Welcome to the North American Subaru Impreza Owners Club Monday October 5, 2015
Old 04-30-2002, 06:22 PM   #1
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Default exhaust volume: low vs high
which is louder? a low tone or a high tone? or it doesn't matter?
FuJi K is offline   Reply With Quote
Old 04-30-2002, 06:56 PM   #2
Member#: 4263
They are equal to each other, Fuji K. An 85db low tone is equal to an 85db high tone. Increase the volume by 15db for each, they are still the same volume. You will feel the low tone more and it will have a lower resonance, like a V8 engine. Where as the high tone will sound more annoying and make you want to cover your ears; such as a 1.8litre 4-cylinder engine.
*I'm not a scientist, doctor, or and engineer*
Skylab is offline   Reply With Quote
Old 04-30-2002, 07:38 PM   #3
Member#: 14909
Yeah, totally go with low tone! You don't want to sound like a Honda with an Oriental Rage / Cambel's soup can muffler on it. The Subaru boxer four has a great growling rumble to it... stick w/ a low pitch muffler. Check out www.northursalia.com 's download section where you can listen to a couple different exhaust sound files...
JSiwek is offline   Reply With Quote
Low Compression/High Boost vs High Compression/Low Boost? JoeTX Newbies & FAQs 31 05-18-2006 04:06 PM
High Comp vs High Boost zoomfactor Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 10-21-2004 11:46 AM
Low RPMs + High Gear + High Boost = Detonation? Hagwag02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 08-25-2004 07:46 PM
VOLUME: Scoobysport VS. Borla AdmireWantWillLove Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-11-2003 01:13 AM
What to do? High Compression, Low Boost or Low Compression, High Boost. FlooredSubaru Normally Aspirated with bolt-on Forced Induction Powertrain 6 01-29-2003 10:55 AM
