Old 07-20-2009, 01:06 PM   #1
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Default Anything wrong with this Log?
Hey guys i just logged my car after installing a FMIC. I am just learning what all of thez numbers mean, i mean i know what they are but don't know if the numbers are in the right range, so if anybody can take a look at them any input would be great.
3rd and 4th pull
4th gear pull
P.S. I also have a cel code saying the my rear o2 is not wotking right, by the V what can you guys see about that?
MODS
Blitz BOV
Light flywheel
FMIC
catless TBE
uppipe
EBCS
Inlet
Short Ram
255 Fuel pump
Might be missing something but they are the mag once.
BlackFighter is offline   Reply With Quote
Old 07-20-2009, 01:22 PM   #2
Badler
Member#: 133597
Loks like it is spooling REAL slow. This on a vf39? IDCs don't look good but I am NO EXPERT, not even close. Time for a tune.
Badler is offline   Reply With Quote
Old 07-20-2009, 01:26 PM   #3
BlackFighter
Member#: 193940
2004 WRX STI Black
Yes a stock vf39
Old 07-20-2009, 01:42 PM   #4
wrxchitown
Member#: 185520
2011 335i
you need bigger injectors. 114% IDC is just plain crazy. do you have a wide band? if not I wouldnt recomend doing any more pulls till you get it tuned. If you do keep a close eye on it to make sure you dont lean out. Oh yeah GET BIGGER INJECTORS..
wrxchitown is offline   Reply With Quote
Old 07-20-2009, 01:45 PM   #5
MIKE DD
Member#: 106818
2003 Truck
Is this on a stock map? And yah your IDC is outta control, get some injectors and a tune ASAP.
MIKE DD is offline   Reply With Quote
Old 07-20-2009, 01:54 PM   #6
STIBungy
Member#: 51684
I assume this is on your 04 STI? With the rear O2 sensor out of commission, the car will run 1 full point richer. The stock fuel map is pretty rich from midrange to redline. Fix your rear O2 and get it tuned and you should be good. With the stock turbo, you shouldnt need to upgrade the injectors. You are running pump gas, right?
STIBungy is offline   Reply With Quote
Old 07-20-2009, 02:04 PM   #7
BlackFighter
Member#: 193940
2004 WRX STI Black
Ya pump gas on a 04 sti, stock map no tune, getting one tomorrow. No need for new inj but what is wrong with them. I just had my rear o2 fixed, it is in my catless healix dp in a homemade cel fix, This one
http://forums.nasioc.com/forums/show...wnpipe+cel+fix
The shop tha checked the code and it said that it is not working a 100% or soo. Low gas analysis or somethign like that.
And when we put on my stock downpipe with/out the cel fix it read like new 100% working
Old 07-21-2009, 09:23 AM   #8
BlackFighter
Member#: 193940
2004 WRX STI Black
Any more input? Had to change my tune date due to rain and humidity :-(
Old 07-21-2009, 09:35 AM   #9
MasterKwan
Member#: 98961
2003 WRX
You should pull a "Learning View" and see where the ECU's pulling timing. It's available on RomRaider's site.
Old 07-21-2009, 09:38 AM   #10
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
wow 114 inj duty cycle???? should be around 80% from what my tuner said. that needs to be adressed asap!
spool is also super slow. get tuned and ur tuner should be able to back off your idc's . fwiw my idc's on a vf48 are around 79%
06-wrx-tr is offline   Reply With Quote
Old 07-21-2009, 09:56 AM   #11
BlackFighter
Member#: 193940
2004 WRX STI Black
can' find the Learning View on their site
Old 07-21-2009, 09:59 AM   #12
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
google "learning view" it will be close to the top.
Old 07-21-2009, 10:07 AM   #13
BlackFighter
Member#: 193940
2004 WRX STI Black
cool thanks
Old 07-21-2009, 01:37 PM   #14
ramair18954
Member#: 28308
03 td-06 wrx ra-c
Platinum
wow, didnt know it was this bad paul, yeah should have kept those 850's and gotten a protune.
ramair18954 is offline   Reply With Quote
Old 07-21-2009, 01:53 PM   #15
BlackFighter
Member#: 193940
2004 WRX STI Black
I still have them new in a box in my room, just waiting for a 20g. And if it wasn't for the rain today i would have had my road tune today after work. :-(
Old 07-21-2009, 05:07 PM   #16
ramair18954
Member#: 28308
03 td-06 wrx ra-c
Platinum
thats ok, you can ride around ghetto for a bit.
Old 07-22-2009, 10:53 AM   #17
BlackFighter
Member#: 193940
2004 WRX STI Black
ni pizdi csoma. :-)
Old 07-22-2009, 12:19 PM   #18
torinalth
Member#: 141720
2005 LGT 5MT Sedan
Satin White
if you do another pull do me a favor and log knock sum as well... i'm curious to see if the inconsistancy on the knock correction advance is due to actual knock, or its setup that way.
and yes IDC is way high. drop in the new injectors and scale them to match (or just get tuned) but also scale the MAF, since you have a new intake.... stock intake is kinda hit and miss anyhow on its scaling. the new injectors will allow for more power and safer... but of course only when getting tuned....
T
torinalth is offline   Reply With Quote
Old 07-22-2009, 01:10 PM   #19
BlackFighter
Member#: 193940
2004 WRX STI Black
my question is how can inj work more then their 100%? And my tuner said no need for bigger inj untill i upgrae my turbo. And had to give away the laptop that i used for the log. If i get my friends laptop for another pull before my tune then i'll do it. Felix if you are reading this can i barrow your laptop :-)
Old 07-22-2009, 04:43 PM   #20
torinalth
Member#: 141720
2005 LGT 5MT Sedan
Satin White
how you can get above 100% is beyond me, never ran into that, so someone else will need to chime in. as far as not needing injectors till a new turbo is done, that is a matter of opinion. the stock STI turbo can and will max out the injectors that come stock... hell, you are proof of that. the injectors were not installed with the idea of maxing out the turbo, just to support the needed power with extra safety room. many people run larger injectors to get more boost (because with a MBC and EWG you can get more out of it when tuned)
T
Old 07-24-2009, 03:03 PM   #21
BlackFighter
Member#: 193940
2004 WRX STI Black
Well getting a tune today and will post a log after the tune to compair. If it doesn't ****ing rain today again. I have been trying to get this road tune for months now.
Old 07-24-2009, 03:34 PM   #22
EMS
Member#: 14116
Why all those reactions on the knock sum, etc.??? Did you ever map a car? BlackFighter is logging knock correction, there are no big jumps in it, so his engine is NOT knocking!
EMS is offline   Reply With Quote
Whats wrong with this log? (Tari DL1) Drews_WRX Engine Management & Tuning 7 08-13-2005 10:33 AM
Do you see anything wrong with this course? TheRex Off-Topic 40 12-29-2004 07:59 AM
Anything wrong with this pic? camshaftprelube Off-Topic 26 02-20-2004 07:20 AM
Anybody see anything wrong with this pic? ProjectWRX Off-Topic 23 01-02-2004 12:45 PM
Does anyone see anything wrong with this? CheeseRcket_ Off-Topic 11 07-25-2003 12:58 AM
