Old 07-18-2009, 02:26 AM   #1
junkboxer
Member#: 102873
Default How will these wheels effect the ride?
i have a stock 2006 WRX. stock wheels and am looking into "Enkei EV5." how will this change effect the suspention, handling, feel and ease of my ride?
specs:
Offset: +45mm
Backspacing: 5.74"
Bolt Pattern: 5-100
Rec. Tire Size: 215/45-17
Weight: 19.0lbs.
junkboxer is offline   Reply With Quote
Old 07-18-2009, 02:27 AM   #2
junkboxer
Member#: 102873
double post
Old 07-18-2009, 03:12 AM   #3
junkboxer
Member#: 102873
ttt...............
Old 07-18-2009, 07:13 AM   #4
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
You couldn't pay me enough to run 18's on LI.
Given the weight of those wheels, your suspension will work less effectively and the ride will become harsher.
Nice looking wheel, though.
Spenk is offline   Reply With Quote
Old 07-18-2009, 01:35 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
d000000000000d
go for the 19's
Old 07-18-2009, 02:49 PM   #6
junkboxer
Member#: 102873
double post
Old 07-18-2009, 02:51 PM   #7
junkboxer
Member#: 102873
btw, anyone know how much the stock wrx wheels weigh, these Enkei weigh 19LBS.
Old 07-18-2009, 03:22 PM   #8
mosc
Member#: 177401
2015 STi White
if you care about your suspension, try to get something within 5 or 10mm of stock offset. Your stock offset is +55mm
mosc is offline   Reply With Quote
Old 07-18-2009, 03:34 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
not enough!!!!
ya need 25 pound rimz for that in the hood ride
Old 07-18-2009, 03:55 PM   #10
SlowImport
Member#: 123720
2003 WRX Wagon
Platinum Silver Metallic
2003 wrx 16x6.5 cast = 16.5 lbs.
2006 WRX 17x7 cast = 21 lbs.
2007 STI 17x8 forged = 18 lbs.
2008 STI 18x8.5 cast = 27.5 lbs.
So it looks like you will be a little lighter then stock, so it will net you a little bit of performance and some say even some gas mileage.
hope this helps a little,
Josh
SlowImport is offline   Reply With Quote
Old 07-18-2009, 07:14 PM   #11
junkboxer
Member#: 102873
i care very much about my suspension. i dont want a clunky and strange feel to my ride. i used to have a Tiburon which had a smooth ride. i put new wheels on them and it made the ride feel rougher. bumps and potholes weren't absorbed like they were with the stock wheels.
can somebody explain in layman terms what the "offset" is and how wheels with an offset other than +55 will affect my ride?
Old 07-18-2009, 07:18 PM   #12
junkboxer
Member#: 102873
ok this is the specs of the Enkei rims im looking into. yay or nay?
Offset: +45mm
Backspacing: 5.74"
Bolt Pattern: 5-100
Weight: 19.0lbs.
Old 07-18-2009, 07:41 PM   #13
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
the offset is how many millimeters the wheel and tire will differ from the stock size. a +45 will stick out about 10mm more near the fender opening than a +55. hope this helps. those wheels you picked seem alright.
424wrx is offline   Reply With Quote
Old 07-18-2009, 08:26 PM   #14
junkboxer
Member#: 102873
dammit, is +45 big enough so that when i make hard turns the tire will hit the fender wall? any other differences i will notice with these wheels over stock?
Old 07-18-2009, 08:28 PM   #15
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Get the Enkeis. Those Rotas are terrible. They will have a notable negative impact on steering and handling.
Byzantium is offline   Reply With Quote
Old 07-18-2009, 08:31 PM   #16
junkboxer
Member#: 102873
thats what i plan on getting, im just trying to find out if the lower offset will throw off the feel of my car and/or make the tire rub against the fender wall on turns.
Old 07-18-2009, 08:46 PM   #17
junkboxer
Member#: 102873
so anyway, how would these wheels do with these tires.
wheel specs:
Offset: +45mm
Backspacing: 5.74"
Bolt Pattern: 5-100
Weight: 19.0lbs.
tire specs:
Bridgestone Potenza RE070
Blackwall
ZR Speed Rated
Serv. Desc: 87W
UTQG: Treadwear: 140
Traction: A
Temperature: A140 A A
*obviously, living in the tristate area i would only use these as my spring/summer/fall wheels.
Old 07-18-2009, 08:49 PM   #18
Byzantium
Member#: 207826
85k 2002 WRX
I'm assuming those are 7" wide wheels?
Old 07-18-2009, 08:50 PM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
why in the HELL would you choose THAT tire and THOSE wheels????
i keep seeing more and more fail, and epic fail, on this board.......why IS that???
Old 07-18-2009, 08:55 PM   #20
Byzantium
Member#: 207826
85k 2002 WRX
He changed the wheel (thank god, we don't need another hellaflush ricer). He's not trying to put 215s are 9.5" wheels.
Old 07-18-2009, 09:04 PM   #21
junkboxer
Member#: 102873
what what what?! what did i do. I'm a god dam noob, so sue me man. Ive had this car for a while but it was a lease so i never thought about modifying it. now my circumstances have changed and i own it. I'm looking into wheels and looking for some help. instead of yelling EPIC FAIL like a telephone tough guy being a keyboard warrior, tell me why those tires suck with those wheels. it says on the site:
Those tires fit that recommendation; moreover, are rated pretty good. tell me why i epically failed.
Old 07-18-2009, 09:07 PM   #22
Byzantium
Member#: 207826
85k 2002 WRX
For the record, there are better tires for much less money than those. Bridgestone tends to overprice their products ridiculously.
Old 07-18-2009, 09:07 PM   #23
junkboxer
Member#: 102873
As far as being a ricer is concerned, I'm not trying to put underbody lights on my car/decorate it in company decals/replace my dash with carbon fiber panels and drill holes in my exhaust/etc. i drive a subaru, not a honda.
Old 07-18-2009, 09:09 PM   #24
junkboxer
Member#: 102873
yea im browsing through the tires now, there are plenty of others. im deciding on whether or not to get all-seasons and use these wheels year round.
Old 07-18-2009, 09:20 PM   #25
Byzantium
Member#: 207826
85k 2002 WRX
If you get summer performance, stick with Dunlop Direzza Sport Z1 Star Specs. If all season, I've heard good things about Michelin Pilot Sports A/S Pluses.
Will these wheels fit the 04 STI -- Please Reply crzhog Tire & Wheel 3 02-17-2006 12:33 PM
Will these wheels clear the 4 pots DanThom Tire & Wheel 6 11-01-2005 10:43 PM
how will 17 or 18 effect the ride joshua_d Interior & Exterior Modification 1 10-15-2005 10:30 PM
Will these wheels fit on the STI? mysube97 Tire & Wheel 2 01-28-2004 11:54 AM
