Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 07-17-2009, 08:57 PM   #1
meebs
Member#: 3251
2009 WRX Hatch
Default BFG SuperSport A/S wear
BFGoodrich Supersport A/S
Miles 12,261
205/55/zr16
EDIT:: I'm pretty sure the large amount of toe was responsible for this .
Inner:
Outter:
Is there anyone else out there experiencing similar wear?
meebs is offline   Reply With Quote
Old 07-17-2009, 09:24 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
45 PSI is way, WAY to high. I run these tires on my Mazda3 at 35 PSI and have seen very little wear over the ~20K miles I've had them. What your showing in those pics seems more like an issue with your car, than the tires. Something isn't right if you're wearing the inside edges that much more than the rest of the tire.
Old 07-17-2009, 10:35 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
the inner wear is due to the toe being something other than '0'
the outer wear is due to not having enough negative camber and having ****ty suspension and too much body roll
and TOO much pressure
and done
Old 07-17-2009, 11:12 PM   #4
meebs
Member#: 3251
2009 WRX Hatch
Do these initial numbers look like it would have caused the wear, specifically the toe? I left out caster because it was right in the middle of spec, and didn't change after the alignment.
First 7000 miles with:
Front Camber: -0.25, -0.21
Rear Camber: -1.02, -1.29
Front Toe: 0.20, 0.20 !!!!!
Rear Toe: 0.22, 0.15 !!!!
After alignment:
Front Camber: -0.29, -0.53
Rear Camber: -1.03, -1.28
Front Toe: 0.02, 0.00
Rear Toe: 0.02, 0.03
The front toe was way out. Would nearly double the max spec of toe (total +0.40 front and +0.37 rear) cause that kind of wear? If so, I'll gladly take back my view on the tires.
Old 07-17-2009, 11:14 PM   #5
meebs
Member#: 3251
2009 WRX Hatch
and done
...And thank you. So it seems they were ruined in the first 7000 miles. Damn I knew I should have had it aligned after I bought it, it just didn't pull or anything, so I procrastinated.
Old 07-17-2009, 11:35 PM   #6
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....don't feel too bad. I ruined two good sets of Pirellis due to bad toe settings, an incompetent alignment shop and laziness (on my part).
Kean is offline   Reply With Quote
Old 07-18-2009, 12:23 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
After alignment:
not enough front neg camber....THAT will make the car push-push-push
MAX it out
Bridgestone LM22 or BFG SuperSport A/S ChuiSTi Tire & Wheel 6 12-20-2008 04:55 PM
BFG G-Force KDW2 vs. BFG G-Force SuperSport Audiosavvy Tire & Wheel 8 10-04-2008 12:24 PM
Used 235/35/18 BFG KDW2 $120 and New 205/40/16 BFG G-Force Sport w/LIFETIME WARRATY timeless SCIC Private Classifieds 13 04-16-2008 07:10 PM
Pirelli P7000 Supersport SubieKidTK Brakes, Steering & Suspension 13 04-25-2001 10:02 AM
Tire Pressures for Pirelli P7000 Supersports uktena Technical Forum Archive 0 06-05-2000 02:17 PM
