Old 07-15-2009, 06:30 PM   #1
DoinkMobb
Member#: 3787
2008 Gay
Car
Default turned on heat for a sec, now no A/C
Apparently you can't search the forums for "A/C"...
I bought a '96 OBS in May, and when I test drove the car, the A/C was unbelievably cold. I didn't register the car until this week, and I noticed the A/C was only kinda cold.
This afternoon as I left work, I noticed the air wasn't that cold, so I turned it to hot and then immediately back to cold. I didn't actually turn the right hand dial to heat, I turned the middle temp control to hot. And then...no A/C at all. When the dial is set to A/C or vent, it feels like a hairdryer is blowing in my car. It feels abnormally hot.
The compressor spins when set to A/C but it blows out extremely hot air all of the sudden. Is there a mixer door or something that is stuck? Why would the vented air from outside feel so damn hot?
DoinkMobb is offline   Reply With Quote
Old 07-15-2009, 07:34 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
When you turned the temp dial, the cable may have broken or become disconnected. This would cause the air blend door to remain in the "hot" position regardless of where the dial is set.
If that's what happened, the fix may be as simple as reattaching the cable if it just came off. OTOH if it broke you'll need a new one. To find out what really happened you have to take a look in there.
Old 07-15-2009, 11:12 PM   #3
DoinkMobb
Member#: 3787
2008 Gay
Car
OK I'll have to check that out tomorrow. Where is this cable I'm looking for?
Old 07-16-2009, 06:25 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It goes from the temp dial to the HVAC box. It may be accessible/visible if you look under/behind the dash, or you may have to partially disassemble the center console.
Old 07-16-2009, 10:58 PM   #5
DoinkMobb
Member#: 3787
2008 Gay
Car
Well I need to install a CD player this weekend, so I guess I'll look around and see what I can find in that area.
Old 07-19-2009, 02:55 PM   #6
DoinkMobb
Member#: 3787
2008 Gay
Car
The little plastic tab that holds the end of the cable snapped off. As a temporary fix, I got a pair of needle nose pliers and pulled the cable to switch it to the cold side. It's working now at least.
turn on the food network right now (833 EST) Johnny Knoxville Off-Topic 8 03-25-2005 08:40 PM
turn on gauge for two amps Will98RS Car Audio, Video & Security 9 09-27-2004 06:32 PM
Remote turn on wire for Basslink, where to tap it? 03WRXMA Car Audio, Video & Security 14 10-29-2003 08:07 PM
CEL for a month....now no more CEL ants wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-03-2003 09:27 PM
Turn on your tv to speed now! WRXMaster Motorsports 5 11-08-2002 08:55 AM
