07-18-2009, 11:15 PM | #1 |
Member#: 147521
SCIC
Vehicle:11' WRX Swaggon PSM |
Belt squeel sound?
At start up today with a/c on i heard a squeeling noise from under my hood. It looks like the timing belt that's spinning is stuck in a way where it makes the squeaking noises. What can i do to fix this? Is this common ? Or should i replace a whole new belt, or is there anything i can spray to stop the noise?
07-19-2009, 12:53 AM | #2 |
Member#: 32669
SCIC
Vehicle:2007 2.34LR, EFR7670 LINK G4+ hybrid STi |
This noise is coming from behind the black timing belt cover? Might be a tensioner going out
07-19-2009, 12:56 AM | #3 |
Member#: 217636
NWIC
Vehicle:2002 Impreza WRX Blue |
I am having a similar problem/sound but its only after the car has been sitting for a good 5 or 6 hours. The squeak is only when I first start the car, and lasts for about 2 minutes and then goes away.
Any Idea? |
07-19-2009, 01:02 AM | #4 |
Member#: 32669
SCIC
Yes, find what's squeaking and that's your problem. How hard is that?
07-19-2009, 01:04 AM | #5 |
Member#: 196050
NESIC
Vehicle:2002 VF-39 Rex 02C |
well that happned to my car alot too .....it was serpintine belt i just got belt dressing and sprayed all the pullys and both visible belts and its all gone now
07-19-2009, 01:18 AM | #6 |
Member#: 180169
Vehicle:2k2 WRX WAGON SILVR 08 S550 AMG Blk/Blk |
Timing belt don't make squeacking noise due to its teeth pattern.
07-19-2009, 01:23 AM | #7 |
Member#: 32669
SCIC
I think the OP meant the alternator "timing belt"
07-19-2009, 01:29 AM | #8 |
Member#: 112667
VIC
Vehicle:2002 WRX wagon WRB |
Take the belt of, degrease it, degrease the pulley's, clean then, and reinstall the belts and tighten the belt to spec.
07-19-2009, 01:45 AM | #9 | |
Member#: 180169
you have a point. but instead of reinstalling it op should just buy a new one. it should not be that expensive and it sure will give you peace of mind. |
07-19-2009, 03:28 AM | #10 |
Member#: 217636
NWIC
I was told that the timing belt probably wasn't the part that was squeaking if it has anything to do with a timing belt. I was told that there is an idler pulley that is notorious for going bad.
07-19-2009, 08:15 AM | #11 |
Member#: 210593
Vehicle:2002 WRX PSM Epic tuned 300whp |
I just replaced both of my belts due to a squeel noise and now its gone. Took me 3 times to find the right belt from Advance but I got the right ones now
07-19-2009, 10:13 AM | #12 |
Member#: 189810
Vehicle:2002 WRX Sedan PSM |
yeah i changed the belts on mine and it stopped now i have to make the time to tighten them up a little bit because it started to come back after a couple of months
07-20-2009, 05:00 AM | #13 |
Member#: 147521
SCIC
where should i get new belts? does it matter what kind i get?
07-20-2009, 11:23 AM | #14 |
Member#: 189810
i got mine from autozone. But any autoparts store should carry them. They are cheap. I bought the gator belt i can't remember what company makes it but it seems to do pretty good.
07-20-2009, 02:06 PM | #15 |
Member#: 112667
VIC
get gates belt, they are good
07-20-2009, 04:02 PM | #16 |
Member#: 147521
SCIC
07-20-2009, 04:04 PM | #17 |
Member#: 184325
VIC
Vehicle:2005 WRX silver |
07-20-2009, 04:22 PM | #18 |
Member#: 71665
South East
Vehicle:1994 Impreza White |
I replaced my ps/alternator belt with a Gatorback belt this weekend after mine broke. Solid belt made by Goodyear, and has "NASCAR" technology! Pretty solid looking belt and perfect fitment.
07-20-2009, 05:47 PM | #19 | |
Member#: 39944
Vehicle:2003 WRX Silver |
See this post, I have a picture of what it looked like: http://forums.nasioc.com/forums/show....php?t=1794258 |
03-16-2011, 03:48 PM | #20 |
Member#: 277004
2nd set of belts
It sounds like I need better belts.
a little over a year ago I replaced all my belts. everything was fine, untill the weather got cold in SOCal, my belts started squeeling like crazy, I had my mechanic take a look it. he thighten up the belts, they where better but still squeeling. about 8 months ago I moved to Northen Cali, I asked my mechanic in socal to do some maintance along with replaceing the belts, he replaced the belts free of charge. he did this before I moved everything was fine, until the weather changed and it got colder. now my belts are squeeling a lot. and it will be a long drive for me to ask him to replace my belts. but wanted to know what worked for most of you. I have an 02 wrx. The squeeling increases when its cold and i am turgning the wheels, I can also feel a lag on my steeirng when I turn at slow speeds <5mph, and it's cold. thanks |
03-16-2011, 03:54 PM | #21 | |
Member#: 44762
Vehicle:2013 BRZ WRB |
But no, this guy's timing belt isn't squeaking. The AC belt is. @Sworks, try bleeing the power steering pump. Entirely possible your belts aren't the squeak. Last edited by qoncept; 03-16-2011 at 04:03 PM. |
03-17-2011, 04:01 PM | #22 |
Member#: 277004
03-17-2011, 05:40 PM | #23 |
Member#: 44762
Maybe you DO just have bad luck with belts.. I'd replace it myself instead of taking it to a mechanic though. Just need a ratchet and a 12mm (er, 14mm?) socket, 4 bolts.
03-17-2011, 06:10 PM | #24 |
Member#: 252648
Vehicle:2010 Mini Cooper Pepper White |
If the belt has been squeeling long enough it's pretty much done. The surface that goes to the pulleys is probably worn smooth. The friction created when it slips will cause the surface to get slick and you won't be able to get it to completely stop slipping even with tightening more. What's a basic belt cost, like $10? Just take a few minutes and replace them both, and while you're at it replace the A/C tensioner pulley if it hasn't been replaced.
03-17-2011, 08:37 PM | #25 |
Member#: 248219
E. Canada
Vehicle:2004 WRX 68HTA+HFS6 PSM |
If you want to be cheap buy belt dressing. It's pretty cheap and you spray it on the belt to make it quiet.
Belts squeeling and wierd noise? | bigolrig | Newbies & FAQs | 13 | 02-03-2010 07:28 PM |
Squeeling sound that stops when I brake or hit a bump? | garface | Brakes, Steering & Suspension | 26 | 08-17-2008 10:56 PM |
Belt squeel of death!! | emsmap | Newbies & FAQs | 34 | 01-25-2008 02:11 AM |
What does a sticky timing belt idler sound like? | nast | Service & Maintenance | 2 | 02-08-2007 12:03 AM |
What does timing belt noise sound like? | 98legacy | Service & Maintenance | 6 | 01-13-2003 06:29 AM |
