Old 07-16-2009, 05:28 PM   #1
Messier77
Member#: 200215
2010 WRX Limited 5DR
SSM
Default Awesome Amsoil 5W-30 UOA
So I just got my UOA back from Blackstone. Didn't really know what to expect because the car is a 99% stock 2005 WRX (STI catback) with 88,000 miles and I'm the third owner (no idea how the previous owners treated it). Ran Amsoil 5W-30 for about 4,000 miles. Results posted below.
Messier77 is offline   Reply With Quote
Old 07-16-2009, 08:08 PM   #2
kh15
Member#: 132400
2006 WRX
ive ran m1, rp, and amsoil in my wrx and so far the amsoil uoa's have been the best by a mile!
kh15 is offline   Reply With Quote
Old 07-16-2009, 09:19 PM   #3
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Very cool.
Might want to try after my next change. Currently using Rotella T.
XanRules is offline   Reply With Quote
Old 07-16-2009, 10:55 PM   #4
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
Which amsoil 5w-30?
Mind is offline   Reply With Quote
Old 07-16-2009, 11:00 PM   #5
Messier77
Member#: 200215
SSM
http://www.amsoil.com/storefront/asl.aspx
The regular synthetic 5W-30...not the XL.
Old 07-17-2009, 11:33 PM   #6
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
You're obviously mistaken. EVERYBODY who's ANYBODY here on NABISCO knows that the use of a 5W30 of any kind will result in the immediate explosion of a Subaru turbo motor.
bulwnkl is offline   Reply With Quote
Old 07-18-2009, 12:38 AM   #7
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
Good stuff, I've been running Amsoil 5w-30 ASL now for about 15K miles.
eurospek is offline   Reply With Quote
Old 07-19-2009, 11:22 AM   #8
NJ2.5RS
Member#: 110353
2006 WRX
black
Yeah same here been running amsoil for about 15k or so now. How much and how long does it take to get your results back from blackstone? Ive been doing 4k change intervals with the amsoil and after this change will be pushing 4500 I would really like to see how the oil has been holding up.
NJ2.5RS is offline   Reply With Quote
Old 07-19-2009, 11:26 AM   #9
bluesubie
Member#: 767
04 FXT
Great uoa, but it is only 4k miles with 1 qt added. How many miles into the OCI did you add the make-up oil? That probably helped the visocisty number.
Those wear numbers are great so the previous owners probably did not use Mobil1 5W-30. I use Amsoil, but I wouldn't use it with 4k intervals. My OCI's are 8k.
-Dennis
Old 07-19-2009, 12:10 PM   #10
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
I usually get my UOA results back from Blackstone Labs (PDF file e-mailed to me) in less than one week from mailing my sample via the USPS. The standard UOA costs $22.50, I sometimes opt for the optional TBN test to see how the oil is holding-up over the life of my OCI. They charge $10 extra for the TBN.
AndyH is offline   Reply With Quote
Old 07-19-2009, 01:40 PM   #11
Messier77
Member#: 200215
SSM
re bluesubie: I added the oil after doing about 1500 miles, so the entire sample was in there for about 2500 miles without having any more added to it.
Old 07-19-2009, 04:31 PM   #12
02redwagone
Member#: 87067
02 Old but tasty
SRP
Having run Amsoil 5-30 for 10k miles with an Amsoil (ea012) filter change midway id say it holds up as good as anything else you could possible put in there. 1 qt makeup on top of filter change makeup.
I had to change it at 10k due to a leaking stock turbo inlet (unknown at the time) letting in dust and raising the silicate count out of control. Otherwise it was ready for more. Its just unmatched for longevity.
All based off Blackstone sampling.
02redwagone is offline   Reply With Quote
Old 07-20-2009, 12:48 AM   #13
C4STI
Member#: 79897
2005 Rock Chipped
Grocery Getter
A few buddies of mine kept swearing by this stuff, so I gave it a shot and have been running the Amsoil Series 3000 5w-30 in my car for 2 years now.
http://www.amsoil.com/storefront/hdd.aspx
I was a bit skeptical at first with it being the Heavy Duty Diesel formulation, but after some research, I decided what the heck. It supposedly holds up really well to the higher temperatures making it a solid choice for turbo vehicles. I also just noticed that it's a bit more expensive then the ASL.
Anyway, thanks to the op for posting this up. I'm going to have to send mine in for testing one of these days to see how well it's been holding up.
C4STI is offline   Reply With Quote
Old 07-20-2009, 09:29 PM   #14
bluesubie
Member#: 767
04 FXT
I added more comments at bitog and linked a run on ASL in a 2.5T at 7k+ miles (hello RonJitsu). I have a bit of xW-30-phobia unless it has some esters (SSO, RedLine, GC, etc.) or maybe exotic base stocks like vege oil .
It's expensive because it's loaded with the old API CI-4+/SL levels of additives (i.e. lots and lots o' zinc and phosphorus ). It has more than the CJ/SM DEO 5W-40.
-Dennis
Amsoil SSO 0W-30 UOA - 8,471 - miles, FXT bluesubie Service & Maintenance 9 09-11-2009 04:38 PM
FS: (WA) 2 bnib amsoil oil 5w-30, 10w-30 jspec-GD wrx Engine/Power/Exhaust 1 02-15-2009 02:52 AM
Just got my UOA in - Mobil 1 5W-30 3100mi Dobbs Service & Maintenance 45 06-27-2008 08:25 PM
Amsoil 5Q 5w-30 and EAO20 Filter bradomcg Engine/Power/Exhaust 6 04-11-2008 01:38 PM
UOA of Castrol GTX 5w-30 dino oil Metallrulz Service & Maintenance 27 10-15-2007 06:58 PM
