Old 04-30-2002, 05:57 AM   #1
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
Default How long do you guys let your car warm?
I usually let it warm at least till the needle is at the mottom line on the scale. Normal operating temp is where I like it to get. Its "wicked bad" to just turn it on and drive, but is it just as bad to let it sit and idle? I can only think of a thing or 2, but nothing an Italian tune-up won't fix.
-IggDawg
IggDawg is offline   Reply With Quote
Old 04-30-2002, 06:06 AM   #2
Charge
Member#: 3313
Everything I've heard lately pretty much rebukes this theory on newer cars(at least non-aspirated, let's not bring turbo into this forum).
In theory, newer engines should have the oil flowing freely right after ignition. Most mechanics I've talked to say from the time you turn the ignition, get situated, then are ready to go, is plenty. I'd say it takes me less than a minute to do my stuff(i.e., I put on my seatbelt after I start the car, lock the doors, turn on the radio, etc...).
However, I don't go above about 4500rpm until the temp guage is at least a quarter of the way up. I doubt that's necessary either, but it makes me sleep better at night
Neil
Charge is offline   Reply With Quote
Old 04-30-2002, 07:41 AM   #3
99OBSter
Member#: 14324
1999 OBS 4eat
I've also heard that you only need to warm up the car for about a minute. I usually let the car sit for about 30 seconds and then shift it into D or R (I have a 4eat) and let it sit for a few seconds in gear before moving. I've heard that you should let the transmission get some of it's aft flowing before taking off. I keep the revs below 3.5K until the car has warmed up, though.
99OBSter is offline   Reply With Quote
Old 04-30-2002, 07:57 AM   #4
IggDawg
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
99 - Never heard of that technique. I guess it would do the trick. I just drive 100% granny till I've gone 5 miles or so. By then I'm on the highway, and I still take is easy for a while for good measure. All these little bits of techno-worship probably do more to put us at ease than anything.
-IggDawg
Old 04-30-2002, 09:06 AM   #5
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
C A P S CAPS CAPS CAPS
I get in, pull on my seatbelt, start my TS and drive away. I do keep the shifts under 4000 til it's warm. When it is below 35 deg I try to let it warm up a bit before going. These are fi motors, they really don't need to warm before going. Now a carbureted motor, they need to warm up because the choke flap closes and cuts off the air going into the motor. You push on the gas pedal and flood the oil and motor with gas. Which in turn can damage and clog the catalytic converter. On a fi car, the computer just enriches the idle circuits to compensate for the air. No flooding at all. And with everyone using synthetic oil these days, the oil still flows whether it is 30 or 130 degrees.
Stealthbmbr is offline   Reply With Quote
Old 04-30-2002, 10:13 AM   #6
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
I warm my car between 2 and 5 minutes when it is very cold.
When anything other than that, I let it warm about 30 seconds before driving off first thing in the morning or at the end of the workday. Any other time of the day I hop in and drive right off.
I use Mobil1 10w30.
ColinL is offline   Reply With Quote
Old 04-30-2002, 11:19 AM   #7
LordBass
Member#: 3266
2006 Jetta 2.0T 6MT
2009 Jamis Aurora Elite
I'm with STEALTHBMBR.. I let it run about 10 seconds before driving, then under 3500rpm or so until fully warm.
In the winter, no point in letting it sit to warm up (unless you have to clear the windows), because the car doesn't much warm up until it's driven a few miles.
I think the most important detail is being nice to the car until it's fully warm, no matter what the season.
lb
www.trancelab.com
LordBass is offline   Reply With Quote
Old 04-30-2002, 01:23 PM   #8
PeterJ
Member#: 14727
2002 impreza RS
I think that you guys might be right... I read somewhere that BMW has a car with some sort of tach light that warns you when the car is still warming up. As the engine warms, you can rev higher and higher without the light coming on.
PeterJ is offline   Reply With Quote
Old 04-30-2002, 01:25 PM   #9
C-daleRidr
Member#: 18074
2008 Speed3
I usually let her warm up for about 5 minutes, unless the windows are frozen over, which happened most mornings this winter. By the time they were thawed or scraped, she was fine. I think a lighter weight oil in the winter is a good idea, too. I used Mobil 1 5W30 all winter and just switched to 10W30 a couple of oil changes ago. Keep the revs down until she's idling under 1000 rpm is the advice I've always gotten, but I think I just do it to make my wife think I know cars.
C-daleRidr is offline   Reply With Quote
Old 04-30-2002, 01:34 PM   #10
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
peter,
many very high RPM engines have secondary rev limiters that are activated by coolant temp. all Honda/Acura engines that have VTEC won't engage it below a certain temp, and they also rev lower at the same time. BMW is probably the same way.
as far as WHEN it's safe to flog it-- unless you have an oil temp gauge you have to go by coolant temp. wait at LEAST 5 minutes after the coolant reads normal before getting serious with the engine, this allows the engine itself and the oil to come to full temp.
Old 04-30-2002, 02:01 PM   #11
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
You may be thinking of the Tach on the newer M3's -- they have an 8000 rpm redline. The tach "redline" is really a bunch of green and red LED's. When the car is still "cool" the "redline" starts at 6500/7000k or something like that, then as the engine warms up, the prior red LED's switch to green, and the redline "magically" grows to 8000 RPM.
It's kinda neat looking actually!
CirrusWRX is offline   Reply With Quote
Old 04-30-2002, 03:08 PM   #12
holam
Member#: 8878
98 wagon white
99 2.5RS white
That's one question I've been wondering too. Base on my observation, when I start the engine in the morning or when it's cold, it automatically revs up to 1500rpm, and then it lowers gradually until ~5 mins later (longer in winter) it reaches the normal idling speed of 600rpm, and at that time, the temp needle reaches the bottom of the scale too. If the engine doesn't need to be warmed up, why would the computer do this automatically?
And if the engine is not cooled down, let's say I just turned off the car for less than 2 hours, the computer wouldn't do this trick. So I guess the purpose of this is to help the engine warm up faster. Of course, I don't mean we should rev the engine to 4000rpm to help it warm up faster, that's just stupid But again, that's just my observation, I don't know much about the technical stuffs.
holam is offline   Reply With Quote
Old 04-30-2002, 03:30 PM   #13
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
if it's warm out about a block before i beat on it, if it's cold at least 2-5 minutes
Old 04-30-2002, 04:28 PM   #14
moogooob
Member#: 15764
00RS -Dumb all over
A little ugly on the side
my buddy has a saturn, dealers said it only takes 15 seconds till its ok to drive normally. In my RS, I always let it warm up till at least the bottom of the c line. Usually takes 1 cigarette and i dont smoke in my car so i dont mind the 5-10 minute wait.
moogooob is offline   Reply With Quote
Old 04-30-2002, 07:16 PM   #15
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
moogoob, I use the cig method too. Start the car...let it idle while I smoke...then get in and drive.
I don't push it "hard" until I've seen the temp climb a bit. Then I have fun.
NC
Reciprocity is offline   Reply With Quote
Old 04-30-2002, 07:39 PM   #16
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
I thought you were quitting, on the patch or gum or something Neil?
Old 04-30-2002, 07:47 PM   #17
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Ha! If it was only that simple. :P
Seriously though...the patch KICKED MY ASS! It was soooooo strong. I went out the first night I had it on...and I could barely walk by 10 o'clock...and I wasn't drinking!
I gotta do something...
NC
Old 05-01-2002, 02:27 AM   #18
V6
Member#: 2703
Y2K GC8
Silver forever
usually after I start the car, I will wait for the rpm drop to 1k then I will drive.
Most of my friends and from some magazines recommend that.
V6 is offline   Reply With Quote
Old 05-01-2002, 08:42 AM   #19
99OBSter
Member#: 14324
1999 OBS 4eat
As far as the rev limiter thingy, I do know that 4eats have a COLD ATF shift map that prevents you from shifting into 4th (and overdrive) when your tranny is cold. Even though you may have it in D, it won't shift into 4. So if you want to drive on the highway, I guess you need to let at least your transmission warm up.
Old 05-01-2002, 08:55 AM   #20
jerymon
Member#: 9115
2004 Forester XT
Platinum Silver
I always wait till the needle reaches the white line at the bottom of the gage before taking off and then dont get on it till it's at it's operating temp.
I also do the ciggie method and I'm going to the Dr. this week and getting some ziban or is it zyban? My friends used it to stop smoking and said it was easy. give it a try. I'll let ya know if it works for me.
Jerry
jerymon is offline   Reply With Quote
Old 05-01-2002, 10:20 AM   #21
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
letting the car sit and idle is worse for the engine than driving it.
I personally, will start it, put on my seatbelt, do whatever I need to do with the radio, then go. I keep it below 3,000RPM until a couple minutes after the temp needle has hit it's NOT mark.
JGard is offline   Reply With Quote
Old 05-01-2002, 10:31 AM   #22
IggDawg
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
Why's that ? I know in older cars cold exhaust would poison cat converters. I thought that problem didn't happen much any mroe. still, why is it bad for the engine?
-IggDawg
Old 05-01-2002, 10:39 AM   #23
99OBSter
Member#: 14324
1999 OBS 4eat
Well, I do know that having your car idle for more than a minute is bad for your water pump, but since we have all been in traffic jams, I'm sure, it's no worse than sitting on the highway for an hour.
Old 05-02-2002, 12:01 AM   #24
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
you too, eh?
SoobATV is offline   Reply With Quote
Old 05-30-2002, 03:22 PM   #25
nuj44
Member#: 18893
2002 Impreza RS
Unhappy
Interesting twist on the how long to warm up question. When I get in and go (I am always late for work, so I hurry) if it is cold out (45 and lower) if I don't give the car a lot of gas (more than ~2000-2500 rpms) I get a BIG A$$ shudder. Feels like the back end. it will do it if I shift into second a little early and don't give it enough gas too. Anyone else have this happen (I hope.... please don't tell me I have somehow F#@$ed up my car)
Therefore, I try to let the car warm up for a bit (at least 5 minutes) before driving it.
Let me know if you guys and gals have the same issue.
Muchos Gracias!
NUJ
PS GO CELTICS!!!
nuj44 is offline   Reply With Quote
TRI-STATE! Where do you guys get your cars detailed? (If you don't do it yourself) Gso2k Interior & Exterior Modification 7 11-26-2007 08:45 PM
How long do you sit on your Throne? SPCJJ Off-Topic 21 10-25-2007 12:29 PM
how long before you adjusted to your car under pressure Newbies & FAQs 22 12-16-2005 03:26 AM
how do you guys wash your cars in the winter??? 516_WRX Tri-State Area Forum 35 12-09-2005 11:07 AM
Where do you guys take your cars for work? DeliciouSpeed Bay Area Impreza Club Forum -- BAIC 5 02-16-2001 06:51 PM
