Old 07-16-2009, 10:43 PM   #1
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Default Anyone diagnose and repair their AC ??
I am in the market for an air conditioning diagnostic and repair kit. I would like to be able to find the leak(s) in my system and charge it myself. any ideas guys ?
I really havn't messed around with air conditioning THAT much... other than replacing the compressor a couple times on various cars. But I always just bring it to the shop to get charged.... maybe thats why this one isn't working now
IllNastyImpreza is offline   Reply With Quote
Old 07-17-2009, 02:24 PM   #2
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
Finding a a/c leak is not that easy. my shop has U.V. equipment and sniffers. along with 30+ years in the biz. we still get beat by them. As far as diagnostics, it's all gauges. and knowing what the pressures mean.
crampfan is offline   Reply With Quote
Old 07-17-2009, 05:42 PM   #3
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
well the thing is, if there is a common place in the subaru AC system that likes to leak... finding it shouldn't be too hard. Swap out a couple O rings and charge away.
But if its always a shot in the dark... I might just bring her in to the shop... it just sucks dumping 150+ bucks for something I could do myself... for much less. especially when I have no money to do so...
Old 07-17-2009, 05:44 PM   #4
HappyIdiot
Member#: 83494
2004 WRX Wagon
Red
Shoot, I called up two of my local Subie dealers and they said $281 would be the minimum to look at my A/C unit.
HappyIdiot is offline   Reply With Quote
Old 07-17-2009, 05:46 PM   #5
tamadrumr88
Member#: 89013
2012 370Z 6spd Sport
Gunmetallic
Just had the o-ring go on the high-pressure hose side of the compressor on my '97 Legacy 2.5GT. Simple fix, 1.3lbs of refrigerant later and I'm back in business. Oh yeah, and I got new tires mounted too for only $60 total. Today was a good day
Before today the a/c compressor clutch would never engage, I was hoping the compressor wouldn't need to be replaced. We jumped the compressor off of the battery and it engaged so the compressor luckily didn't have to be replaced. The low refrigerant switch kept it from turning over and saved the compressor when all of the refrigerant had leaked out
tamadrumr88 is offline   Reply With Quote
Old 07-17-2009, 09:11 PM   #6
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
yeah **** that. If I had to I would bring it to my buddy who works @ Hogan Tire... But even then it'll still cost me more than it would to do it myself.
so the Orings on the highside that connect to the compressor ?? I'll check that first... I really hope I can figure this one out myself.
Where do you guys buy the R13 or whatever we use? Should I fill it with some oil and stop leak as well??
Old 07-17-2009, 10:17 PM   #7
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
R134a can be bought at any auto part store or even walmart. The oil shouldn't come out at the leaking point so you shouldn't need oil. You will need a vacuum pump to purge the system before refilling (assuming you opened the system).
09rexwagon is offline   Reply With Quote
Old 07-17-2009, 11:12 PM   #8
tamadrumr88
Member#: 89013
Gunmetallic
I believe it takes between 19 and 23lbs of refrigerant... without the necessary gauges this may be hard to achieve
If you're looking at the compressor from the front of the engine bay, it's the hose that enters the compressor from the driver side of the engine bay (proceeds toward the front of the car after coming out of the compressor)
Old 07-18-2009, 12:17 PM   #9
rick-l
Member#: 33868
2003 wrx
srp
16-19 ounces
If you don't start from zero you are just guessing.
rick-l is offline   Reply With Quote
Old 07-18-2009, 02:45 PM   #10
09rexwagon
Member#: 216135
2011 Civic SI
Yes 19-23lbs is way off. The best thing to do is to evac the system with a pump and leave the vacuum guage on the nipple for 5+ hours to make sure it holds the vacuum and confirm a leak or not. After that you can start adding a can or so. When it hits atmospheric pressure it won't suck in anymore and you'll have to start the engine and turn the a/c on (turn on max with doors open so it doesn't turn off. Continue doing that until it stops drawing refrigerant. I know that doesn't sound very scientific, but the compressor will stop being able to take on more refrigerant when it's full so there really isn't a concern with overfilling it.
Old 07-18-2009, 04:59 PM   #11
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
so you guys are saying, since I have a leak somewhere... that I should purge the entire system first? How much does this vacuum pump and the equipment cost ?
I'm really a newb when it comes to AC....
Old 07-18-2009, 11:51 PM   #12
Rickyh
Member#: 40453
If there is a harbor freight nearby youcan get a set of manifold gaugesfor about 40 and a vacuum pump for around 90. Autozone will let you use them for free if you give them a deposit.
Big leaks are easy to find. Small ones are a pain. I actually got tired of searching ffor a leak on a friends car and just went ahead and changed all of the o rings. took a little time to do it but to me it was much less aggravating than trying to find a tiny leak.
Rickyh is online now   Reply With Quote
Old 07-18-2009, 11:55 PM   #13
Rickyh
Member#: 40453
You most certainly can overfill it. I have seen guys just start dumping in 134 until the compressor starts squealing and locking up.
Old 07-19-2009, 01:53 AM   #14
Horkus
Member#: 112667
2002 WRX wagon
buy those A/C dyes, it's also refrigent oil, charge it, run it, look under a black light in the dark and see where the leak is.
Horkus is offline   Reply With Quote
Old 07-21-2009, 12:57 PM   #15
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
Some of the answers here could cost some folks some big money. trust me, it is cheaper to have your system diagnosed and repaired by someone that knows a/c, than it is to buy the proper tools to do it right.(not counting the training needed) If you insist on doing the work yourself, at least have a shop, evacuate, and charge the system properly. without training do you know why you need to evacuate the system? it's just air, right? (I wish I had one of those rollie eye smileys)
Old 07-24-2009, 02:00 AM   #16
avk
Member#: 17252
'06 WX8
59E
To answer the original question: if you know the system is low on charge, you can start by adding some refrigerant pre-mixed with dye, and see where it takes you. You do need to have a set of gauges.
There are two well-visited auto AC forums with very friendly members, sponsored by ackits.com and by acsource.com (two competing supply houses, both based in AZ).
avk is offline   Reply With Quote
Anyone cheat and open their presents early? 24 Off-Topic 49 12-25-2005 01:44 PM
Anyone had their AC recharged on 99-01 RS? DreddRS25 Electrical & Lighting 1 08-30-2004 04:32 PM
Has anybody removed their AC from their subaru? dallas_wrx_blue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-04-2002 07:14 PM
anyone order and install their autometer a pillar? girl Interior & Exterior Modification 4 02-15-2002 04:11 PM
