Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 07-19-2009, 01:12 PM   #1
guynexdoor
Member#: 115673
2002 wrx sedan
blue
Default problems when shifting between 2nd and 3rd gear
I have an automatic, 2002 wrx sedan.
When the car shifts from 2nd to 3rd gear, at around 3RPM...the RPMs shoot up to 4RPM, it's hard to describe what's happening. The shifting just isn't smooth.
the best way I can describe it is like when a beginner is learning how to drive a MT, and the transitions aren't smooth, and so when you engage the clutch, it puts the car on Neutral right, and then the engine revs up if you don't switch into gear smoothly enough...
that's what's happening to my car. I don't know how else to describe it.
guynexdoor is offline   Reply With Quote
Old 07-19-2009, 04:40 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
how's the fluid look/smell?
Old 07-20-2009, 01:25 AM   #3
guynexdoor
Member#: 115673
2002 wrx sedan
blue
fluid is fine. i have 86,000.
is the transmission controlled by a computer on the 2002 wrx? Or is it completely independent? perhaps the tranny is fine, just the computer?
2nd and 3rd gear pull log economy AP map vf30 boost too high ? bozz AccessPort 4 04-30-2008 03:02 PM
FS: 03 WRX 5speed Tranny - broken 2nd and 3rd gears ProdriveRex NWIC Private Classifieds 2 11-20-2006 09:15 AM
2nd and 3rd gears kris555 Newbies & FAQs 5 05-20-2006 08:16 PM
Irregular boost in 1st, 2nd, and 3rd gear JDM Junkyard Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-04-2003 06:45 PM
grinding 2nd and 3rd gear synchros. solomrus Technical Forum Archive 0 08-11-2000 02:57 PM
