Old 07-20-2009, 08:41 PM   #1
PelvaanAli
Member#: 190157
2003 WRX
Default Help Replacing Ac
HOW DO YOU GET THESE BOLTS OUT ?
PelvaanAli is offline   Reply With Quote
Old 07-21-2009, 05:53 PM   #2
rick-l
Member#: 33868
2003 wrx
srp
1) Perform the compressor oil return operation.
<Ref. to AC-21, OPERATION, Compressor Oil.>
2) Turn A/C switch OFF and stop the engine.
3) Using refrigerant recovery system, discharge refrigerant.
<Ref. to AC-16, OPERATION, Refrigerant
Recovery Procedure.>
4) Disconnect the ground terminal from battery.
5) Remove the V-belt. <Ref. to ME(S0HC)-43, REMOVAL,
V-belt.> or <Ref. to ME(D0HC TURBO)-
44, REMOVAL, V-belt.>
6) Remove the generator. <Ref. to SC-13, REMOVAL,
Generator .>
7) Remove the low-pressure hose and high-pressure
hose.
8) Disconnect the compressor harness from body
harness.
9) Loosen the bolts to remove compressor bracket.
10) Remove the bolts and then separate compressor
and bracket.
rick-l is offline   Reply With Quote
02 Buyeyes replace AC compressor & Alternator bon1210 Service & Maintenance 6 08-28-2012 05:39 PM
Replacing ac compressor? jpbpro Service & Maintenance 8 09-09-2010 06:20 PM
Replacing AC Line jester696 Service & Maintenance 1 06-09-2008 03:37 AM
Replaced AC lines-how crucial is it that the AC Drier be replaced on WRXs ScoobyNubieToo! Service & Maintenance 4 05-27-2008 07:57 PM
How to replace AC pulley bearing? ilmaestro Service & Maintenance 3 09-09-2004 02:19 PM
