Alaskan Impreza Club
Old 07-15-2009, 11:35 PM   #1
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
Default Defi EGT Sensor: Thread Tap size??
what size do i tap my headers for this sensor. any one know??
also what port is under cylinder 3? thanks
Alaskan EJ20 is offline   Reply With Quote
Old 07-16-2009, 01:11 AM   #2
MrRicH
Member#: 150452
2016 Subaru WRX STi
Ice Silver Metallic
I've heard best results come from C4. I asked the same question and I've just had a huge group of specialists say tap c4 to get the most accurate reading. Let me know when you decide to drill for your because I need to do the hole for my STRI gauge and I'd love to either tag along or do mine as well. 1/8PT should be the size for your hole. I'm 99% sure, but I could be wrong.
MrRicH is offline   Reply With Quote
Old 07-16-2009, 02:30 AM   #3
ScoobyTec
Member#: 138546
04 HD2500
Green....Loud
use cyl 3 and the thread is 1/8"npt
ScoobyTec is offline   Reply With Quote
Old 07-16-2009, 05:45 AM   #4
MrRicH
Member#: 150452
2016 Subaru WRX STi
Ice Silver Metallic
Only reason I mention 4:
http://forums.nasioc.com/forums/showthread.php?t=529496
Seems from experience cyl4 runs a few degrees hotter as long as you're using stock head and uppipe. Not fighting it, but from what other's have tested results showed that's where the heats at.
Old 07-16-2009, 05:54 AM   #5
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
3 is last in line to get fuel...cyclinder 3
greenspeed is offline   Reply With Quote
Old 07-16-2009, 04:09 PM   #6
MrRicH
Member#: 150452
2016 Subaru WRX STi
Ice Silver Metallic
True.
Old 07-16-2009, 04:18 PM   #7
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
yeah 3 is the last to get fuel, i still dont remember if its passenger side front or rear?
Old 07-16-2009, 06:39 PM   #8
MrRicH
Member#: 150452
2016 Subaru WRX STi
Ice Silver Metallic
Front Pass 1
Front Driv 2
Rear Pass 3
Rear Driv 4
Old 07-16-2009, 07:06 PM   #9
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
word, thanks, Rich- is yours going in the stock mani?? i might have one that you can drill and tap then you can just give me yours when you swap em'. Ill check when i get home for you.
Old 07-16-2009, 09:05 PM   #10
MrRicH
Member#: 150452
2016 Subaru WRX STi
Ice Silver Metallic
I'm already running a stock header on mine. I used to run the Borla set-up when I bought the car but I preferred the stock header and STi uppipe.
Old 07-16-2009, 11:21 PM   #11
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
thats what i mean, if you want i can find my stock mani and you can get all ready to install, that way you dont have to take yours off, prep it, and put it back on. lmk ill help you out.
Defi EGT Sensor: Thread Tap size?? Alaskan EJ20 Electrical & Lighting 3 07-16-2009 12:02 AM
Defi EGT where to tap NaVaWRX Electrical & Lighting 5 11-21-2005 01:07 AM
Is 1/8NPT the right tap size for Defi EGT probe? ssitu Electrical & Lighting 5 07-10-2004 03:20 PM
APS SR-50, TXS downpipe tapped for Defi EGT gauge, TXS intake, Samco MAF ARM, uppipe BLUETURBOWRX Private 'For Sale' Classifieds 18 02-17-2004 12:02 PM
what tap size do i need for a defi egt sensor mount? Otaku64 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-18-2003 02:10 AM
