Old 04-30-2002, 03:33 PM   #1
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Default Speaker Sizes By Model And Year
Please correct these if they are wrong, but we needed a thread made with speaker sizes *without major modifications* to make life easier on those going aftermarket. Credit for this idea goes to Silver2000RS. If you have good information on max mounting depth (without spacers) that would be most helpful as well.
1993-2001 Impreza
Front Door: 6.5" wide x ??? deep
Rear Door: 4" wide x ??? deep
Rear Deck: 6/5" wide x essentially unlimited depth
Rear Pocket on wagon: 6.5" wide x ??? deep
2002 Impreza RS and WRX
Old 04-30-2002, 04:13 PM   #2
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Don't forget the OBS for MY02!
All this info is for MY02 front doors:
I quote from Concillian in sticky thread #4 (sticky threads #4,#5,#6 are good for this subject):
Mount depth to the top of the plastic doo-dads that you screw into to the end of that gold colored screw that sticks through the window when rolled down is close to 1.75", not quite there, but close.
Distance from the top of the gold screw to the furthest inside point in the doorpanel is about 3.125"
Distance from the top of the gold screw to the part where the door panel bulges out is about 3.5"
Mounting radius for the original speaker seems to be about 3 3/8", but is probably actualy some metric equivalent, though 3.375 is really close.
So it looks like a spacer of somewhere between 1 and 1.25" would be the max spacer, and would leave some room for the speaker lip.
Thus:
1) Maximum top-mount depth w/o spacer is about 1.6".
2) Maximum top-mount depth w/spacer is about 2.6-2.9".
Other important info for MY02 front door speakers:
3) All base MY02 Imprezas (inc. WRX); (that is, without "upgraded speakers") come with paper driver+whizzer cone speakers that have a non-standard 3-screw extended-radius mounting setup. They look roughly like standard Ford/Mazda speakers, but with the 3 holes at a greater distance from the center. Also, there is no rainshield. Therefore, your aftermarket speaker will ALMOST CERTAINLY require both a rain shield and an adapter/spacer or drilling to get proper mounting holes. See threads in the forum sticky for various spacer & rainshield ideas.
4) The Subaru MY02 "upgraded speakers" apparently come with a rainshield/mounting adapter; if you reuse this, your aftermarket speakers will most likely not require an additional adapter or drilling. This adapter *cannot* be purchased separately from Subaru, as they would loose too much profit by not forcing you to buy the "upgraded" speakers.
5) Almost any aftermarket tweeters can be successfully installed in the stock location by the doorlock. The WRX and other models w/tweeter upgrade have a bracket w/OEM tweeter already installed there. Remove the bracket, throw away OEM tweeter, and install aftermarket on same bracket w/screw or hot glue. Models w/o OEM tweeters have no bracket, so you must make your own or glue or otherwise attach the aftermarket tweeter to the door panel tweeter opening area. The OEM bracket *cannot* be purchased separately from Subaru, as they would loose too much profit by not forcing you to buy the OEM tweeters.
6) Stock speaker wiring: none of the stock speaker varieties has an external crossover. In all models (even w/o tweeters), the front door speaker wires make a Y-split inside the front door, with one leg going to the tweeter location by the door lock, and the other leg going down to the large main speaker opening.
7) Aftermarket crossover installation: most will fit inside the door panel in the indentation under the armrest (max-strength Velcro attached w/Goop adhesive works well here). In this case, just reroute the stock wires from the main speaker opening to an opening in mid-door, attach quick disconnects, and continue to the the crossover's IN posts. If your crossover is too big to fit in the door panel, mount it in the kickpanel area or under the dash over by the side. Then, cut the speaker wires as they head for the door and attach to IN posts. Drawback -- you will have to run 2 pairs of wires from the crossover's outputs *through the door wire bundle tube* to hook up the tweeter and woofer.
Old 04-30-2002, 04:29 PM   #3
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
MY02 rear door speaker info:
(See forum sticky post #7 for full details and photos)
1) Stock speakers are 4". Mounting depth is essentially unlimited, as rear window does not come down that far. Stock speakers come with mounting adapter/rain shield. Reuse this to mount aftermarket speakers. If there is a gap between the outside of new speakers and inside of mounting adapter, cut a ring of 1/16" foam weatherstripping wide enough to fill the gap and sandwich it between the speaker and adapter.
2) Opening in metal door is big enough that some 5.25" speakers will fit. For most others, simply adding a 0.25-0.5" spacer will bring the speaker out far enough that the remaining part of its basket will fit through the metal opening without problem. For mounting/rainshield, you're on your own.
Old 05-01-2002, 03:18 PM   #4
avk
Member#: 17252
'06 WX8
59E
About rear speakers on 1993-2001 (VIN GF) wagons:
For 1993-96, the rear speakers are mounted on top of the strut towers, like on 1st gen. Legacy. From 1997 on, the speakers are in the rear doors. I believe the size is 6.5 for both locations.
avk is offline   Reply With Quote
Old 05-06-2002, 05:22 PM   #5
Pinochle
Member#: 638
93 L, 00 RS, 04 TS
pat + nat
What's the info on the front speakers for the GC8s?
P.
Pinochle is offline   Reply With Quote
Old 07-26-2002, 08:07 PM   #6
edkwon
Member#: 453
2014 Audi S4 B8
Porsche Cayman GTS
bump
Why was i told on several instances that the 99RS front door speakers were a smaller size than the 00-01 MY which have 6.5" ?
I was told multiple times on the board that the 99MY have 5.25" size front door speakers, yet when i do multiple searches elsewhere online they all say that the MY99 included has 6.5" speakers? Who is correct here?
Ed
edkwon is offline   Reply With Quote
Old 08-07-2002, 09:20 PM   #7
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
We know now don't we.
The stock size for the 99 RS front door is 5.25 inches.
dbrier is offline   Reply With Quote
Old 08-10-2002, 01:57 AM   #8
edkwon
Member#: 453
2014 Audi S4 B8
Porsche Cayman GTS
Dale: what did you forget already?
front stock size- 6.5"
rear stock size- 6.5"
Ed
Old 08-10-2002, 03:34 PM   #9
Siper2
Member#: 1134
2007 BMW 328xi wagon
Lightbulb
Brian (North_),
Just a suggestion... How about sticky-fying this thread?
If it's a common question, it'd be a good common reference point.
Yeah?
-S2-
Siper2 is offline   Reply With Quote
Old 09-05-2002, 07:06 PM   #10
jsmaze
Member#: 23354
2003 WRX Wagon 4EAT
I will be purchasing a 03 WRX Wagon very soon and want to move the system from my old car into the WRX. Right now I have a set of Boston Pro 6.5's and Boston Rally 6.5's.
What I can gather is that they will fit ok in the doors, both front and back? Im not looking for anything fancy and spacers are not a concern (as of now my door speakers in my current car have about a 1 1/2" spacer).
I figured I would put up a quick post to check for sure and from the info here it seems certainly possible.
Thanks much!
Jeff
jsmaze is offline   Reply With Quote
Old 10-29-2002, 08:48 AM   #11
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Crystal White Pearl Mica
ABSOLUTE MAX for the 2000-2001 SEDAN:
Front doors can be no more than 2 7/16" deep.
This is such a close fit, the windows actually peeled stickers off of the back of my speakers.
Texas25RS is offline   Reply With Quote
Old 11-06-2003, 12:17 PM   #12
Stevins
Member#: 33931
2001 Impreza RS
Anyone have Boston Pros in the front doors of their GC8?
Stevins is offline   Reply With Quote
Old 11-10-2003, 05:59 PM   #13
webHead_RS
Member#: 41516
2001 2.5 RS
Blue Ridge Pearl
Has anyone tried CDT's HD-62CF series in their front doors?
webHead_RS is offline   Reply With Quote
Old 11-25-2003, 01:58 PM   #14
rkevans
Member#: 44204
2004 Impreza WRX STi
Yes. You'll need the 'thick kit' from www.iaperformance.com.
Use 4 washers (included) under each of the lower mounting screws to clear the window. Seal the resulting space (I haven't done this yet...).
They sound nice.
Rick
rkevans is offline   Reply With Quote
Old 03-09-2004, 08:28 PM   #15
Purgatory-Z
Member#: 31664
2003 Impreza WRX Sed
Bump for this dinosaur thread.
Question: If I already have the upgraded speakers which apparantly have a spacer/rainguard (03 WRX), will speakers like infinity reference or boston 6.5 pros give me problems without the purchase of the iaperformance adapter?
-PurgZ
Purgatory-Z is offline   Reply With Quote
Old 12-11-2006, 11:28 AM   #16
Chapel
Member#: 3496
1995 Roadmaster
Beige
So, what are we saying the maximum depth is safely?
2" with a spacer?
what spacers do you guys use that don't mess with the door cards?
Chapel is offline   Reply With Quote
Old 12-11-2006, 02:17 PM   #17
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
whoaa, back from the dead....
Check out iaperformance.com under the Subaru Stereo section
02BlueSuperRoo is offline   Reply With Quote
Old 12-11-2006, 06:04 PM   #18
HorrorBusiness
Member#: 126981
04 WRX Wagon
SRR
They sound nice.
Rick
I wish I had known about these earlier, would've made things so much simpler
HorrorBusiness is offline   Reply With Quote
Old 12-13-2006, 12:04 PM   #19
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Yes they make things easier if you are willing to spend the money on them (I did back in the day). But they have also been in the Manifesto for a long time know. Make sure you arent missing anything else in there.
offset
offset is offline   Reply With Quote
Old 02-12-2007, 11:20 PM   #20
misterjoshua
Member#: 140599
'05 WRX Stg2
1st post here (yay!)
Just bought an '05 WRX and wanted to know what the stock speaker sizes were (front and rear door) so I could get some speakers ordered without having to remove the door panels just to check the sizes. My system is painfully stock and even though I LOVE the car, the system needs upgraded asap.
Appreciate it.
misterjoshua is offline   Reply With Quote
Old 02-20-2007, 01:56 PM   #21
Rippen Griffen
Member#: 91708
AD Motorsports FTW
06 OBP - Cobb AP Stg 2
Just finished installing my front speakers - after an exhausting search of ideas...I decided to use the OEM speaker surround to mount my 6 1/2" speakers.
I made 3 brackets from small thin pieces of metal
Then I attached the new speakers on the OEM surround like this
Rippen Griffen is offline   Reply With Quote
Old 02-20-2007, 09:19 PM   #22
Daishi00
Member#: 78952
2005 WRX
CGM
^^^wow that's a lot of work especially when you can make baffles pretty easy out of mdf, HDPE or HDPP, BUT it is a great design and gives people options when they don't have access to a router. Excellent MacGyver skills
misterjoshua - you can fit 6.5" in the front up to about a 3" depth with some modifications, but nothing huge or hard to do. Rears you can fit 5 1/4" without too much of an issue as well.
Daishi00 is offline   Reply With Quote
Old 02-21-2007, 08:40 AM   #23
Rippen Griffen
Member#: 91708
AD Motorsports FTW
I have jig, circular and hand saws, but I don't have a router. I was going to try a 6" PVC pipe and a thin board.
It wasn't much work either...I had a some thin malleable metal, and cut it to length with wire cutters. Bent the metal and attached to the OEM surround. I think it took more time to draw the pretty pictures than to fabricate the metal pieces
Old 02-21-2007, 08:54 AM   #24
Daishi00
Member#: 78952
2005 WRX
CGM
haha good to hear.
Old 02-21-2007, 05:44 PM   #25
HolyCrikey
Member#: 66776
2005 Mazda3 Hatch
Titanium Grey Metallic
Fantastic thread, definitely needs to be compiled, revised and stickied!
Thanks!
HolyCrikey is offline   Reply With Quote
What make, model and year car commercal? (no link) PWR_Slave Off-Topic 13 02-25-2010 10:46 PM
$6500 what model and year to buy alpentalic Newbies & FAQs 9 09-17-2009 11:05 PM
Do WRX pulleys fit NA cars of the same model and year? Spudchucker Normally Aspirated Powertrain 5 02-01-2009 12:15 PM
OEM Speaker Upgrade - Different Model Year - Will it Work? WRXcellent Car Audio, Video & Security 5 04-07-2006 05:30 AM
What is the proper speaker size for doors and rear decklid? adrive43 Car Audio, Video & Security 13 07-21-2005 03:07 PM
