Old 08-01-2009, 10:39 AM   #1
rewindnottm
Member#: 116621
2006 WRX EU spec
Default issues 1.42 ECUflash
I cant get the new version of ECUflash 1.42 to work, i have tried it with both 16bit and 32bit ECU's and on ECU's i have ECU's before.
the connector block is on and the green connectors are together too
can someone help.. thank you
details below
[14:56:55.406] EcuFlash Version 1.42.2595
[14:56:55.406] OS Version Windows XP
[14:56:55.406] Qt Version 4.5.0
[14:56:55.421] 56 memory models read.
[14:56:55.421] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[14:57:01.203] 343 ROM metadata models scanned.
[14:57:01.203] checksum module "subarudbw" loaded.
[14:57:01.203] checksum module "mitsucan" loaded.
[14:57:01.203] flashing tool "wrx02" loaded.
[14:57:01.203] flashing tool "wrx04" loaded.
[14:57:01.203] flashing tool "sti04" loaded.
[14:57:01.203] flashing tool "sti05" loaded.
[14:57:01.203] flashing tool "mitsukernel" loaded.
[14:57:01.203] flashing tool "mitsukernelocp" loaded.
[14:57:01.203] flashing tool "mitsubootloader" loaded.
[14:57:01.203] flashing tool "shbootmode" loaded.
[14:57:01.343] flashing tool "shaudmode" loaded.
[14:57:01.343] flashing tool "subarucan" loaded.
[14:57:01.343] flashing tool "mitsucan" loaded.
[14:57:10.171] J2534 API Version: 04.04
[14:57:10.171] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[14:57:10.171] Device Firmware Version: 1.07.2597
[14:57:17.203] denso02_bootloader_cmd_start
[14:57:18.468] denso02_bootloader_cmd_start
[14:57:19.750] denso02_bootloader_cmd_start
[14:57:21.031] denso02_bootloader_cmd_start
[14:57:22.312] denso02_bootloader_cmd_start
[14:57:22.734] kernel get version
[14:57:23.046] interface close
[14:57:23.062] interface close
[14:57:45.500] J2534 API Version: 04.04
[14:57:45.500] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[14:57:45.500] Device Firmware Version: 1.07.2597
[14:57:49.468] denso02_bootloader_cmd_start
[14:57:50.750] denso02_bootloader_cmd_start
[14:57:52.031] denso02_bootloader_cmd_start
[14:57:53.312] denso02_bootloader_cmd_start
[14:57:54.593] denso02_bootloader_cmd_start
[14:57:55.015] kernel get version
[14:57:55.343] interface close
[14:57:55.359] interface close
rewindnottm is offline   Reply With Quote
Old 08-01-2009, 07:14 PM   #2
quazimoto
Member#: 70395
Are you using the 2.0 or the 1.3? And if you had an earlier version of Ecuflash on did you do a clean install? I just upgraded to 1.42 and have no problems with the 1.3 cable.
Old 08-01-2009, 08:53 PM   #3
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Looks like he's using the 2.0 cable.
I dunno what the deal is, but try uninstalling and then use 'run as administrator' when you reinstall.
^ Generic response to EcuFlash issues. It has been known to help.
Old 08-02-2009, 04:02 AM   #4
rewindnottm
Member#: 116621
2006 WRX EU spec
Thanks guys I'll give it a try and report back
Possible Tranny issue, grinding with no load battlewaggin Transmission (AT/MT) & Driveline 3 06-06-2010 01:02 AM
Ecu Flash 1.42 Question Subyroo2.5 Normally Aspirated Powertrain 2 01-17-2010 10:25 PM
WTB-Subiesport Magazines Issues 1-4 02_WRX_OK Private 'Wanted' Classifieds 5 01-26-2009 03:45 PM
WTB: Subiesport issues 1 and 2 subbywerks Grassroots Motorsports Magazine Forum 9 02-05-2007 02:31 PM
WTB: Subiesport issues 1 and 2 subbywerks Private 'Wanted' Classifieds 3 02-03-2007 11:30 PM
