Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 07-19-2009, 02:06 PM   #1
Defiant Autospeed
Vendor
Vendor Sales Rating: (29)
Member#: 155450
2007 FXT
Default Handing and Braking sale! Whiteline suspension packages! Brake packages and more!
The key to a well rounded performance car is to pay attention to every aspect of performance. All too often people go through a long list of power upgrades and neglect the handling and stopping power of their car, greatly reducing the overall driving experience.
Subarus already handle nicely, but they can be so much better, the performance gains from suspension and brake work are nothing short of astounding.
We are here to help with your handling and braking needs. We carry a full lineup of suspension and brake upgrades to suit any budget, if you want a dramatic improvement, or just looking to "tighten up", we have the knowledge and parts to send you on the right path.
What brands do we carry?
Whiteline
Cobb
Tein
Eibach
Perrin
Hotchkis
Cusco
GTSPEC
And more.
Packages? We got em
This thread's featured suspension brand is
This package is really a "first step" aimed at making the largest improvement possible, on the tightest budget possible
It Features
Whiteline 24mm non adjustable front swaybar
Whiteline 22mm non adjustable rear swaybar
You may ask, but why is the front bar larger? Despite what many think, Subarus tend to respond well to a front end bias on the swaybars. While these are not adjustable, its a combination that has proven itself time and time again to offer amazing performance on a very tight budget. If you are still worried, we can do the 22mm non adjustable swaybar instead. This also works very well.
Want a bit more adjustability? Pick up a set of adjustable swaybars, in sizes ranging from the monster 27mm, all the way down to the 22mm.
Want a bit more? To make the swaybar upgrade more complete?
Add a set up whiteline heavy duty alloy end links
to the swaybars. Ensuring the most direct connection to the chassis for superior response.
There is so much you can add to these packages, Add Strut braces from Whiteline, Cusco, Perrin, Tein and GTSPEC to stiffen the chassis up to get the most from your upgraded suspension by enabling it to deal with the added loads a little better.
And there is the one small mod. The one tiny thing that makes a suprisingly large improvement.
The Whiteline rear subframe locking bolt kit
This simple little mod takes as little as 20 min to install (some cars require a little more playing around to get them in, all in all its a rather simple to install mod) but makes a large improvement by locking the rear subframe in place. By doing this you keep the rear suspension centered where it belongs, preventing those tiny alignment changes mid corner. You will notice that the back end of the car feels more "connected". The added driver confidence will make you faster!
We carry a large range of chassis and suspension braces to really tighten your car up and get the most out of it.
Check out these sweet braces from GTSPEC
We have the ever popular front "H-Brace"
Front Fender reinforcements
These bolt from the door hinges to the front unibody behind the fenders. By eliminating the flex in that area, steering response is improved This is a mod that is gaining popularity and there is a reason for that.
Front lower tie brace
This replaces the stock jacking plate and and ties the front control arms together for a very rigid lower suspension assembly. A very effective and often overlooked mod.
Rear T-Braces
These bolt from the lower rear lateral links, bracing them to the chassis. This prevents any flex in the rear subframe due to the cornering forces at that connection.
3 Piece complete subframe brace kit.
This ties it all together, bracing all the way back to the middle of the chassis.
This replaces the stock front subframe, and made from aircraft aluminum, greatly improves chassis rigidity while shedding a full 13lbs off the nose of the car, improving the overall balance for even more gains in handling, acceleration and braking!
We offer lower chassis braces by Whiteline, Perrin and a lightweight front subframe by Carbing featuring 8 connection points for the ultimate in bracing as well. If you are looking for springs, We carry Tein H-tech and S-tech, Eibach Sportline and Prokit, Cobb, and Hotchkis. We carry Coilovers by Tein and Eibach.
WE CAN MAKE YOUR CAR HANDLE.
Defiant Autospeed is offline   Reply With Quote
Old 07-19-2009, 03:25 PM   #2
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
At some point, you have to stop. Or at least slow down. I know we would all love to drive around fast all day long, but at some point you are going to have to stop to eat or use the restroom
For this problem, I offer brake upgrades
I offer a full range of brake pads from
(Posi-quiet an oem quality pad which offers low dust and quiet performance for day to day driving)
For a day to day pad, you cannot beat the Hawk HPS pads. They are a low dusting pad to help keep your wheels clean, and they are known for being a quiet pad, while offering a very responsive brake pedal. These are an incredible autocross pad as well as for day to day driving.
For something a little more aggressive, the Hawk HP+ is another great option. These are a little dustier, about comperable to the OEM STI brembo pads in that aspect, but they can take a good bit more heat, for bite that resists fade. They also stop a lot harder. As with any aggressive pad, there is a bit more noise, and at times these can be somewhat loud. I daily drive on a set and although sometimes they do squeel loudly, they are typically pretty quiet. A lot more tame than people give them credit for in my opinion. A decent track day pad.
And featuring rotors by
(they are the same company now)
Old 07-19-2009, 03:30 PM   #3
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
We also carry stainless braided brake lines to help firm up that pedal.
We carry 3 brands to choose from
For a REALLY firm pedal we offer the Perrin Master Cylinder brace.
This stops the master cyl from being able to move around due to firewall flex, caused by the huge forces under hard braking.
To complete your upgrade, we offer Motul RBF600 brake fluid
Motul can explain this fluid to you better than I can, so lets look to them
Motul is 100% synthetic fluid for hydraulic-actuated brake and clutch systems. Motul is specifically designed to resist the high temperatures of actuated (steel or carbon) racing brakes and clutch systems. Motul RBF 600 offers Extreme thermal resistance and stability. Motul's RBF 600 has an elevated boiling point, 312 C / 593 F with factory brake lines, enabling effective braking even under the extreme conditions of competition. Motul RBF 600 is very efficient in wet conditions; the very high wet boiling point, 216 C / 420 F with factory brake lines, is superior to conventional brake fluids and provides a particularly efficient braking system in rain and retards the apparition of vapor lock.
What I can tell you is that this fluid, while a little more expensive, is far from a large investment, and unlike the other popular fluid, this has a temperature rating that is well suited for the heavier Subaru. If you are going to upgrade your fluid, then upgrade it with something that WORKS.
Please PM for special NASIOC pricing.
As always, We strive to bring you the highest quality parts available, for great prices.
With many years of direct Subaru Performance specific experience (some shops work on many vehicles, We eat, live, breath and sleep Subaru) we are here to offer advice and answer any questions you may have, customer or not. Do not hesitate to ask. If I cant answer your question, I will do my best to direct you to someone who can.
Old 10-09-2009, 02:34 AM   #4
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Bump for some corner carving goodness
Whiteline Suspension for '08+ STI and WRX coming!!! KW and RCE also in stock dalesalignment&brake VIC Vendor Classifieds 3 05-24-2009 12:19 AM
RCE Yellow, Black, and Wagon springs!!! Staged Suspension Pacakges!!! Brake sale!!! GTWORX.com Suspension/Brakes/Handling 32 08-06-2007 03:17 PM
Super summer suspension/brake sale! WHITELINE-CUSCO-PERRIN-COBB-HAWK-and many MORE!! P&L Motorsports Inc. Suspension/Brakes/Handling 27 06-29-2006 01:15 PM
Giant Endless and Zeal Sale!!! Whiteline, Tein and Much More!! Gruppe-S Suspension/Brakes/Handling 8 06-14-2006 08:35 PM
