#1 | |
NASIOC Storefront Vendor
Vendor Sales Rating: (88)
Member#: 26854
Vehicle:2002 Impreza WRX |
COSWORTHUSA.COM WEBSITE FOR MORE DETAILS
![]() Cosworth Subaru EJ25 High Performance Short Block - $5284 shipped Cosworth Subaru EJ25 High Performance Short Block w/ Billet Crankshaft- $8806 shipped ![]() Cosworth Subaru EJ25 (STI) CNC Ported Big Valve Cylinder heads Only - $4011 shipped Cosworth Subaru EJ25 (STI) CNC Ported Big Valve Cylinder heads with Camshaft - $5578 shipped Please stated which version (USA Spec / Japan Euro Spec) ![]() Cosworth Subaru EJ25 (STI) Long Block Assemblies with Billet Crankshaft - $15557 shipped Cosworth Subaru EJ25 (STI) Long Block Assemblies with STI Forged Crankshaft - $11742 shipped Various version available, please call us for more details ! COSWORTH CAMSHAFT / CRANKSHAFT / STROKER KIT ![]() Cosworth Crankshaft (Billet / Lightweight) - $3800 Shipped Cosworth Stroker Kit (2.2L / 2.6L) - $6066 Shipped Cosworth EJ20 US Spec CamShaft Set (KK3765) - $993 Shipped Cosworth EJ20/EJ25 Jap/Euro Spec CamShaft Set S2 Grind / Cable Throttle (KK3920) - $1098 Shipped Cosworth EJ20 GC8 CamShaft Set (20005187) - $993 Shipped Cosworth EJ257 US Spec CamShaft Set S2 Grind (KK3766) - $1098 Shipped Cosworth EJ257B (Dual AVCS) CamShaft Set S2 Grind (20007395) - $1098 Shipped OIL CONTROL / ACCESSORIES Cosworth Subaru EJ20/25 Oil Pump - $313.00 shipped Cosworth Subaru 2008 STI Specific Oil Pump - $323.00 shipped Cosworth Subaru Oil Control Baffle - $293.00 shipped Cosworth Subaru EJ20/25 High Pressure / High Volume Oil Pump - $484.00 shipped Cosworth Subaru High Volume Oil Pan - $570.00 shipped Cosworth Subaru EJ20/EJ25 Billet Timing Belt guide - $63 shipped Cosworth Subaru EJ20/EJ25 Cam Angle Sensor - $63 shipped Cosworth Subaru EJ20/25 Kevlar Heavy Duty Timing Belt - $237 shipped Cosworth Subaru Air Pump Delete Plate Set - $63 shipped PISTONS / RODS / SPRINGS / BEARINGS / HEAD GASKET / HEAD STUDS Cosworth EJ25 99.5mm / 99.75mm Piston and RING SET - $1065 shipped Cosworth EJ20 92.0 mm / 92.50mm Piston and RING SET - $1065 shipped Cosworth Connecting Rods Set - $929 shipped Cosworth Ultra High RPM Dual Valve Springs + Titanium Retainer Set - $756 shipped Cosworth Valve Set (Intake + Exhaust) / (+1.0mm) - $476 shipped Cosworth Head Gasket Set (per pair) - $180 shipped Bore Size 101mm (2.5L) or 93mm (2.0 L) with .78mm / 1.1mm / 1.5mm Thickness Cosworth Subaru EJ20/25 Main and Rod Bearing Sets - $168 shipped Choose between Size 0,1,2 INDUCTION / FUEL Cosworth Subaru High Volume Intake Manifold - $1016 shipped Cosworth 2008 STI Front Mount Intercooler Kit - $2185 shipped
__________________
[ WORK WHEELS ] [ RAYS WHEELS ] [ YOKOHAMA WHEELS ] [ WEDSSPORT WHEELS] [ FERODO ] [ BC RACING ] [ COSWORTH ] [ DBA ROTORS ] and many more! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. TEL: 631-586-3520 EMAIL: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by RavSpec; 01-19-2010 at 09:57 PM. |
#2 |
Member#: 26854
PISTON / ROD / STI Short Block
MAHLE Forged Piston + Ring Set EJ20 or EJ257 - $475 Shipped WISECO Forged Piston + Ring Set EJ20 or EJ257 - $475 Shipped WISECO Forged Special Size Piston + Ring Set - $595 Shipped 0.040 over (100.5mm), Side Coating Add $50 STI OEM Short Block Assemblies EJ257 - $1900 + Shipping STI OEM Short Block with Aftermarket Performance Parts Assembled - $3200 + Shipping Wiseco Or Mahle Pistons, Eagle Rods, STI Forged Crankshaft, Cosworth Bearings Set, Cometic Head Gasket (up to 1.5mm thickness), ARP Head Studs, All Assembled ! TOMEIUSA.com WEBSITE FOR DETAIL Tomei ARMS 7760 Bolt On Turbo 400 WHP (WRX/STI)- $1659.00 Shipped ![]() TOMEI Pon Camshaft For EJ20 - $1099 Shipped TOMEI Pon Camshaft For EJ25 (AVCS) - $975 Shipped ** On Clearance ** ![]() TOMEI EJ20 / EJ25 Valve Spring - $299.00 Shipped ![]() TOMEI Forged H Beam Connecting Rods EJ20/EJ25 - $680 Shipped TOMEI Oil Pan Baffle Stiffner - $399.00 Shipped TOMEI Timing Belt Guide - $50 Shipped TOMEI Timing Belt High Performance - $215 Shipped TOMEI Fuel Pressure Regulator (Type S) + Adaptor - $115 Shipped TOMEI Fuel Pressure Regulator (Type L) + Adaptor - $175 Shipped
__________________
[ WORK WHEELS ] [ RAYS WHEELS ] [ YOKOHAMA WHEELS ] [ WEDSSPORT WHEELS] [ FERODO ] [ BC RACING ] [ COSWORTH ] [ DBA ROTORS ] and many more! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. TEL: 631-586-3520 EMAIL: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by RavSpec; 12-17-2009 at 12:12 PM. |
#3 |
Member#: 26854
TD05H-16G Stock Bolt On Turbo (350 HP)- $759.99 Shipped
The TD05H-16G is a bolt-on upgrade for the WRX/STI utilizing a Mitsubishi TD05 16G compressor wheel in a TD05 compressor housing capable of supporting 350 HP maximum. The turbine section consists of a Mitsubishi TD05H high flow turbine wheel and shaft assembly and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG we will also included the uppipe to turbo and downpipe to turbo gasket TD05H-18 G Stock Bolt On Turbo * 7CM (395 HP)- $850 Shipped The TD05H-18G is a bolt-on upgrade for the WRX/STI utilizing a Mitsubishi TD05H compressor housing and 18G exhaust housing with the capability of supporting 395 HP maximum. The turbine section consists of a Mitsubishi TD05H high flow turbine wheel and shaft assembly and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG. we will also included the uppipe to turbo and downpipe to turbo gasket TD06H-20G - Bolt On WRX/STi (440 HP)- $1259.99 Shipped The TD06H-20G is a bolt-on upgrade for the WRX/STI utilizing a Mitsubishi TD06 20G compressor wheel in a TD06 compressor housing capable of supporting 440 HP maximum. The turbine section consists of a Mitsubishi TD06H high flow turbine wheel and shaft assembly for maximum HP potential at high RPM on the 2.5L and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The turbine housing is ported and polished in the turbine inlet throat and wastegate port areas to improve exhaust gas flow and boost control via the internal gate. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG. we will also included the uppipe to turbo and downpipe to turbo gasket BLOUCH TURBO Dominator 3.0R Full Ball Bearing Turbocharger (520HP) - $1650.00 Shipped BLOUCH TURBO Dominator 2.0 Turbocharger Turbocharger (520HP) - $1450.00 Shipped BLOUCH TURBO Dominator 2.5R "Polka Pickle"Full Ball Bearing Turbocharger (475 HP) - $1550.00 Shipped PACKAGE PRICING WITH TURBO / FUEL UPGRADE TD05H-18G With Fuel Upgrade Package (Good For WRX Upgrade) - $1399 shipped - TD05H-18G 7cm Turbo - All gaskets (included) - STI Pink Injectors - Walbro 255 L/H Fuel Pump ** Optional ** 52mm or 60mm Electronic Boost Gauge ** $139 With Purchase Of Turbo Package ** Max Boost Turbo Upgrade (Good For STI ** 2.5 Liter Engine) - $2259 shipped - Blouch Turbo Dominator 2 - All gaskets (included) - PE or SARD 800 cc (Top Feed) or 850 cc (Side Feed) Injectors - Walbro 255 L/H Fuel Pump ** Optional ** 52mm or 60mm Electronic Boost Gauge ** $139 With Purchase Of Turbo Package ** Max Boost II Turbo Upgrade (Good For STI ** 2.5 Liter Engine) - $2199 shipped - TOMEI ARMS M7760 Turbo (bolt on, including lines) - All gaskets (included) - PE or SARD 800 cc (Top Feed) or 850 cc (Side Feed) Injectors - Walbro 255 L/H Fuel Pump ** Optional ** 52mm or 60mm Electronic Boost Gauge ** $139 With Purchase Of Turbo Package ** ![]() Tomei ARMS 7760 Bolt On Turbo 400 WHP (WRX/STI)- $1659.00 Shipped The ARMS M7760 is the largest bolt-on turbo possible that TOMEI engineers can fit into the limited space of the EJ engine. Despite the size, the internals of the turbocharger speaks otherwise; extracting the most and finest efficiency from its design. With bolt on exhaust system, we have seen the dyno horsepower up to 390 to the wheels. This is a 100% bolt on kit for USDM Spec EJ20 or EJ25 engine, including gasket and coolant lines.
__________________
[ WORK WHEELS ] [ RAYS WHEELS ] [ YOKOHAMA WHEELS ] [ WEDSSPORT WHEELS] [ FERODO ] [ BC RACING ] [ COSWORTH ] [ DBA ROTORS ] and many more! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. TEL: 631-586-3520 EMAIL: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by RavSpec; 07-16-2009 at 03:01 PM. |
#4 |
Member#: 26854
Subaru OEM Component
Subaru OEM EJ257 Short Block - $1799 Shipped Subaru OEM EJ257 Bare Block - $999 Shipped Subaru OEM EJ257 Coated Crankshaft - $355 Shipped Subaru OEM Engine and Rebuild Gasket + Seals Kit - $320 Shipped Subaru OEM EJ257 Oil Pump - $120 Shipped *** 08 STI version, Larger COSWORTH S2 Spec Camshaft USDM EJ257 - PM for Clearance Price Int."278" deg. 10.7mm lift / Exh. "274" deg. 10.mm lift. ![]() ![]()
__________________
[ WORK WHEELS ] [ RAYS WHEELS ] [ YOKOHAMA WHEELS ] [ WEDSSPORT WHEELS] [ FERODO ] [ BC RACING ] [ COSWORTH ] [ DBA ROTORS ] and many more! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. TEL: 631-586-3520 EMAIL: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by RavSpec; 04-13-2010 at 12:08 AM. |
#5 | |
Member#: 26854
hi guys:
We have put on order a tons of Fujitsubo exhaust system on clearance now. Please call us to pre order !!! ![]() ![]() Quote:
Fujitsubo Power Getter Cat Back System For USDM WRX/STI : - $899.00 shipped (in stock now !!!) - Weight: 12.9 kg - Fit fit any US Spec downpipe !!! Fujitsubo RM01A One Piece Cat Back System For USDM WRX/STI - $919.00 shipped (in stock now !!!) - Weight: 11.3 kg - Fit fit any US Spec downpipe !!! Fujitsubo Legalis-R Cat Back System For USDM WRX/STI : - $929.00 (in stock) - Weight: 14.5 kg Fujitsubo Super EX Header Twin Spool For JDM WRX/STI (header only) - $1155.00 (in stock) - Weight: 5.4 kg Fujitsubo Catted Downpipe For JDM WRX/STI (Twin Spool) - $1399.00 (not in stock) - Weight: 6.0 kg
__________________
[ WORK WHEELS ] [ RAYS WHEELS ] [ YOKOHAMA WHEELS ] [ WEDSSPORT WHEELS] [ FERODO ] [ BC RACING ] [ COSWORTH ] [ DBA ROTORS ] and many more! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. TEL: 631-586-3520 EMAIL: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by RavSpec; 07-28-2010 at 11:32 PM. |
#6 |
Member#: 26854
Weekend Bump!
__________________
[ WORK WHEELS ] [ RAYS WHEELS ] [ YOKOHAMA WHEELS ] [ WEDSSPORT WHEELS] [ FERODO ] [ BC RACING ] [ COSWORTH ] [ DBA ROTORS ] and many more! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. TEL: 631-586-3520 EMAIL: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
Member#: 26854
Weekend bump.
__________________
#8 |
Member#: 26854
Bump...^
__________________
#9 |
Member#: 26854
Sunday Bump^
__________________
#10 |
Member#: 26854
Weekend bump.
__________________
#11 |
Member#: 26854
Weekend Bump.
__________________
#12 |
Member#: 26854
Happy Labor Day Bump!
__________________
#13 |
Member#: 26854
Weekend Bump
__________________
#14 |
Member#: 26854
Hump day bump.
__________________
#15 |
Member#: 26854
Bump ^
__________________
#16 |
Member#: 26854
Weekend bump.
__________________
#17 |
Member#: 26854
Weekend Bump
__________________
#18 |
Member#: 26854
Weekend Bump.
__________________
#19 |
Member#: 26854
Christmas in 3 weeks!
__________________
#21 |
Member#: 26854
__________________
#22 |
Member#: 26854
bump!
__________________
#23 |
Member#: 26854
[IMG]
[/IMG]
__________________
#24 |
Member#: 26854
bump.
__________________
#25 |
Member#: 26854
20007714 - Cosworth Subaru EJ25 (2.6L) long block with 2004-06 Big Valve Cylinder heads, KK3920 cams, 81mm billet crank, H11 head studs, 12mm oil pump. 9.2:1 CR
PM for special Price 20002504 - Cosworth Subaru EJ25 long block with 2007 Big Valve Cylinder heads, KK3766 cams, OEM 79mm crank. 8.2:1 CR PM for special Price
__________________
| Thread Tools | |
| Display Modes | |
| 05 gry se with radflos, deavers, and many more parts/sale or trade** price change | bl02wrx | Private Vehicle 'For Sale' Classifieds | 10 | 04-27-2010 09:58 PM |
| Cobb, SPT, Blitz, Perrin, Cosworth (free shipping) and many more... | FlatironsTuning.com | Engine/Power/Exhaust | 197 | 11-19-2009 01:20 PM |
| Lowest Pricing Eagle/CP/Mahle/Walbro/APS/Invidia/ and Many More!!!! | Maximum Output | Engine/Power/Exhaust | 4 | 10-12-2009 11:58 AM |
| GT52, Buschur TBE, hydra, hydramist and many more parts | SplatZ400 | Engine/Power/Exhaust | 170 | 08-30-2009 10:54 PM |
| Power Parts @ OAKOS - Cobb, TXS, Samco, Perrin, and Many More!!! | OAKOS Automotive | Engine/Power/Exhaust | 34 | 11-10-2008 03:42 PM |
