Old 07-22-2009, 01:55 AM   #1
supernick77
Member#: 145122
1999 99 lgt, 86 brat
black, lt blue
Default what size and pitch is the banjo bolts on the td04 turbo.
i need to find what and where i can find bajo bolts that will fit the tdo4 for the coolent lines that bolt to it and what size and pitch. also what size and pitch is the on that bolts to the block for the oil feed line. thanx
supernick77 is offline   Reply With Quote
Old 07-22-2009, 01:26 PM   #2
penusai
Member#: 102808
1995 v8 EJ207 v7 6sp
30r swap in progress
penusai is offline   Reply With Quote
Old 07-22-2009, 02:01 PM   #3
supernick77
Member#: 145122
black, lt blue
1.25 for the pitch
Is the banjo bolt on the td04 the same size? Blakeat86 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-17-2009 11:35 PM
What size is the torque bolt on the injectors on an 05 STi? 1/500yellowwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 11-10-2006 03:40 PM
What size washers do I need for banjo bolts on brake caliper? thrdeye South East Region Forum 27 10-14-2005 01:15 AM
Oil feed line, what size banjo bolt for the block? CMJ Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-14-2005 09:42 PM
How do I remove the bottom bolt on the strut? whiterabbit Brakes, Steering & Suspension 15 06-28-2002 08:45 PM
