Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 07-16-2009, 01:31 AM   #1
tabrad
Member#: 157229
02 WRX
Default How hard is it really to do a clutch?
I have done quite a few projects on my car... rear diff, tbe, turbo, etc. But am trying to gauge if I really want to replace the clutch myself.
For those of you that have done it, how hard is it really?
tabrad is offline   Reply With Quote
Old 07-16-2009, 01:53 AM   #2
steve3
Member#: 174055
2015 Impreza Sport
Kent will help
steve3 is offline   Reply With Quote
Old 07-16-2009, 01:57 AM   #3
EsubaruJ
Member#: 200008
03 wrx
TE72 wagon, Legacy wagon
Its easy with the right tools.
EsubaruJ is offline   Reply With Quote
Old 07-16-2009, 02:08 AM   #4
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
if you know what you are doing and have the correct tools its a straight forward job.
pumpkyn is offline   Reply With Quote
Old 07-16-2009, 02:18 AM   #5
tabrad
Member#: 157229
02 WRX
Ok, I believe I have all of the "right" tools, besides the tranny jack. I only have a normal jack.
I have airtools, and also all of the other standard tools that have needed to be used to work on my car
Old 07-16-2009, 11:43 AM   #6
Not-EWRX
Member#: 158043
2013 Wrx Hatch
If you don't have a lift I would suggest just moving the engine forward.
You will need either a cherry picker type thing or two comalongs and a garage. Someone told me you could do it by just jacking the engine up from underneath but that was a god damn lie.
Took me 9 hours, alone. You'll prob need a back up vehicle. Oh and resurface the flywheel for 30$ at transmission exchange.
Not-EWRX is offline   Reply With Quote
Old 07-16-2009, 08:53 PM   #7
Timon_479
Member#: 212007
MBP
Pizza + Drinks and you might be able to lure a few subaphiles into helping you . This is my plan when my clutch starts slipping (80k and still going strong).
Timon_479 is offline   Reply With Quote
Old 07-16-2009, 08:58 PM   #8
Kentrik
Member#: 125937
03 WRX I do not
like your tweed, chap.
Very funny, Steve.
It depends on if you employ the assistance of people who know what they're doing or not. There is a DIY on here that had some helpful pictures, but the word-for-word is full of crap. You will definitely need the air tools, and plenty of time (min 8 hours). Also, you will want PB Blaster/liquid wrench, and will need some more tranny fluid. It's also a good time to replace crossmember bushings, DP gaskets, tranny mounts, pitch stopper, braided brake line, and anything like that.
And you WILL need a transmission jack. You can borrow/rent one from most auto product shops (Vato Zone, Chucker, etc.) for fairly cheap. If there is ANY POSSIBLE way to get access to a lift, it makes worlds of difference, and I would recommend it +123ventybillion times over again.
With the right tools, some dedication, and a bit of mechanical aptitude, you can save yourself $500. The labor isn't overly HARD, just takes time to do it right.
Kentrik is offline   Reply With Quote
Old 07-16-2009, 09:20 PM   #9
stoner
Member#: 52863
2007 B7 A4
Ill come do it in a week in a half for 200. Its fairly easy to do and straight forward. A little more challengine to do on the floor but still simple enough.
stoner is offline   Reply With Quote
Old 07-17-2009, 12:11 AM   #10
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Noah says that, with a lift, proper air tools, and plenty of experience, he can do one in four hours. That's how easy it is.
DLC is offline   Reply With Quote
Old 07-17-2009, 01:53 AM   #11
MXJS
Member#: 129793
2004 STI
LSX RX-7
I agree with this guy. I pull the engine out to change mine because i don't have a lift.
MXJS is offline   Reply With Quote
Old 07-17-2009, 02:21 AM   #12
suberboy
Member#: 1531
2008 GRB
Red
deleted
suberboy is offline   Reply With Quote
Old 07-17-2009, 07:31 AM   #13
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I choose stoner for 200 please. . Or just take it to solid. I do all the work on my car and clutches are 1 I think is worth the 60 an hour. . I paid the guy 40 an hour 4 years ago after doing a few of my own (in a shop with every tool known to man, it took me 5 hours) well worth the money to pay someone.
medamullet is offline   Reply With Quote
Old 07-17-2009, 11:44 AM   #14
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
I just put the car on jackstands and take the transmission out from the bottom. I may have had to move the engine up/down, but there was no need to remove the engine.
yamahaSHO is offline   Reply With Quote
Old 07-17-2009, 03:20 PM   #15
tehhali
Member#: 155142
1996 Legacy
Granola Edition
I've been in the process of swapping my transmission and clutch/flywheel, and with no prior experience at all, if I had proper tools I probably would have had it done in one or two days. It's literally ALL about having the right tools, the rest of it is just unbolting and removing things.
tehhali is offline   Reply With Quote
Old 07-17-2009, 05:08 PM   #16
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
I didn't mean to quote everybody, but my finger slipped.
Anyway I've done the clutch a bunch of times on multiple cars.
1) My first time doing it was by dropping the tranny - NEVER AGAIN. It's easier to lower an engine onto a tranny than it is to raise a tranny into a motor. PERIOD! It took me 9 hours to do it the first time. 5 hours the next and I've pretty consistent at 4 hours now.
2) I have never touched an air tool.
3) Dropping the tranny requires a little more precision when you remove the axles from the tranny - cause you have remove your allignment bolt and you could end up screwing up your allignment if you're not paying attention.
4) Other reasons below
Well duh! Your advice applies to everything... Example - If you know how to bake a cake and have all the ingredients, it should be straight forward........ Unless you're like me and eat the batter prior to baking it. That's besides the point though.
Originally Posted by Kentrik View Post
It depends on if you employ the assistance of people who know what they're doing or not. There is a DIY on here that had some helpful pictures, but the word-for-word is full of crap. You will definitely need the air tools, and plenty of time (min 8 hours). Also, you will want PB Blaster/liquid wrench, and will need some more tranny fluid. It's also a good time toupgrade (I had to fix this from "replace") crossmember bushings, DP gaskets, tranny mounts, pitch stopper, braided brake line, and anything like that.
I AGREE
I DISAGREE
So can I - And thats with a cheapo Cresent combo set of tools and an occasional mallet or something. (and 10mm hex for shifter fork plug) and an engine hoist - However you will either need an engine hoist or a tranny jack... take your pick.
I see your opportunity cost, but that only works if the time where you would be spending doing your clutch is in place of time where you WOULD be making money otherwise. (ie, taking unpaid time off from work to replace it yourself).
paintbing is offline   Reply With Quote
Old 07-17-2009, 06:11 PM   #17
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
oh the cost of not spending time with your wife.... That right there is worth the $200.00 to have someone else do it for you
Old 07-17-2009, 07:34 PM   #18
stoner
Member#: 52863
2007 B7 A4
Dont need to remove the axles. Take out the pins, push the tranny slip out one axle, push the tranny the other way and slip out the other axle.
The easiest way is the way you are comfortable with and know.
I have done this job on an sti without airtools and on the ground. Lol soo much fun.
I have done numerous wrx's on a lift with airtools. Lol soo much fun.
At the end of the day it all depends on your attitude and your motivation.
Old 07-18-2009, 04:12 AM   #19
tabrad
Member#: 157229
02 WRX
I had solid do it about 1 year and a half ago, they were very reasonably priced, and did a great job. Thats what I get for using a gripforce clutch....
I just am very tight on cash right now, so am looking to do it myself to save some money.
Old 07-18-2009, 06:26 AM   #20
TurboJunkie85
Member#: 193412
1985 pumas.
white
Correction you do not have to remove your camber bolts you just have to un-bolt your lower control arms then take a pickle fork then pull it apart then using one of your legs you should be able to push the wheel out far enough to where it will clear. Enjoy =)
TurboJunkie85 is offline   Reply With Quote
Old 07-18-2009, 08:46 AM   #21
stoner
Member#: 52863
2007 B7 A4
Tight on cash you say. Well I will make you a deal 100 but your helpin.
full vinyl car wrapping - who has done it? how hard is it to do? any issues removing? mattesonb Interior & Exterior Modification 121 08-07-2013 01:57 AM
So how bad is it really to have 2 different types of tires on the front and rear? 0260B4U Tire & Wheel 4 10-01-2008 01:09 AM
How bad is it really, to have 2 different sets of tires on an AWD car? WhiteFox Tire & Wheel 12 03-19-2008 04:22 PM
I mean, really, how hard is it to write in complete sentences? DrDRum Off-Topic 13 11-11-2004 01:00 PM
How hard is it to install a clutch on a WRX? stephan Transmission (AT/MT) & Driveline 15 09-03-2004 06:44 AM
