07-17-2009, 09:57 PM | #1 |
Member#: 160822
Vehicle:2007 Forester XT Beige |
I need some insight on wheel bearings...
Searching on the subject I found some info, but not a whole lot, and not much on my year wrx.
Ive come to the conclusion of, well nothing really. I've found poeple saying its taken them from 45 minutes to 4 hours to complete, and also its not something a rookie should attempt... My front driver side wheel is making a noise that sounds like a flat tire, but the tire is fine, which leads me to the assumption that it is most likely the wheel bearing, but like I said, I don't know alot about wheel bearings and diagnosing them. So now, I ask the guys at NASIOC for some advice. 2006 WRX TR Stage 2 w/ 63k miles...
07-17-2009, 10:26 PM | #2 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
rotate tires....see if the noise moves
07-17-2009, 11:22 PM | #3 |
Member#: 160822
I will give that a shot..
07-18-2009, 03:24 AM | #4 |
Member#: 112667
VIC
Vehicle:2002 WRX wagon WRB |
sometimes even the tires will make that noise.
IF you have an other set of tires try do that too and see if it disappears. |
08-24-2009, 12:36 PM | #5 |
Member#: 160822
So after rotating the tires the noise has moved to the rear, meaning that something is wrong with the wheel/tire? What should I do next?
08-24-2009, 09:09 PM | #6 |
Member#: 16200
your alignment is bad
get the toe set to '0' the noise is there to stay until you buy new tires....but it is alignment related and will only get worse until your alignment is fixed |
08-24-2009, 10:00 PM | #7 |
Member#: 160822
Man that sucks, considering I bought my tires like 6 months ago.
Thanks scotty, Ill get my alignment set and go from there.. Last edited by Impreza541; 08-24-2009 at 10:11 PM. |
09-15-2009, 01:18 PM | #8 |
Member#: 35332
RMIC
Vehicle:2002 WRX PSM |
Wow, youve been a tech since 1986 and have the stupidity to say this without seeing the car? Im glad you are not my tech, you must be one of the least educated, and most opinionated and often wrong people I have ever seen post on a forum. To the original poster, does the tire appear to have toe wear (gee scotty maybe you should have asked this first?) if not then take the car to where you purchased the tires and complain, if it does how bad is it?
09-15-2009, 07:44 PM | #9 | |
Member#: 16200
these kinds of issues are quite common with these vehicles and in most cases, when the noise moves when the tires are moved....it is a tire issue caused by an alignment issue and the most common issue that will cause this is toe certainly, there are other possibilities....but, for the most part the irregular wear that a toe issue causes makes tires noisy even before it is visually apparent that there is a wear issue and the information that is given and inferred, leads me to think that I'm right and since joining in 2003 you have posted 15 times and one of these was to TRY to slam me go troll some other board Last edited by Uncle Scotty; 09-15-2009 at 07:52 PM. |
09-16-2009, 10:48 AM | #10 |
Member#: 33868
Vehicle:2003 wrx srp |
My 2003 cups every brand of 17" tire I have tried. That may be your noise.
It is not alignment or struts on my car (changed checked). |
09-16-2009, 12:18 PM | #11 |
Member#: 16200
09-16-2009, 04:47 PM | #12 | ||
Member#: 33868
09-16-2009, 07:19 PM | #13 |
Member#: 16200
and that's that
09-16-2009, 10:02 PM | #14 |
Member#: 33868
I need some insight on Intercoolers and some other thoughts. | Nivekk | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 14 | 08-24-2007 06:07 PM |
Need some insight on road bikes | wizzman | Off-Topic | 10 | 11-30-2005 04:27 PM |
Need some Specs on Wheels for STi | JDMTEG98 | Tire & Wheel | 5 | 09-17-2003 09:54 PM |
Need some insights on several wheels | S-WRX | Brakes, Steering & Suspension | 0 | 02-09-2002 06:23 AM |
need some opinions on wheels | skyhigh420 | Interior & Exterior Modification | 12 | 06-23-2001 02:58 PM |
