 psi of vacuum at idle, because it's impossible to have 19 psi of vacuum, unless you believe in anti-matter.
Maybe a bad BPV?
Old 07-15-2009, 01:41 PM   #8
Cards2323
Member#: 142868
2014 BRZ LIMITED
Satin White Pearl
Maybe after installing the inlet you ripped the BPV hose and the whistle is air releasing from a tear???? Pretty hard to figure it out without hearing it..
Cards2323 is offline   Reply With Quote
Old 07-15-2009, 04:46 PM   #9
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I will take the hose off tonight and check it out. Eggroll you are right. I stated it incorrectly. I will try to make a video tonight as well.
Old 07-15-2009, 05:12 PM   #10
blernin41
Member#: 200321
2009 Forester 2.5XP
Armpit Green
I had an airaid TBS on my wrangler and it whistled on part throttle. could be the new airflow and may be perfectly normal. does it sound "cool"
blernin41 is offline   Reply With Quote
Old 07-16-2009, 11:46 AM   #11
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
More like a cat meeeeooooooowwwww! Not so cool I think . I didn't have time to make a video yesterday (date night with the wife. I will take off my tmic and the bpv hose that connects back to the inlet and check it out.
Old 07-16-2009, 12:02 PM   #12
subiedrewbie
Member#: 190168
2015 WRX
i had a whistle once and it ended up being a hose not clamped down hard enough or at a weird angle.. could possibly just need to take apart and put back together
subiedrewbie is online now   Reply With Quote
Old 07-16-2009, 01:43 PM   #13
MyOtherRideIsUrMom
Member#: 159636
2007 WRX WRB-18G EWG
2014 Outback LTD ISM
I have sort of the same thing happening now. I just installed a Perrin silicone inlet and when I let off the gas i get a "wind tunnel howling" noise that increases with speed. Only thing I can think of is I noticed my BPV return hose was semi-squished by the throttle body. I plan on fixing it later but maybe you are having the same thing?
MyOtherRideIsUrMom is offline   Reply With Quote
Old 07-16-2009, 02:00 PM   #14
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Both of those sound about the same as what I am dealing with. I am going to take off my hose and see what's up.... I will check all hoses and see if they are clamped down properly.
Old 07-16-2009, 02:11 PM   #15
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTORŪ
i'm 90% sure its a boost/vac leak somewhere. check everything again.. start with the inlet.
AlxSti is offline   Reply With Quote
Old 07-16-2009, 02:14 PM   #16
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
if so shouldn't I be loosing vac at idle? or have sparatic vac at least? I hit full boost in every gear.
Old 07-16-2009, 02:18 PM   #17
Member#: 51961
2005 STi
2012 WRX
Depends on where the leak is. A leak before the throttle body won't affect your idle vacuum.
Old 07-16-2009, 11:04 PM   #18
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
ya ,fixed it today. I took off my TMIC and I could see the hose that goes from the BPV to the inlet was kinked. I took off my throtle body and took the hose completely off. Lubed it up with a bit of oil and slid it back on (all the way, because that was what was causing the kink) and took it for a spin. No more cat meeeeoooooowwwwwww!
anyone comeing down from prescott to phx? SubeSTIle South West Impreza Club Forum -- SWIC 4 09-03-2009 05:52 PM
Whistle sound coming from behind gauges livin503 Electrical & Lighting 3 08-28-2008 11:15 PM
Short sqeak/whistle when coming down after a throttle blip perret318 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-10-2005 01:01 PM
So there I was, coming down from Brighton.... ibis Rocky Mountains Impreza Club Forum -- RMIC 3 11-24-2001 09:55 PM
Coming down from Vegas for RallyX - time? Toolin South West Impreza Club Forum -- SWIC 8 03-26-2001 09:24 PM
