Old 07-18-2009, 07:29 PM   #1
Never_Satisfied1
Member#: 155234
02 Wrx
Talking Help removing cam gear bolt!
I'm replacing the head gasket on my wrx and inorder to do that I have to remove the cam gear. I've tried impact wrench, that didn't work. Tried it with breaker bar with a pipe extension and I broke the 10mm Allen socket about 4 times now.
Is there another way to remove the cam gear bolts?
Never_Satisfied1 is offline   Reply With Quote
Old 07-18-2009, 08:00 PM   #2
xilles
Member#: 147056
um leave your timing belt on to keep the cam gear from moving and breaker bar extension there is a pic around here of the timing belt vice gripped together so the 2 cam gears dont move. thats the best way to do it. or a actual allen key and some sort of device for leverage. sorry if this doesnt help
xilles is offline   Reply With Quote
Old 07-18-2009, 08:09 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
make several radial cuts on the 'skirt' on the bolt with a dremel and cutoff wheel
or chain drill the skirt off
remove bolt
and then replace the bolt
or
get a 6-8 FOOT----yes FOOT long pipe for your breaker bar and apply slow, ever increasing pressure to the system until the bolt comes loose or you do the above
I saw a master tech at the dealer cut the bolt and replace it because it wouldnt budge otherwise
http://forums.nasioc.com/forums/showthread.php?t=964052
Old 07-18-2009, 08:57 PM   #4
PIGSTI06
Member#: 134783
08 STI BLUE\GOLD
01 Audi A4 Silver
That's crazy that you got to do it that way... but it is what it is...............
PIGSTI06 is offline   Reply With Quote
Old 07-28-2009, 07:17 PM   #5
skeet2121
Member#: 207257
'04 WRX
1-1/8" wrench on the cam with a big friend and a breaker bar and 2 ft extension with another big friend.
skeet2121 is offline   Reply With Quote
Old 07-28-2009, 10:50 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
ya didnt read the thread did ya???
there is NO WAY to do this on the AVCS cams as there is no 'flat' on the cam to hold them
cam gear bolts, crank bolt stuck boosted lego Transmission (AT/MT) & Driveline 16 04-13-2011 10:11 PM
Stripped 10mm Hex Cam Gear Bolt!! HELP!! onemoreday21 Built Motor Discussion 41 11-17-2008 02:27 PM
Crank pulley bolt/Cam gear bolt Starkiller Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-17-2007 01:55 PM
Can't remove cam gear bolts ForceFedDSM Service & Maintenance 5 10-08-2006 08:35 PM
need help with cam gear bolt attitude Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 01-07-2005 06:22 PM
