Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 05-04-2002, 10:48 AM   #26
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
C A P S CAPS CAPS CAPS
Looks like you're trying to re-fuel without landing.
Stealthbmbr is offline   Reply With Quote
Old 05-04-2002, 07:00 PM   #27
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
That's just not the same as a blower through the hood .
HamFist is offline   Reply With Quote
Old 05-04-2002, 09:15 PM   #28
STiTuner
Member#: 5778
09 135i
Jet Black
Originally posted by mrbillydee
top dog,
Do you have a setup that keeps water out or do you just put the cover back under the scoop when it rains?
neither
he just tells people its water injected
Brad
STiTuner is offline   Reply With Quote
Old 05-05-2002, 02:39 PM   #29
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
HA HA HA, I have 2 intakes. That one is for the fair weather days.
This is the intake that I normally use and use in SoloII. I can't run the hook scoop intake cause it would put me out of STS.
The hood scoop intake does great for mileage on the highway. I have been wanting to get a manifold pressure gauge and see of much pressure difference it is on the top of 3rd and 4th gear at WOT.
As for water in little rain. There is not problem, because of the big cavity before the filter and there is not alot of wind speed in the box before the filter to blow in the water. It's more air pressure than anything. It tends to most of the water out and if a little gets in. It's not going to hurt it.
Pat
Kartboy Kustoms/ Falken tires
Patrick L is offline   Reply With Quote
Old 05-05-2002, 03:30 PM   #30
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
where did you get the heat wrap, and how much was it? Did you wrap your headers also?
Another question, what's that thing near your intake?
scotty305 is offline   Reply With Quote
Old 05-05-2002, 04:37 PM   #31
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Q#1: Where did you get the heat wrap? If your talking about the header wrap. You can get it at any performance shop. Mostly a domestic tuner shop.
Q#2: How much was it? It was about $45 for about 50' if I remember right. I bought it earily last year.
Q#3: Did you wrap your headers also? No
Q#4: What's that thing near your intake? That is a oil catch can. The crankcase and valve cover vents are connected to it on the bottom side and the hose that comes off the top goes to the intake. It captures any oil that might migrated up the lines and prevents it from getting in the intake.
Ram air Turbo intake saintluciascooby Built Motor Discussion 10 08-06-2007 10:24 PM
hack CAI to make ram air style intake? SLowery Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-13-2003 09:28 AM
ram air intake vs cold air intake Shaji Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 62 07-21-2002 09:05 PM
Anybody Have True Ram Air Intakes Available Yet? MY99 2.5GT Normally Aspirated Powertrain 12 08-23-2001 11:54 AM
new TRUE ram air for 25 dollars HamFist Technical Forum Archive 2 08-20-2000 01:53 PM
