Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 07-18-2009, 01:02 AM   #1
wrxchitown
Member#: 185520
2011 335i
Default cant get rid of power dip at 4500 rpm
First off not sure if this should be in this forum or over in tuning. but here is my problem anyway.Trying to figure out what is causing the dip in power between 4500 and 5000 rpm.
2.0 first run with new turbo
2.1 added a degree of timing
2.2 removed a degree of timing vs 2.0
2.4 added 1 degree of timing before 4000 and used same timing as 2.0 above 4000(i think I got a little wheel slip)
any ideas what is causing it??
mods:
2006 WRX TR
PE1820
GMBCS
bosch 1000cc
walboro 255
E85 GAS
CSS TMIC
APS 3" turbo back
Open Source tune
wrxchitown is offline   Reply With Quote
Old 07-18-2009, 02:01 AM   #2
noonagon
Member#: 159745
2007 drunkman tuned
mega meth
mods:
2006 WRX TR
PE1820
GMBCS
bosch 1000cc
walboro 255
E85 GAS
CSS TMIC
APS 3" turbo back
Open Source tune
the extreme need for an ewg??
noonagon is offline   Reply With Quote
Old 07-18-2009, 02:14 AM   #3
wrxchitown
Member#: 185520
2011 335i
I would like to go EWG soon, but the boost is staying pretty steady.
Old 07-18-2009, 02:26 AM   #4
noonagon
Member#: 159745
2007 drunkman tuned
mega meth
had a problem like this on a forester, when he changed ewg springs from .7 bar to 1 bar. too a while to tune out, mostly boost issues not afr. grimmspeed bcs as well. just didn't seem to act as fact as others (prodrive) just looks like your bcs catches, then releases and as soon as the boost is climbing back up it hits it hard again.
Old 07-18-2009, 10:22 AM   #5
Bullwinkle1983
Member#: 172332
2006 WRX
Post a full log. Is your clutch slipping?
Bullwinkle1983 is offline   Reply With Quote
Old 07-18-2009, 10:56 AM   #6
MattPersman
Member#: 139385
does it do it on wastegate pressure without the BCS into play
MattPersman is offline   Reply With Quote
Old 07-18-2009, 12:42 PM   #7
wrxchitown
Member#: 185520
2011 335i
I didn't do any dyno logs at lower boost levels so Im not sure. Im going to turn the boost down a little to see if maybee I am out of the eficiancy range of the turbo at tht RPM.
Old 07-18-2009, 01:26 PM   #8
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Post a log......boost, timing, afr, total timing, fbkc and flkc.
that will help a lot more than dyno sheets.
im almost positive that its gonna be a boost issue. the way the torque oscillates it looks like you're overboosting and the turbo dynamics are too high....IE removing too much WGDC which is why you get such a drastic drop in torque.
Also, the large variation in peak tq over the 4 runs also points to a boost control issue.
Phatron is online now   Reply With Quote
Old 07-18-2009, 02:16 PM   #9
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
logs would definitely help. It looks like clutch slip, pulled timing, or a large boost oscillation. If not, have you tried tuning AVCS to smooth it out?
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 07-18-2009, 03:17 PM   #10
wrxchitown
Member#: 185520
2011 335i
logs are all posted at osecuroms.org http://www.osecuroms.org/viewtopic.php?f=2&t=1797 along with maps. I think I may have a blown turbo. noticed some oil under car so I decided to check the oil return line. pulled TMIC and trail of oil spills everywhere. no traces of any oil at up pipe downpie or exhaust wheel. but all kinds at BOV, intake pipe and turbine wheel. Anyone know how to clean oil out of intercooler??
Old 07-18-2009, 05:14 PM   #11
Nuke209
Member#: 108089
2003 WRX
NF Performance
also do a compression test while at it.
Nuke209 is offline   Reply With Quote
Old 07-18-2009, 10:25 PM   #12
Travman1
Member#: 217636
2002 Impreza WRX
Yeah, check compression test a friend of mine had a similar problem with his car and compression test unveiled a few small problems.
Travman1 is offline   Reply With Quote
For that WAPCE you just cant get rid of... izzodesh Off-Topic 28 03-19-2007 10:49 AM
power dip at 3.5k rpm? engr Engine Management & Tuning 2 07-05-2006 11:02 PM
Yahoo! group question - how to get rid of garbage links at the bottom? Wow! Long titl re92 Off-Topic 0 01-26-2006 04:25 PM
help.. cant get rid of the wheel vibration! John #555 Tire & Wheel 8 02-23-2004 12:18 PM
Cant get rid of the rotten egg smell Swivel1000 Normally Aspirated Powertrain 13 11-09-2000 12:58 AM
