Old 07-21-2009, 06:03 PM   #1
gando327
Member#: 101942
03 Impreza WRX
Silver *wingless*
Default found torn boots under car.. how to fix? (pics)
So i was doing some work under the car and noticed that my passenger side steering rack boot (not the tie rod boot) is torn up and not sealed. Is there a way for me to fix this at home with a new boot or should i go to the dealer because it might be contaminated?
I have an 03 WRX sedan.
thanks guys.
gando327 is offline   Reply With Quote
Old 07-21-2009, 08:15 PM   #2
gando327
Member#: 101942
03 Impreza WRX
Silver *wingless*
bump any ideas? i dont want to have to replace the whole steering rack because its expensive, but if i have to i'll suck it up.
Old 07-21-2009, 09:40 PM   #3
silver2004impreza
Member#: 127878
2004 Impreza 2.5TS
2004 Outback sedan H6
I imagine that as long as the steering feels OK, you can probably get away with just replacing the boot. You're going to have to remove the outer tie rod end to get the old boot off and install the new one, so you're going to have to get the car aligned right after you replace the boot so you don't destroy your tires prematurely.
Also, if you manage to find a new boot, send me a PM, as I need one too and none of the local parts stores stocks them, and the dealer told me that they can't get me one.
silver2004impreza is offline   Reply With Quote
Old 07-21-2009, 09:45 PM   #4
MIKE DD
Member#: 106818
2003 Truck
Order off of subaru genuine parts, should be fine w/just replacing the boot. If it was the axle, I'd recommend a new axle and boot. You can do it yourself if you are patient and have the tools. I'm lazy so i took it to my mechanic, just easier w/a lift and air tools.
MIKE DD is offline   Reply With Quote
Old 07-21-2009, 10:10 PM   #5
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
if there's no evidence of leaking or scoring of the surface of the rack shaft I'd say you are good to just replace the boot
there should be a crimp-on metal band / clamp as well holding the boot on, make sure you order those too - you can see one here (ignore the other stuff)
depending on where you detach the tie rod you may not even need to align after - i.e. if you pop the outer rod end out of the knuckle instead of separating the inner/outer rods:
UkNuck is offline   Reply With Quote
Old 07-22-2009, 07:08 AM   #6
MIKE DD
Member#: 106818
2003 Truck
And if you detach the tierod make sure you mark how many turns you unscrew so you don't mess up your alignment. Just count the turns when you take it off and make sure you turn it the same amount when you put it back together.
Old 07-22-2009, 08:43 PM   #7
gando327
Member#: 101942
03 Impreza WRX
Silver *wingless*
thanks guys
Old 08-11-2009, 10:13 AM   #8
Layvon
Member#: 195711
STi 04/05/06/07
Man, I searched for this on the website for a while, and google found it no problem...lol.I have the same issue. Did this fix it for you gando?
Layvon is offline   Reply With Quote
Old 08-13-2009, 11:58 AM   #9
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
Originally Posted by UkNuck View Post
nice $200 tool
works so perfectly
AliBenn is offline   Reply With Quote
How to fix paint chip? krinksta Newbies & FAQs 2 06-04-2010 11:07 PM
Found my AC leak, help on how to fix it!!!! Ryandc Service & Maintenance 5 09-25-2006 09:41 AM
cv boot leak. how to fix ? JDM 3SGTE Brakes, Steering & Suspension 3 05-11-2006 04:42 PM
Anyone know how to fix my car? obyone Mid West Subaru Owners Club Forum -- MWSOC 11 11-17-2002 01:21 PM
yo, does anyone know of any classes that will teach u how to fix cars?? Keith Tri-State Area Forum 11 10-05-2001 09:28 PM
