#1 |
Member#: 124212
E. Canada
Vehicle:06 STI Built By Inn-Tune |
Finally got the car sorted out and had the car tuned at Innovative. Here is my mod list and my results.
Power mods: Engine Stock AEM Stand alone UR T3/04S .63AR modified to full BB and water cooled jacket. DW 850cc injectors Walbro pump Aquamist HFS-6 kit running 50/50 Perrin FMIC Full 3" exhaust Tail 38mm WG Tail BOV Here is my dyno graph run at 24psi and meth: ![]() Here are some more dyno's so you can compare. ![]() Here is one on another dyno with similar mods run number 009. ![]() Here is an STI with a built motor on the same dyno run at 25 psi, as you can see mine makes similar power. ![]()
#2 |
Member#: 133765
Vehicle:06 sti black |
isnt that a 60lb/min turbo? you made less then 400whp at 24psi? that seems realllly low
#3 | |
Member#: 124212
E. Canada
Dyno's are a tuning aid, 1/4 mile MPH is the true teller. |
#4 | |
Member#: 133765
#5 |
Member#: 124212
E. Canada
It's a mustang dyno and it reads very low. I can tell you from my car being dynoed at 415 Whp before this tune and the addition of meth and full stand alone that the car is a lot quicker and smoother.
The power is much more linear and there is no lag between my shifts like before. So going from a MAHA dyno and reading 415WHP to what I have now is just the dyno reading differently. The car definitely has more power, This is why I posted the different graphs. If you made almost 400whp on 7.5psi that is phenomenal and congrats on that. |
#6 | |
Member#: 133765
#7 |
Member#: 97785
NESIC
Vehicle:2005 WRX Stg 2 EFI Logics/CTSUBIE |
Yeh exactly, comparing a 6 cyl. higher compression motor to an STi is not apples to apples.
There is an 06 STi w/ 35R making under 400whp I believe on innovatives mustang dyno and running mid/low 11 second passes...to OP congrats on power! |
#8 |
Member#: 124212
E. Canada
#9 |
Member#: 95670
NESIC
Vehicle:06 STG 4 wrb STI EFI LOGICS TUNED! RIP CSK |
i have basically the same setup minus the bb/water cooled, ill post numbers when i get tuned to compare (mustang dyno as well) i think alot of people forget that a dyno is just a tool, congrats on the power
#10 |
Member#: 124212
E. Canada
#11 |
Member#: 95670
NESIC
#12 |
Member#: 133765
#13 |
Member#: 124212
E. Canada
#14 |
Member#: 97785
NESIC
Any updated pics of your engine bay?
#15 |
Member#: 133765
i did read... youre saying its a mustang dyno which is low reading but almost 100whp lower then where it should be around. im sorry youre getting your feelings hurt because i made an observation. go take it to the track and post a trap speed. and if its a good trap showing you make good power then that dyno is veryyyy low reading. i made 300whp 350wtq on a mustang dyno with vf39 tbe large tmic cai and meth at 24psi. im not trying to offend you so i dont see the need for the way youre acting. if youre happy with the car thats all that matters
#16 |
Member#: 95840
NWIC
Vehicle:sold to a good bud awaiting next car |
Congrats on the power.
Question.....why did you modify that turbo for BB? Any reason you just didn't step up to a 35r at that point? One would think with the modification you performed, you are now in the cost range of a 35r, with the lower power of a 60lb turbo? just asking... |
#17 |
Member#: 9960
Vehicle:2002 Impreza WRX WRBlue Perl |
Congrats on the new found power. Mike is an excellent tuner to deal with!
From what I have seen so far, Innovative's dyno isn't just a heartbreaker.. it is a heart crusher, especially for those used to seeing Dynojet numbers. The only other dyno I have read about that might be equally as stingy would be Buschur's dyno. The numbers it puts out seem more in line with what our Australian members are used to seeing on the dyno, and not so much the higher numbers that we are used to seeing over here. At the end of the day however, these are just numbers, as evident by the trap speeds that the other beautifully modified silver STi tuned by Mike puts up at the drag strip. I think the owner of that car is a member here also. While the dyno numbers are low, the real world trap speeds are crazy high, which I would prefer any day of the week. |
#18 |
Member#: 141952
Vehicle:03 emo 8/2011 wrx |
#19 |
Member#: 95670
NESIC
Little to late for that it's already in my car just waiting to weld bov
I picked up this kit for nothing just sold my green setup so I dont think ill be unhappy |
#20 |
Member#: 68647
Vehicle:07 STI Rotated 35R Jorge Tuned |
#21 |
Member#: 133765
#22 |
Member#: 124212
E. Canada
I had an issue with the turbo last summer and had to send it back to Precision to be repaired for the 2nd time. They upgraded me for half the cost due the issues so I jumped on it. This is now a 35R with 70lbs/ min wheel .63 AR.
#23 |
Member#: 132244
NWIC
Vehicle:2006 OBP WRX 2006 BMW 325i |
Congrats
#24 | |
Member#: 68647
#25 |
Member#: 133765
wow man youre my hero... i didnt compare them if you read but i guess thats a little past you since youre all knowing. i compared my vf 39 on the same dyno to his. i build and tune all of my cars myself... and im sure you pay for both on yours
| Thread Tools | |
| Display Modes | |
| Ur T3/04s | moreboost | Factory 2.5L Turbo Powertrain | 91 | 11-29-2007 08:19 AM |
| FS: 2005 Aspen White Subaru WRX STi! UR T3/T04S Rotated kit. Engine Logics tuned! | anthongy817 | Private Vehicle 'For Sale' Classifieds | 33 | 10-19-2007 09:51 AM |
| UR T3/04S tuned | moreboost | Proven Power Bragging | 24 | 05-13-2007 04:48 PM |
| FS: 2005 Aspen White Subaru WRX STi! UR T3/T04S Rotated kit. Engine Logics tuned! | anthongy817 | TXIC Private Classifieds | 31 | 10-25-2006 11:56 PM |
| Do 06 sti tails fit 04s? | Midnightsilence | Newbies & FAQs | 14 | 06-25-2006 04:10 AM |
