#1 |
Member#: 54918
This WRX turned out great for a track car! We could only turn up the GT65 bolt-on to 25 psi before fuel pressure started to drop off. This car has been sitting for about a year and the old 110 oct wasn't so fresh but the 100 octane was.
Since this is a road race car the tune is conservative but still impressive for only 25 psi. On this dyno rotated 35R cars without head work only hit 490-500 at 30 psi (dyno reads about 7% low in my experience for whatever reason). ![]() Mods: Element Tuning Motor (25 STi block with OEM JDM heads) Element Tuning GT65 Bolt On Turbocharger Element Tuning 3" Silicon Inlet Hose Element Tuning Competition Catch Can Element Tuning Hydra EMS 2.5 Element Tuning Hydramist FMIC brand? 3" Exhaust brand? 1000cc low impedance fuel injectors Walboro fuel pump (too small to exceed 25 psi of boost pressure) Andrewrtech built PPG 5 Speed Dog Box Sunoco 110 and 100 oct fuel I would have loved to been able to put a good fuel pump in this and turn up the Element GT65 bolt-on to 30 psi to see what it could do. I think it would have gained another 35-45 whp more with +4 psi of boost but it has a new home in Europe now. Thanks, Phil Element Tuning
#2 |
Wow, 143 views and no comments? 494 whp on a stock-position turbo is no slouch! Great numbers, Phil! I can't wait to get this turbo on my STI
![]() Armin |
#3 |
Member#: 211802
Vehicle:2003 Wrx Sonic Yellow |
Sounds like a really great car. Have any plans to bump that psi on it?
#4 |
Member#: 9960
what does a stock STi make on said dyno?
#5 |
Member#: 54918
Thanks.
I don't tune any stock Sti's LOL! 290 whp (closest I've done to stock) ran 110 mph, 500 whp and customer's trap 130 mph, 540 whp and they trap 134 mph, and 600 whp runs 140 mph trap for what it's worth. My 08 WRX dynoed 185 HP if that helps. This car is getting exported but I wish I could have changed the fuel pump and bumped it up to 30 psi. When things slow down with racing I may run one on my car at 30 psi. Thanks, Phil Element Last edited by Element Tuning; 07-17-2009 at 03:00 PM. |
#6 |
Member#: 68647
Vehicle:07 STI Satin White Pearl |
Nice peak numbers. Power drops off like crazy pass 7k rpm, would you really rev it to 7.5k? Also, what JDM heads are being used?
#7 |
Awesome numbers Phil! How do you think the PPG's will hold up with that kind of power?
#8 | |
Member#: 54918
(not all JDM is better).It's best to shift by 7500 rpm on this engine which is similar to what you find with the USDM STi using stock heads and a 35R. Running to 8k rpm is really only useful in 1-2nd gear. |
#9 |
Member#: 54918
The PPG Straight Cut gears on the 5 speed are reliable up to 550 whp from my experience. I used to run this box on my WRX Time Attack car up to that power level and that car was trapping 134 mph in the 1/4 mile. It may be able to handle more but I never pushed it past that.
#10 |
Member#: 84772
Vehicle:2005 GDB STI WRB |
Congrats Phil. I am looking forward to having you complete my build.
#11 |
Member#: 196559
South East
Vehicle:04 Sti Wrbb |
that is a sick setup! congrats
#12 | |
#13 |
Member#: 54918
#14 |
Member#: 165206
Vehicle:2006 WRB DPSti w/ white shoes |
I love seeing these plots (and the ones on your site).
Makes me too excited to add meth to my GT52, but I promised myself pistons first ![]() |
#15 | |
Member#: 54918
Thanks, Phil |
#16 |
Very nice but for gods sake put some dam smoothing on that thing!
#17 |
wow very impressive. I am in a bind trying to figure out what turbo i want to run with my new build... have it between atp 35, dom 4, element gt52 or gt65.... decisions decisions.
#18 |
#19 |
Member#: 53979
why the hell did u even bother with the walbro in the first place??
#20 | |
Member#: 54918
Thanks, Phil Grabow |
#21 | |
Member#: 33458
Vehicle:Your BOV sounds lame 2002 WRX |
#22 |
Nice work Phil. I bet this customer is very happy
#23 |
Member#: 54918
Thanks yes the customer is very happy.
![]() We now make the mounting plate one piece. Some have asked why the plate is so large. We do that so you have lots of options to mount the fuel pump, wiring, and a Hydramist (water/meth injection pump) if you want. Also the gas tank is very close and it's easier to mount using this type of design as you have two existing seat bolts and then the rear of the plate is behind the gas tank so there's an easy and safe plate to drill two mounting holes. The can is also mounted in the safest possible place between the strut towers and in front of the rear frame rail. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Element Tuning GT65 Bolt On, Hydra, 452whp@22 psi, 07 STI 2.5 Pump Gas | Element Tuning | Proven Power Bragging | 15 | 06-16-2010 01:45 PM |
| Element Tuning GT65 Bolt On Turbo, Hydra EMS, E85 fuel, 532whp, 07 STI 2.5 | Element Tuning | Proven Power Bragging | 10 | 05-18-2010 10:21 PM |
| Element Tuning: Hydra, Hydramist, 668 whp@30 psi, 06 STI 2.5, 35R | Element Tuning | Proven Power Bragging | 25 | 02-15-2010 08:11 PM |
| Element Time Attack STi, Hydra, Hydramist, GT65 563 whp at 24 psi Video Inside! | Element Tuning | Proven Power Bragging | 56 | 09-09-2008 09:39 AM |
| Element GT52 Turbo/Hydra/Hydramist 436 whp | Element Tuning | Proven Power Bragging | 60 | 10-25-2006 11:05 PM |
