Old 04-30-2002, 02:08 PM   #1
WRXThis
Member#: 3960
Default Tranny and Rear Diff oil changes help
OK guys so I was new to the Subaru community a year ago when I purchased my WRX and new to AWD as well. Please go easy on me here. How often should one change there rear diff and tranny oil? Anyone have step-by-step instructions on how this is done? I have 18k miles on my WRX and I've yet to check either area. All help is appreciated.
WRXThis is offline   Reply With Quote
Old 04-30-2002, 02:38 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Maintenance schedules can be found in your owner's manual or by logging onto my.subaru.com but I believe it is every 15k or 30k miles. As for how to do it, I can help you with that ...
Tranny:
http://www.northursalia.com/m...id/tfluid.html
Rear Diff:
http://www.northursalia.com/m...diff/diff.html
Brian
http://www.imprezamods.com
http://www.scoobymods.com
http://www.subaruwrxparts.com
Old 04-30-2002, 03:39 PM   #3
WRXThis
Member#: 3960
Wow, just what I needed. Thanks!
Old 04-30-2002, 05:12 PM   #4
TerenceT
Member#: 9510
04 FX35
Pearl White
why is foam in the transmision oil bad?
my guess is foam has less viscosity?
TerenceT is offline   Reply With Quote
Old 04-30-2002, 05:18 PM   #5
2Point5RS
Member#: 3639
How much does one expect to spend on 4 quarts of tranny fluid?
2Point5RS is offline   Reply With Quote
Old 04-30-2002, 06:25 PM   #6
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Frothed oil has both less viscosity and less ability to cool as it is essentially contaminated with air . Air is not nearly as good at thermal transfer as oil is . When I put in Redline Superlight Shockproof, I spent less than $40 on the 4 quarts. Something like regular Mobil gear oil will be dramatically less expensive however.
Brian
R180 rear diff oil change, Help wrxsubiemod Service & Maintenance 1 09-20-2009 12:00 PM
Vibration after 5 MT and Rear Diff Oil Change jjbehren Transmission (AT/MT) & Driveline 2 03-17-2008 03:31 PM
front, center, and rear diff oil change? awdguy Transmission (AT/MT) & Driveline 4 04-28-2005 10:44 PM
Tranny and rear-diff fluid change experience jlyttle Transmission (AT/MT) & Driveline 19 04-29-2002 04:57 PM
Recommended Tranny and Rear Diff Oils.... Philip Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 05-18-2001 01:09 PM
