Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 07-15-2009, 08:41 PM   #1
Member#: 127948
1995 impreza
Default Need Advice !!!
My 1999 Subaru legacy outback is overheating. i just changed the thermostat, and i thought i cured the problem but when i drove it(for about 20-30 min) it started overheating again. The coolant overflows through the reservoir and the top hose is hot and the bottom is cold. the fans turn ono. there is no smoke coming out of the talepipe, so i dont think its a blow headgasket.BUT im not really mecanically incline so i dont really know. could it be the water pump? ANY ADVICE, HELP, SUGGESTIONS PLEASE any help is positive help for me im stuck in limbo land!! THANK YOU MY SUBY COMRADEDS
felix0831 is offline   Reply With Quote
Old 07-16-2009, 02:33 AM   #2
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Have you burped the cooling system? Do a search for the burping procedure and burp the system. If after it is burped correctly it still heats up, then check for leaks and do a combustion leak test to see if it is a damaged headgasket. Also if you can, do a collant system pressure test to test the cap is working correctly.
wrxsti.l is offline   Reply With Quote
I need advice. N00bie relationship advice. Pretty Waste Off-Topic 52 07-28-2006 01:13 PM
Need OTter help...new puppy coming and I cant stop it. Need advice... kaisersouse Off-Topic 83 04-25-2006 04:41 PM
Need to replace front rotors/pads on 2002 OBS - Need Advice! mekkon Brakes, Steering & Suspension 6 04-24-2006 06:16 PM
Need advice ! new home need cheaper car but my wagon is leased Karlos Off-Topic 2 03-05-2004 10:29 PM
i need a rear lip, need advice and opinions Tobey Interior & Exterior Modification 2 08-01-2003 06:35 PM
