Old 07-21-2009, 02:45 PM   #1
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Default ZR1 goes [email protected] with simple bolt ons!
This car is a beast and has a bottom end built like a tank, this is with only a few bolt ons, can't wait to see someone upgrade the blower or even the exhaust/heads/cam on one of these things. With only a pulley, air filter, ported throttle body, intercooler upgrade and slicks almost runs a 9!!!!
http://www.youtube.com/watch?v=9jlo_...layer_embedded
Stock LS9 cylinder heads & short block
Stock LS9 exhaust manifolds and cat back exhaust system
- LPE 8.5” diameter harmonic balancer – 11 rib
- LPE 2.60” diameter supercharger pulley – 11 rib
- Lingenfelter S&B air filter
- 4” diameter air intake tube with mass air sensor
- Ported stock throttle body
- Intercooler supercharger inlet modifications
- Double capacity intercooler heat exchanger
- Larger capacity intercooler reservoir system
- Mickey Thompson ET Street Radials P345/35R18 rear
- M&H Racemaster P185/50R18 front
- CCW Aluminum wheels
translation...
air filter, pulley, balancer, inlet, throttle body, wheels, and intercooler.
Humid 80 F degree Indiana weather at 932 ft altitude
C J is offline   Reply With Quote
Old 07-21-2009, 02:47 PM   #2
Illusive
Member#: 90436
2005 STI
Obsidian black pearl
There's no replacement for displacement.
Illusive is offline   Reply With Quote
Old 07-21-2009, 02:53 PM   #3
Clark_Kent
Member#: 114299
This is the second thread I've seen in the last two days that I've seen a thread that boasts "minimal modifications". The term minimal is being tossed around ambiguously. Minimal mods is like an air filter and a downpipe not 10 modifications to the vehicle. Fast car nonetheless.
Clark_Kent is offline   Reply With Quote
Old 07-21-2009, 02:53 PM   #4
thepigsti
Member#: 166215
That torque curve looks like it would liquefy your internal organs between 1500 and 2000 RPM. God help us all.
thepigsti is offline   Reply With Quote
Old 07-21-2009, 02:54 PM   #5
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Amazing... That motor just has grunt everywhere... torque curve is beginning to look like an electric motor's torque curve..
jigga is offline   Reply With Quote
Old 07-21-2009, 02:59 PM   #6
Hites
Member#: 138997
0000 Nothing
Minimal my ass. You can't even daily drive that thing now. It's been turned into a drag car. Look at the tires!
Hites is offline   Reply With Quote
Old 07-21-2009, 02:59 PM   #7
dmross
Member#: 2818
2000 2.5RS
I dunno, it tapers off pretty bad after 5000rpm, almost 100ft/lb by redline...
dmross is offline   Reply With Quote
Old 07-21-2009, 03:01 PM   #8
Kilya
Member#: 80496
lol the HP curve doesnt taper at all lol
Kilya is offline   Reply With Quote
Old 07-21-2009, 03:02 PM   #9
C J
Member#: 132587
2006 JrTuned STi
[email protected]
This car has a bolt on pulley, swapped air filter, bolt on intercooler, bolted on ported throttle body, and bolted on wheels/tires. The mod list only looks long b/c they include EVERYTHING with no vague statements like "turbo modification" used in the GTR thread.
If that isn't minimal I don't know what is, changing a downpipe is a hell of a lot more work than any of those modifications.
Old 07-21-2009, 03:05 PM   #10
C J
Member#: 132587
2006 JrTuned STi
[email protected]
People switch between track tires and street tires all the time, no difference.
Old 07-21-2009, 03:05 PM   #11
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
hardly minimal. But ****ing sick!
700 ft/lbs by 3k is nuts, just nuts!!!!
godforbid67 is offline   Reply With Quote
Old 07-21-2009, 03:10 PM   #12
Clark_Kent
Member#: 114299
Rinse the sand from your crotch and lower your mini-skirt. Its not a "stab", its a point blank statement. I don't care what you say...that isn't "minimal". I also don't care how "simple" these mods are. The fact remains there are quite a few. And besides...is this your car? Of course not, its someone else's car that you stumbled across while whoring it up on Youtube. I'm not sure why you're so up in arms over a car that's not even yours.
Old 07-21-2009, 03:11 PM   #13
PPhilthy
Member#: 102948
2006 STI
Compared to the GTR 'minimal mods' thread - this is TRULY minimal mods!
pulley upgrade, air intake, intercooler and tuning = GTR Killer! lol
PPhilthy is offline   Reply With Quote
Old 07-21-2009, 03:14 PM   #14
C J
Member#: 132587
2006 JrTuned STi
[email protected]
The point is that all the parts are simple bolt ons and it is completely badass. You don't even have to put the car on a lift, this could be down without jacking the car up or even laying the ground.
Old 07-21-2009, 03:14 PM   #15
thepigsti
Member#: 166215
Why is everyone getting all butthurt over the appropriate use of the word "minimal" when referring to car modifications? Hell, neither of the posts in question are even about Subarus, get over it.
Old 07-21-2009, 03:14 PM   #16
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Exactly my point.
Old 07-21-2009, 03:16 PM   #17
jutes85
Member#: 127232
E92 M3
98' Foz
That is one long-ass first gear.
jutes85 is offline   Reply With Quote
Old 07-21-2009, 03:16 PM   #18
capaWRX
Member#: 37768
MY12 wrx ltd
98 2.0rs (sold!)
- LPE 8.5 diameter harmonic balancer 11 rib
- LPE 2.60 diameter supercharger pulley 11 rib
- 4 diameter air intake tube with mass air sensor
translation...
air filter, puller, balancer, inlet, throttle body, wheels, and intercooler.
I, for one, would definitely consider these mods minimal... Especially with the power it's now making.
I would also consider a stage 2 wrx minimal... The labor to install the turboback, filter, and tune is probably the same if not a shorter length of time for the zr1's mods.
Lingenfelter ftmfw
capaWRX is offline   Reply With Quote
Old 07-21-2009, 03:17 PM   #19
whontime
Member#: 77338
2005 STi
I would say that the mods are pretty minimal as far as LSX stuff goes. As far as driving it goes, I don't think it would be an issue to drive it most anywhere. Heck, I drove a 72 Nova on slicks with a fuel cell, no interior other than a race seat and a ratchet shifter back and forth to the drag strip for over two years.
whontime is offline   Reply With Quote
Old 07-21-2009, 03:22 PM   #20
GeneralTJI
Member#: 152680
Interesting......
One night I was running my car at Bandimere there was a new ZR1 running... now I'm wondering what the deal was because it was absolutely pathetic. Best ET was in the high 12's (spinning bad on launch), but even more shocking was he was only trapping in the 11-115 area and he made every shift from what I could tell. It didn't run anything like the car in this thread!
Those mods are not minimal, but regardless, that is an effing fast car!!!! with an effing huge price tag...
GeneralTJI is offline   Reply With Quote
Old 07-21-2009, 03:26 PM   #21
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Trapping 141.... holy Jesus.
**** me that's fast.
Audiosavvy is offline   Reply With Quote
Old 07-21-2009, 03:31 PM   #22
C J
Member#: 132587
2006 JrTuned STi
[email protected]
Originally Posted by GeneralTJI View Post
Interesting......
Lots of bad drivers out there, kind of like how stage 2 STi's only run high 12s or low 13s or worse
Old 07-21-2009, 03:36 PM   #23
GeneralTJI
Member#: 152680
Yea that has to obviously be most of the issue I agree.. between that an altitude I guess. Maybe he was going easy on it- kind of an expensive ride to drive into the wall ya know.
Old 07-21-2009, 03:45 PM   #24
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Because we're no longer talking about Subarus, and we're just mouthing off about different cars...if you truely want to go fast pick up a used Gallardo ($100k) and hook up with the guys at Underground Racing in NC. They offer a turbo kit which will get you in the mid 9's at 160+mph. Poops on the GTR and poops on this ZR1. WHAT?!
Steve.804 is offline   Reply With Quote
Old 07-21-2009, 03:47 PM   #25
GDB FAN
Member#: 105814
I literally LOL'd when I read this.
Must be a beast on the street.
GDB FAN is offline   Reply With Quote
