Old 07-15-2009, 11:17 AM   #1
OB2
Member#: 51500
1999 impreza rs-t
sylver
Default Project Mongrel 370WHP
MAHA LSP 3000 4WD DYNO (verry conservative)
[email protected] CR
19PSI of Boost
SOHC Head
TWE Stage 3 turbo Cams(272 HKS)+ spring et Valve
2.5I 2005 Intake Manifold
Block EJ257
Wiseco [email protected] compression Piston
K1 Carrillo Rod
Cosworth bearing
Cometics head gasquet
ARP stud
Lachute Hi-Flow oil pump
Cosworth belt retaner
Gates Racing Belt
Lachute 3" Turbo/Back Exhaust
Zero Sport Radiator Wind Deflector
Halley Fuel Pump (650 hp)
K&N Air Filter and Intake
Turbo XS Blow off Valve
Lachute Up-pipe
Lachute Down-pipe
Lachute Headers
Vibrant Front Mont Intercooler (26*12*3.5)
Garrett GT3076R ar.82 Turbo
Tial 44mm Wastgate
Electronic boost Selenoide (Set at 19 psi)
FAL Engine Cooler
Unorthodox Racing Full Pulley Kit
Power Entreprise 850cc Injectors
SUNO Automobile HYPER GROUND SYSTEM
Lachute CatchCan
Custom IC water foger
V-pec EMS (tuned at Lachute Performance)
Group N motors mont
OB2 is offline   Reply With Quote
Old 07-15-2009, 11:47 AM   #2
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
You couldnt get her to spool any better? That thing should hit 19 psi before 4,000. Maybe that manifold is holding you back?
Wait, exactly what engine is in this car?
godforbid67 is offline   Reply With Quote
Old 07-15-2009, 12:00 PM   #3
OB2
Member#: 51500
1999 impreza rs-t
sylver
It a spagati Type engine
Forged EJ257 [email protected] CR
Impreza 1999RS SOHC head
EL headers
4'' Down-Pipe
3'' Catback
I use it every day!!!
Old 07-15-2009, 01:10 PM   #4
cellgeek101
Member#: 143941
04 STI JBP
07 LIMITED #602/ 06 BUSA
Looks pretty good for not having AVCS and also having a mild cam in there!
cellgeek101 is offline   Reply With Quote
Old 07-15-2009, 05:10 PM   #5
WRXDre
Member#: 195923
2005 WRX "Stage 2"
Rally Blue
Those are awesome numbers for that particular dyno!
A stock 2008 wrx made 160whp, 210chp, 224tq. 2009 265 wrx: 190whp, 255chp, 248tq. 2009 STi: 200whp, 283chp, 275tq.
Those were done in November of 2008, therefor very different temperatures.
Just to give you a general idea of what this dyno reads.
Congrats on the build.
WRXDre is offline   Reply With Quote
Old 07-15-2009, 10:16 PM   #6
CatfaceType-R
Member#: 81102
needs a dohc and =+1000 rpm downlow and hold it another +1000 rpm up top..your spool isn't great, but what would bother me more is that you lose more power at redline than on the stock vf39 STi turbo.
Get dohc and at least a ported wrx mani for cheap!
CatfaceType-R is offline   Reply With Quote
My rs project rs420 Vancouver Impreza Club Forum -- VIC 31 06-07-2010 12:12 AM
370WHP alternative to Dom 3.0XT-R turboICE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 06-07-2010 12:04 AM
project mongrel??? OB2 Built Motor Discussion 1 04-01-2009 04:13 AM
04 wrb STi for SALE 370whp 93 octane Shane25 NWIC Private Classifieds 51 09-28-2006 04:41 PM
FS: 2004 WRB STi 370whp on 93 octane Shane25 Private Vehicle 'For Sale' Classifieds 0 05-08-2006 11:19 PM
