Old 04-30-2002, 06:32 PM   #1
racerwad
Member#: 2564
Question wastegate control questions for TT
ok, so i was wondering if any of the standalone ECU's have the ability to control two wastegates? i contacted AMR and they said that while the link does not have this ability, it should be possible to have one solenoid control two wastegates. this sounds like a good idea to me. does anyone know if this could work? for all intents and purposes, it should work. can anyone think of why it wouldn't? thanks.
andy
racerwad is offline   Reply With Quote
Old 04-30-2002, 06:38 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
In theory, when I had the TT setup on my RS, Shiv and I figured that the TEC-II could control both of the wastegates. We never did get a chance to play with it....
kastle is offline   Reply With Quote
Old 04-30-2002, 06:55 PM   #3
SubbyRS
Member#: 17193
1991 Legacy RS
I presume you're talking parallel turbos (like Skyline GT-R) & not sequential (like Legacy TT or Mazda RX-7)??
I could imagine one solenoid controlling 2 wastegates in parallel, but it'd be trickier getting 2 sequential wastegates controlled....
SubbyRS is offline   Reply With Quote
Old 04-30-2002, 07:11 PM   #4
racerwad
Member#: 2564
Default ought to work, right?
kastle-
you're the one person i was hoping could response. i know that you were never really able to get the car running the way you would've liked; however, could you clarify how your wastegates were controlled? were they both controlled by the same solenoid? also, once you have a twin TB setup, will the TEC-II(or III) be able to control two TPS sensors?
subbyrs-
the turbos are definately in parallel. i couldn't even imagine the hassle of trying to home engineer a sequential setup!
Old 04-30-2002, 07:28 PM   #5
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
They were being controlled by the internal wastegate settings... So, at that time, we weren't using the boost solenoid at that time. The plan was to use the TEC-II to control it over the wastegate settings, since we didn't think we could install 2 Tial's due to space contraints.
Also, it's not a great idea to have the solenoid (GPO settings) control all the boost (no wastegate spring) since it makes a lot of noise (according to Shiv) when activated (ie, more activity = more noise).
I won't be doing anything further with the TT setup since I have given it back to Robert to allow him to further tweak the prototype and get it into production. I didn't give that much though (twin TPS's), but that's a really good question.
Old 04-30-2002, 07:42 PM   #6
racerwad
Member#: 2564
the two TB with the doubling of all the associated hardware and software was the main reason i was skeptical of the dual TB idea. if it were possible to do the engineering properly (and by no means do i think FAT isn't able!) then the dual TB solution would be a fairly elegant one. i don't think it's really going to work though at controlling the turbos from overboosting one another. i think what the setup needs is either a larger intercooler or some sort of plenum that can be pressurized before the charge reaches the TB. that way the pressure differentials can be equalized (if not completely, then to a greater extent) by the volume of a larger intercooler or plenum. you'd lose some boost, but gain a TT.
i for one am willing to deal with the increased noise of a solenoid controlled wastegate versus depending on the vagrancies of individual springs on each wastegate to control overboost. just my .02 cents.
andy
Do you have an electric exhaust controller? - question for you. bugeyes Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 12-07-2005 10:56 AM
Do you have a electric exhaust controller? - Question for you. bugeyes Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-06-2005 09:30 PM
Climate Control question for '05 GT Endlesshine Legacy Forum 5 11-09-2004 12:13 AM
Launch control questions for the experts... Brian Broz Engine Management & Tuning 2 07-06-2003 02:54 PM
Climate control question for 93 Legacy. Dealer Xing Legacy Forum 6 03-22-2002 08:57 PM
