Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 07-22-2009, 12:22 AM   #1
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Default TGV deletes, and then a boat load of fail. Please help make my car run nicely again.
My radiator developed a crack a few days ago so I figured I'd do the TGV delete mod while I was waiting for the new one. I thought everything went smoothly, but then I ran into problems when I tried to start the car.
At first, it wouldn't start at all. (I put the key to the on position a few times to prime the fuel system first) Well, it would fire, but then cut out immediately. I looked around and saw that the hose that went from the driver side rocker cover to the metal line that bolts into the intercooler was disconnected. I tried again, and it started up. The problem was that the idle was wandering from 500-3000 or so. Not only was the idle wandering, it was very rough too. This worried me so I shut it off and looked around some more. After a pretty thorough inspection, I decided to let it run for a while longer to see if the problem would remain after warming up. The idle wandered a bit less(went up to 2k rather than 3k), but it was still rough, almost like the sound of aggressive cams. The check engine light did not come on at any time.
My car isn't heavily modded. I have a 3" turbo back exhaust, STi top mount, XPT stage 2 map, and a few misc things that aren't relevant to this.
Here is a video of what is going on. This was taken after the car was a little warm. Notice the popping noises, wideband reading(22.4), and the rough/wandering idle. I did not touch the gas pedal in this video. This is also the first time it has stalled like that.
My thought is that it isn't getting enough fuel. That would explain the high a/f, and the stall. Other people have reported wandering idle after this mod so I'm not too concerned about that at the moment.
If anybody has an idea as to what the root of this could be, please let me know. I don't think I missed any connections, but it's certainly not an impossibility. Is it possible that the tune is at fault? I've been happy with my XPT map for a while now, but I'll contact a tuner tomorrow to get their take on it.
Thanks in advance.
573 is offline   Reply With Quote
Old 07-22-2009, 12:24 AM   #2
apexslider
Member#: 168101
15 BRZ Limited
SS
does your map support removing the TGV's?
apexslider is offline   Reply With Quote
Old 07-22-2009, 12:33 AM   #3
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Yes. I checked before I did the mod and all the codes pertaining to the TGVs have been disabled. The check engine light did not come on either. That being said, I do not think that the map was put together with TGV deletes in mind, as it is just an off the shelf stage 2 map.
Old 07-22-2009, 12:39 AM   #4
Prevent
Member#: 149114
this....
Prevent is offline   Reply With Quote
Old 07-22-2009, 12:41 AM   #5
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Originally Posted by Prevent View Post
this....
Lots of people have done this mod without changing their tune and have not had problems. Also, unabomber's FAQ thread states that besides deleting the CEL codes, additional tuning is not required for this mod. I'm not opposed to getting a professional tune, and I probably will in the near future. I'm just saying this because I think there is another problem.
Old 07-22-2009, 01:14 AM   #6
STIBungy
Member#: 51684
You have a leak somewhere in the intake manifold.
STIBungy is offline   Reply With Quote
Old 07-22-2009, 01:52 AM   #7
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
this....
put a sock in it.
Vac leak. You're pulling in air after the maf, so the ecu is only dumping enough fuel for part of the air, hence, crap idle.
Double check everything you touched post-maf, including all TGV/manifold bolts. Brake booster, purge valve, breathers, fuel pressure regulator, bpv hose, etc..
I once forgot the purge valve vac line (front center of intake manifold) and it produced the same results.
Merp is offline   Reply With Quote
Old 07-22-2009, 08:11 AM   #8
STIBungy
Member#: 51684
Yep. On mine, I forgot to connect the PCV line that goes to the fitting under the IM.
Old 07-22-2009, 03:30 PM   #9
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Thanks for the help. It was the PCV line under the manifold.
The car is running great now, and the idle stopped wandering.
Old 07-22-2009, 04:33 PM   #10
[D.I.]WRX
Member#: 116314
I was just about to say that....Same exact thing happened to my car. I just plugged it up so it wont happen again
[D.I.]WRX is offline   Reply With Quote
Old 07-22-2009, 05:31 PM   #11
WRX 2002
Member#: 11211
2004 STi
Rally Blue
Had the same problem myself...
WRX 2002 is offline   Reply With Quote
Old 04-03-2010, 11:15 AM   #12
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
OT but I like where you put your wideband meter.
snowflowmfg is offline   Reply With Quote
Uppipe making my car run like doodoo? RNBauer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-29-2008 09:34 AM
excedy clutch i think making my car run richer VAUGHNB19 Transmission (AT/MT) & Driveline 3 10-04-2006 08:54 PM
How an EM can make my car run smoother?? BBBsti LTD Engine Management & Tuning 2 07-05-2005 10:44 AM
Would a bad 02 sensor (P0037) make my car run bad? skimmilk68 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-04-2004 12:33 PM
mositure makes my car run bad...help!! MattJP Service & Maintenance 9 09-19-2003 10:12 AM
