Old 07-22-2009, 08:53 AM   #1
Electric Mayhem
Member#: 173868
2003 WRX
Question Check Engine Reset Question
03 WRX
I had a gas cap code come up and was wondering if once fixed it would go away after several drive cycles or do I need to manually reset it by unhooking the battery and draining the power?
thanks
Electric Mayhem is offline   Reply With Quote
Old 07-22-2009, 10:14 AM   #2
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
Originally Posted by Electric Mayhem View Post
03 WRX
thanks
It should go away after 2-3 engine cycles (turn on, turn offs) assuming that the CEL signal is not getting resent during these cycles.
Resetting the ECU I don't think will clear a CEL. You can buy a cheap harbor freight OBDII scanner than can clear codes for you.
09rexwagon is offline   Reply With Quote
Old 07-22-2009, 11:33 AM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
If it was a leak code, after it runs the EVAP test twice with no issues it should turn off. EVAP monitor test is only done under certain driving conditions, ie steady highway speeds on flat ground for about 2 - 10 minutes.
If you are sure its fixed just unhook the battery for about 5 minutes.
Old 07-22-2009, 02:02 PM   #4
Electric Mayhem
Member#: 173868
2003 WRX
It came on when I had the cruise control on. I don't know why since I just had emissions done in June and it was ok. I'll put my cruise back on and see if that works. Maybe I didn't fix it yet.
1995 Legacy LSi - Check Engine/OBDII question DLausche Legacy Forum 2 02-07-2006 08:53 AM
Check engine light question.... just one blunt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-26-2004 08:04 PM
[B]Check Engine Light question regarding uppipe/downpipe[/B] Moshpit552 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-21-2004 02:36 AM
Check Engine/ Dealership Question BlueScoobyRex03 General Community 1 08-25-2003 12:35 PM
Check engine Light Question P1443 speedrkj Tri-State Area Forum 8 02-26-2003 07:39 PM
