Old 07-16-2009, 02:24 PM   #1
leeswrx
Member#: 118295
05 STI
Default A/C compressor scuffing sound
I reciently noticed this after bringing my car down from alaska. When you turn on the a/c, it makes a scuffing/rubbing sound for about a second. Once in a while it might last for two. When im driving with the ac on, the sound will come and go. Also the temp of the air will be cool, then get warm for a couple seconds then go back to cold every so often. If any one help me out with this I would be really appreciate it. Its an 05 STI with about 20,000 miles on the new motor.I almost for got, When I brought it down here it was on an autotransport. It was VERY dirty. Dont know if dirt could get in there and cause some damage. Thanks.
leeswrx is offline   Reply With Quote
Old 07-21-2009, 01:05 PM   #2
leeswrx
Member#: 118295
05 STI
Any ideas anyone?
Old 07-21-2009, 01:46 PM   #3
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
sounds like the compressor clutch is giving up
crampfan is offline   Reply With Quote
Old 07-21-2009, 01:53 PM   #4
only1agam
Member#: 56183
mines been doing this for a while +1 good question
only1agam is offline   Reply With Quote
Old 07-21-2009, 03:25 PM   #5
leeswrx
Member#: 118295
05 STI
should I go ahead and replace the clutch or the whole assembly? Thanks.
Old 07-21-2009, 03:37 PM   #6
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
you might have someone look at it first. you should only need to replace the clutch, but I'm thinking that they only come with the compressor.
Old 07-21-2009, 05:40 PM   #7
rick-l
Member#: 33868
2003 wrx
srp
You might want to tighten the belt first
rick-l is offline   Reply With Quote
Old 07-22-2009, 08:24 PM   #8
vince72
Member#: 89636
04 wrx
java black
I have the same problem, when i called the dealer they only sell it as a complete unit. for about $500..convenient for them isnt it
vince72 is offline   Reply With Quote
Old 07-24-2009, 11:07 AM   #9
leeswrx
Member#: 118295
05 STI
I changed the belts not to log ago( 8 months.) I will try and tighten the belts up. Thanks for everyones input.
Old 08-03-2009, 04:59 PM   #10
desiwrxpwr
Member#: 33284
try to spray some wd-40 on the compressor wheel, I had the same problem, and I just did that and it worked, no more screaming horror from my car when the a/c is turned on.
desiwrxpwr is offline   Reply With Quote
Old 08-07-2009, 11:06 AM   #11
TixArmy
Member#: 134248
2007 STi-Stage2 -RIP
"Desert Sand on White"
I am dealing with this issue too. However, I am in the middle of the 120 AZ Sun....
Check for leaks first and foremost. Mine had a small leak on the low side of the compressor. Low charge will cause both the squeak and the air to warm up fast.
How often does your compressor cycle? If it is often, then it has to re-charge the coolant. Again, check the levels.
For roughly $55 here I can get the system vacuumed out and topped off. I would highly recommend doing that.
You can replace the clutch by itself, though I am told it will void the rest of the compressor. General thinking is that if the clutch is going, the rest of the compressor is going too.
GL
TixArmy is offline   Reply With Quote
Exhaust drone, vent holes in the trunk, and sound absorption ... need input Hokie-wrx wagon Interior & Exterior Modification 15 07-11-2013 07:36 PM
AC Compressor Scratchy Sound djoye Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-10-2007 09:59 AM
A/C compressor startup sound IntraWRX Service & Maintenance 0 03-06-2007 05:56 PM
Compressor Surge sound and FMICs wgknestrick Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 05-25-2004 12:05 AM
New FMIC and compressor surge sound? big_adventure Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 76 03-30-2004 10:10 PM
