Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 07-17-2009, 07:05 PM   #1
db_amn
Member#: 163779
2002 wrx
Impreza WRX STi need a base for 2.5L block/2.0L heads w/VF30 and TMIC
Ok, so im running the Stage 4 base on the car now, which it runs well, but timing and fuel are off due to the 2.5L block. Ive been trying to find a hybrid base map, but to no avail. I cant afford to get it dyno tuned yet, so i just need a good base map to help for now. If anyone knows of any, even just a print out,i know how to get in to adjust things, just dont know what to adjust and which way! If I can get a print out, I'd be good!
Thanks,
Sean
db_amn is offline   Reply With Quote
Old 07-18-2009, 06:52 PM   #2
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
why dont you just turn speed density on? do you have a WBo2? As for timing, keep it conservative...just use ecu values for now. I have a similar setup, hybrid with the vf39, but my injectors are huge because I am going to upgrade the turbo and such very soon. Otherwise I'd give you my map. Also for 150$ Clark Turner will set you up with a decent map for now.
BlackJavaPearl04 is offline   Reply With Quote
Old 07-18-2009, 07:35 PM   #3
db_amn
Member#: 163779
2002 wrx
ill try turning that on, i do not have a wideband yet, it is definitly in my plans! yeah, im only running the 565's so your's are probably much bigger. i can see about getting him to build one, but id have to get up the money. I may see what Doug from TS can build one for, he is down here all the time. I definitly appreciate the help!
Old 07-18-2009, 10:16 PM   #4
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
sure n/p
Old 07-19-2009, 07:10 AM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
I use to run Performance driven parts back in 06 before i went overseas.
I have alot of tune utec maps & parameter files.
pretty sure i can help you.
I was trained in utec when nathan was head tuner..
Old 07-22-2009, 05:24 PM   #6
db_amn
Member#: 163779
2002 wrx
Wink
Switching the SD on seemed o help quite a bit! Jaxscooby- Ur name is Ben right? Bill told me to try to get a hold of you. I just cant really afford much right now, gotta catch up my car payments first! But Ive heard of you from a number of people! I definitly want to get together with you!
Old 07-26-2009, 06:25 AM   #7
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
just drop me pm or email..
Old 07-26-2009, 01:42 PM   #8
db_amn
Member#: 163779
2002 wrx
will do, thanks!
Old 07-29-2009, 12:32 PM   #9
alenk37
Member#: 211850
03 WRX
Midnight Black Pearl
hey I pm'ed you a few days ago... you still got ant utec maps? never got a response
alenk37 is offline   Reply With Quote
Old 08-11-2009, 05:18 AM   #10
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
oh i got utec maps..
but i don't just send them..
customers paid for their tunes...when PDP was open..
list your mods..and i'll see if i have a map close to
your set up..
Assembly: 2.0L Heads on 2.5L block Kingpin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 110 09-26-2014 06:58 AM
FS: GST Built 2.5L Block, Stock STi heads 1WRX2NV Engine/Power/Exhaust 18 10-28-2009 12:59 AM
Reliablity Of 2.0l heads on a built 2.5l block? rsw0124 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-30-2009 05:47 PM
2002 WRX sedan 2.0L upgrading to STI 2.5l BLOCK, concerns or suggestions? alex02wrx Engine/Power/Exhaust 2 01-17-2008 12:25 AM
2.0L or 2.5L block, and also need '02 wagon rear spoiler cegpcola Private 'Wanted' Classifieds 4 12-26-2005 10:14 AM
