Old 07-30-2009, 12:42 PM   #26
b00st3d
Member#: 9891
2015 RC-F
Ultra White
awesome diy! i think flat black would look better.
b00st3d is offline   Reply With Quote
Old 07-30-2009, 12:44 PM   #27
Sleepr56
Member#: 67326
2015 WRX Limited
World Rally Blue Pearl
Matte/Flat black looks badass (that's what I did)
Paint matched would look unique.
My car is black....so my opinion probably doesn't count
Sleepr56 is offline   Reply With Quote
Old 07-30-2009, 01:27 PM   #28
scprs
Member#: 172359
2005 STi
wrb for sure!!!!!!!!!!
scprs is offline   Reply With Quote
Old 07-30-2009, 02:02 PM   #29
Claymra
Member#: 83167
2002 Wrx
MBP
flat black because you have flat black in your fogs, front bumper, and headlights. it would tie it together i guess.
Claymra is offline   Reply With Quote
Old 07-30-2009, 02:06 PM   #30
MicMcKee
Member#: 185297
2008 Evo X
RR
IMO the WRB paired with the mesh sitting farther back makes it look like it was a half-arsed attempt at a grille...
The black doesn't have the same problem... It looks more natural...
MicMcKee is offline   Reply With Quote
Old 07-30-2009, 03:29 PM   #31
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
Default Decisions...Decisions
I hear what everyone is saying, and I really appreciate the input. It is a tough decision because obviously painting it black would be much easier, but then I am straying even further from what I originally set out to do. If I paint it WRB, its much closer to the Prodrive grille which I was hoping to replicate.
I do like it black, but it feels like a cop-out to completely abandon my original goal. This is why I normally don't set goals for myself
J
thrasher is offline   Reply With Quote
Old 07-30-2009, 04:19 PM   #32
RedefinedTR
Member#: 149848
2011 Honda CRZ
Performance White Pearl
I like black better too. You may want to use a bit of body filler to smooth out your grind marks so they do not show up on the fial product tho. But It looks killer now that you removed the rest of the material under the logo.
RedefinedTR is offline   Reply With Quote
Old 07-30-2009, 04:28 PM   #33
2.5ReallySexy
Member#: 167943
I say move the emblem down it cant be that hard to do. It will be a good learning experience.
2.5ReallySexy is offline   Reply With Quote
Old 07-30-2009, 04:48 PM   #34
h23
Member#: 183045
Similar to mine:
h23 is offline   Reply With Quote
Old 07-30-2009, 04:58 PM   #35
cmiovino
Member#: 134005
2004 WRX Premium
Looks good. I might end up make up making my own flat black mesh grill for my OBS. I hate silver mesh, but dark gray or black looks good. My stock one is majorly faded.
Old 07-30-2009, 05:03 PM   #36
02wrxRally
Member#: 205994
'02 Bawkeye WRX
'04 tOtaledBS | '68 MGBGT
I've got a project like yours brewing too, and I've been debating painting it wrb, or black too. I think that black plastic doesn't look great, but the black color makes the opening look bigger. The wrb makes your eye fill in the areas of the grill surround instead of just blending in with the mesh/shadow of the grill opening. Does that make sense? I think painting it blue will do more than just a color change, it will make the stock grille look smaller.
02wrxRally is offline   Reply With Quote
Old 07-30-2009, 06:52 PM   #37
itsdaliks
Member#: 214164
Looks great man, love the blue. Combined with the black mesh it seems to add some depth, like you’re being sucked into a vacuum hose…
itsdaliks is offline   Reply With Quote
Old 07-30-2009, 09:31 PM   #38
thrasher
Member#: 40579
2002 WRX Stage 2+
Don't worry, I haven't even started sanding yet. All I've done is Dremel out the plastic parts I didn't want - there's still a lot of sanding to do before paint. I am trying to avoid body filler if at all possible.
J
Old 07-30-2009, 09:36 PM   #39
thrasher
Member#: 40579
2002 WRX Stage 2+
There's more to it than just cutting it and sticking it to the bottom. In order to make it look similar to the Prodrive grille or the WRC bumper, it would require some really careful shaping around the back and sides of the badge. As much as I would like to make it look like the Prodrive grille, I think if I move the emblem down and use body filler, it will look bad, and I will eventually get discouraged and give up. Maybe I will try to get a hold of another OEM grille and actually follow through with it. That way if I f%$& it up, I won't feel like all was wasted.
Old 08-02-2009, 01:43 PM   #40
thrasher
Member#: 40579
2002 WRX Stage 2+
Default Sunday Update
I had a request from someone to post the measurements of the mesh that I cut, so here ya go:
After I finished rough sanding with 150 grit paper, I sanded with 220 grit before priming/painting (probably should have used 400+, but I used what I had)
Then I did some masking with blue painters tape
And here is the grille after 3 coats of primer
I still need to get black paint, and I gotta figure out what I'm doing with the badge. I sanded the black paint out of the inside, but now it is cloudy from all the scratches. I am hoping with some finer grit sand paper and some plastic polish I can clear it up again before I paint it.
J
Old 08-05-2009, 09:35 PM   #41
thrasher
Member#: 40579
2002 WRX Stage 2+
Talking At long last...its finished!!!
Well, it took longer than I thought it would, but it was worth it. I had the grille painted with three coats of paint, but I tried to use the same cheap stuff I used on the mesh, and it looked like a$$. Then I bought some flat black paint made for "high heat" applications, but that looked too much like my gas grill.
Soooo, I resanded the whole thing, and bought Rustoleum Black Satin Finish at Home Depot. Here is the grill after three coats of paint. The color and sheen matches the other black plastic on the front of the car really well, so I am pleased.
Also, during test fitting I noticed that the bottom of the grille sagged since the badge piller had been removed. To remedy this, I stuck two small 3M non-scratch furniture feet on the center push tab like so
And so without further ado...
In case anyone is wondering, the paint I used on the badge is not WR Blue pearl. I went to the Subaru stealership the other day to get touch-up paint, and they wanted $9.00 for a little bottle. And then they wanted me to wait until Friday. So I said F&$% it, and went back to Home Depot.
Here's what I got...pretty good match if I do say so myself
Here are both paints I used in case anyone would like to get the same stuff
I realize that the end product is almost the complete opposite of what I originally set out to do, but I am very pleased with the result. IMHO, it came out very well for a DIY project, and it cost me very little.
Thanks for everyone's input.
John
Old 08-05-2009, 10:32 PM   #42
Mobutusan
Member#: 118017
2004 WRX Waggin'
Good job. That looks really clean, and almost OEM, but better. I've got to see if I can pull this off on my '04.
Mobutusan is offline   Reply With Quote
Old 08-05-2009, 11:32 PM   #43
integral_machine
Member#: 157016
02 WRX - MBP
Invisible...
Great job! Something that you might want to keep in mind is that the spray paint on the gutter guard will start chipping, no matter how many coats you use. Mine did and I reshot it with plasti-dip spray and it has held tight with no chips for over a year....
integral_machine is offline   Reply With Quote
Old 08-06-2009, 12:30 AM   #44
STi Hockey Guy
Member#: 212589
12 135i
alpine white
man that looks so good and clean. great job! your car is awesome looking
STi Hockey Guy is offline   Reply With Quote
Old 08-06-2009, 02:30 AM   #45
daleyswanson
Member#: 205604
87J Robinson
R22
i was skeptical to start but it turned out great. awesome job man
daleyswanson is offline   Reply With Quote
Old 08-06-2009, 08:11 AM   #46
thrasher
Member#: 40579
2002 WRX Stage 2+
Thanks!
Yeah, thanks. I did notice that when I was test fitting it the first time, I scraped some paint off very easily, and had to respray it. I thought it was just because of the cheap paint I used. Fortunately the mesh is not attached to the grill, so it will be very easy to remove and repaint if necessary.
Thanks!
Thanks!
Old 08-06-2009, 08:06 PM   #47
Subiebobby
Member#: 181046
2002 wrx wagon
psm aps s/r55, meth 6 spd
looks great!
Subiebobby is offline   Reply With Quote
Old 08-06-2009, 09:06 PM   #48
YBajaSteve
Member#: 184040
. 03' Baja- Sold
83' Datsun 280ZX
my black painted grill itself has started chipping, i wonder if plastidipping the whole grill would look that bad, and it might hold up really good against road debris and bugs. any thoughts?
OP, car looks awesome btw
YBajaSteve is offline   Reply With Quote
Old 08-08-2009, 04:45 PM   #49
thrasher
Member#: 40579
2002 WRX Stage 2+
Smile Another successful DIY!
Here's a couple better pics of the new grille:
Thanks for all the feedback and positive comments everyone!
J
Old 08-08-2009, 05:59 PM   #50
Subaru Tripple 5
Member#: 211600
2001 Suzuki DRZ400
Supermoto
that looks great, nice work
Subaru Tripple 5 is offline   Reply With Quote
DIY Bugeye Grill - opinions/comments welcome Aleman03wrx Interior & Exterior Modification 32 03-07-2010 05:35 PM
suggestions on DIY grill material 2point0 Interior & Exterior Modification 26 06-14-2009 08:34 PM
Need your input on what to do next...stuck on a few choices. jarelee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 02-25-2004 04:30 AM
Need some input on my 1/4mi times silverscooby Proven Power Bragging 15 09-20-2002 06:09 PM
I need your input on exhaust modification. ttg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-23-2001 10:27 AM
