Old 07-19-2009, 01:21 PM   #1
tacomaprime
Member#: 70572
2005 Tacoma
Default 1300 miles on new tires, nail in 1 sidewall. Can I just replace 1?
I bought some nitto invo tires in march, and have only put 1300 miles on my car since then. I only have a 5 mile drive to work. This morning I went out and found the drivers side front is flat from a nail in the sidewall. It's not repairable.
So my question is, seeing as how I only have 1300 miles on the tires, and all I have done is driven back and forth to work, can I get away with just replacing 1 tire, instead of buying 4 brand new ones? Just curious. I can afford to replace all 4, but since I don't race the car, and the tires don't get abused in the least, I figure if I can get away with just replacing 1, why replace all 4.
Thanks.
tacomaprime is offline   Reply With Quote
Old 07-19-2009, 01:34 PM   #2
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
Worst case, you could order one from TireRack and they could shave it to match the rest. Probly wouldn't require much shaving at all to make it equal to the others.
thrasher is offline   Reply With Quote
Old 07-19-2009, 01:44 PM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
With that little mileage, you should be fine to replace the one tire. I had a similar issue way back with aset of S0-3's. Replaced just one with about 5K miles on them. Never had an issue.
Old 07-19-2009, 01:47 PM   #4
tacomaprime
Member#: 70572
2005 Tacoma
That's what I figure too. I have a 5 mile drive to work, and it's mostly a flat, smooth highway type road, so it's not like the tires are getting beat up. And the 1300 miles is over a 4 month span. As you can see, I don't drive much.
Old 07-20-2009, 02:04 AM   #5
Web Foot STi
Member#: 39086
2004 STi
Put the new rubber on the left front. It tends to get the most wear. You will be fine.
Web Foot STi is offline   Reply With Quote
Old 07-20-2009, 01:23 PM   #6
mosc
Member#: 177401
2015 STi White
3/32 is the limit. Measure all your tires and find their treaddept. Find the new treaddepth. If you're within 3/32 on all 3 tires, you can stick a new tire on provided it's the same size and model. 3/32 is more of the limit though. If they're at the limit, you should probably just ask tirerack to shave em 3/32 for you. If it's 2/32 or 1/32 off of new though, I wouldn't bother.
mosc is offline   Reply With Quote
Old 07-20-2009, 01:56 PM   #7
BeatLA
Member#: 182396
2005 WRX Wagon
2004 FXT for Mrs. BeatLA
For only 1300 miles, you'll be fine as long as you haven't been performing powerslides for 1000 of those miles. As someone posted, make sure it's in the front so it catches up a little quicker to the others.
BeatLA is offline   Reply With Quote
Old 07-20-2009, 03:38 PM   #8
Tire Rack Moderator
Member#: 1215
ext. 4362
1300 hundred miles ... unless you have spent a large portion of those miles on a road course or doing smoky burnouts just put a new tire on
Old 07-20-2009, 04:28 PM   #9
tacomaprime
Member#: 70572
2005 Tacoma
lol, nope, most, if not all of those miles have been on a smooth highway type road.
Old 07-23-2009, 08:20 PM   #10
Jeff Johnston
Member#: 66604
'05 WRX STi
Crystal Gray
Why does the left front get the most wear? For that matter, which gets the least?
Jeff Johnston is offline   Reply With Quote
Old 07-24-2009, 08:30 AM   #11
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
right turns at intersections tend to be sharper than left turns. Cloverleaf interchanges tend to be all right turns. There aren't many analogous situations which would wear the right tire to match in the US.
sniper1rfa is offline   Reply With Quote
Old 07-24-2009, 12:13 PM   #12
Web Foot STi
Member#: 39086
2004 STi
My favorite freeway on ramp is a right hand 190 degree turn. Posted at 15 mph...
Old 07-24-2009, 02:41 PM   #13
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTORŪ
yea.. youll be fine.
AlxSti is offline   Reply With Quote
i hear a noise like shaking nails in a coffee can Richbmxer87 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-21-2010 04:36 PM
FS: STI springs 1300 miles on them EPME Suspension/Brakes/Handling 2 03-12-2009 09:23 PM
Nails in both rear tires, can I just replace the axle set? Acejam2k Tire & Wheel 5 06-22-2008 03:42 PM
i got a nail in my sidewall, do i need four new pirellis? bigjosh2004wrx Tri-State Area Forum 9 12-19-2004 09:33 PM
Idiot redlined my brand new WRX with 1300 miles on it rally_wannabe Newbies & FAQs 16 04-25-2002 10:17 PM
