Old 07-21-2009, 01:53 PM   #1
KnightRiderWRX
Member#: 151042
2004 WRX IMPREZA
Default Need new clutch, please HELP!
Hello there, I have no idea what the stage thing means but I'm making about 250 crank HP and my ACT sports clutch is going out, could you please advice me to a better clutch because this one didn't seem to last long about 30k miles I don't know if that's normal or not. I looked at a stock replacement exedy clutch but I don't know if it'll last long with as much power as I have. I also looked at a stage one F1 racing clutch and a stage one XTD clutch, umm so if any of you nice folks had any good expeciences with any of those your input will help me greatly thanks!
KnightRiderWRX is offline   Reply With Quote
Old 07-21-2009, 03:28 PM   #2
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
250 crank is probably 200-210awhp which the OEM exedy will handle with ease. Should last well over 60-70k miles unless you are driving it hard with lots of launches with a lot of riding until fully engaged and hard shifting and riding the clutch between gears.
09rexwagon is offline   Reply With Quote
Old 07-21-2009, 03:38 PM   #3
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
At that power level on an otherwise unmodified trans... Stick with a stock replacement as more agressive clutches are capable of putting a lot of added shock load on the gears without any real advantage. Engagement will be smoother, the car will be easier to drive, it'll have no problem holding that power level and you will be less likely to blow gear teeth all over the pavement... Everybody wins.
jhargis is offline   Reply With Quote
Old 07-21-2009, 04:04 PM   #4
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
I'd also stick with OEM.
Normally I recommend the ACT Stage 1 as a standard stock replacement. I think it's one of the better feeling clutches on the market, and it doesn't put your stock transmission in TOO great of danger.
Phil
Andrewtech Automotive
AndrewtechAutomotive is offline   Reply With Quote
I need new shocks. Please help. rockclimber Newbies & FAQs 4 07-06-2009 03:14 PM
Problems with new clutch. Please Help!! auto-f Newbies & FAQs 12 01-04-2008 10:09 PM
Need new rim please help... DRKRYD Private 'Wanted' Classifieds 4 09-03-2006 11:18 PM
Need New Motor! Please Help! wrx02smokeu Southern California Impreza Club Forum -- SCIC 25 04-25-2004 04:25 AM
