Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 07-22-2009, 12:15 PM   #1
Slug71
Member#: 159963
2003 Subaru Baja
Black & Silver
Default Gas Light??
How low does the needle on the Fuel gauge go before the light comes on? I've had the tank down to just over 1.6 gallons of petrol left in the tank and still no light. Needle a ways below the 'E'. Also if i turn the ignition on, all the lights come on but the Fuel light. Is that normal?
The needle is about right on maybe just below 'E' now. Might just fill a Fuel container and do some driving an a little while.
Slug71 is offline   Reply With Quote
Old 07-22-2009, 01:33 PM   #2
Seahag1978
Member#: 79452
Mine comes on just above the "E".
I wouldn't recommend deliberately trying to run it out of gas. I know someone that ran out by accident and had a hefty injector cleaning/replacement repair bill.
Seahag1978 is offline   Reply With Quote
Old 07-22-2009, 03:03 PM   #3
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Same here - right at the E-line is when my light comes on. Typically I've found that it comes on somewhere between 3 and 2.5 gallons of gas left tho.
moonzie is offline   Reply With Quote
Old 07-22-2009, 05:33 PM   #4
steven765
Member#: 105920
2006 Baja 5 Speed
in theory it's supposed to come on at 2.6 gal according to the manual. I have the scanguage and it's usaully around that. For me it's just above the last white line. It stalls out at 16.1gal found that out the hard way now.
steven765 is offline   Reply With Quote
Old 07-22-2009, 10:38 PM   #5
kev m
Member#: 128582
2010 Impreza 2.5 Wgn
2011 Nissan Juke
I don't know that I've paid attention specifically to the E light, but the theory on most vehicles is that all warning lights are supposed to come on as a self-check (to make sure the bulb and circuit is working) anytime the key is turned from OFF to ON.
So I would think there is something wrong with the bulb/circuit.
kev m is offline   Reply With Quote
Old 07-23-2009, 12:46 AM   #6
Slug71
Member#: 159963
2003 Subaru Baja
Black & Silver
Well I went to work, came home and did did a bit of a detour and still no light and i haven't even run out of gas yet.
I almost definitely must be under a gallon of gas. In fact its probably literally got fumes left in there.
So im pretty certain now especially after what all you have said, that its not working.
Subaru must either have crappy sensors or bulbs in there because we bought a 95 Legacy LSI about 3.5 years ago which also had a non working fuel light.
Old 07-23-2009, 11:40 AM   #7
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
I always can tell how much is left when I fill up. It's a 16.9 gal tank. minus whatever you put in. I've never filled up my tank with more than 16.2 gallons and that needle was WAY below the E line.
Old 07-23-2009, 01:11 PM   #8
Slug71
Member#: 159963
2003 Subaru Baja
Black & Silver
Well it definitely was on fumes last night. Try to start the car this morning and it was running out of gas.
Guess i'll be taking it to Subaru tomorrow.
Old 07-24-2009, 10:13 AM   #9
kev m
Member#: 128582
2011 Nissan Juke
I should walk out to the car and check it, but IF it is supposed to self-test, then it has nothing to do with the sensor, it's the circuit between the ECM and the light (or the bulb itself).
Old 07-25-2009, 07:56 AM   #10
BrunoShield
Member#: 155944
2003 Baja
Black Granite Pearl
I happened to think of this post yesterday while I was washing my engine. Yeah, I'm anal about my Baja. I checked since my low fuel light works properly and goes off with about 2.6 gallons left in the tank and the needle almost on the E mark. The light DOES NOT come on with the key test. For whatever reason that circuit isn't tested at start up.
BrunoShield is offline   Reply With Quote
Old 07-25-2009, 11:06 AM   #11
Slug71
Member#: 159963
2003 Subaru Baja
Black & Silver
@BrunoShield,
Thanks for looking into that for me. So its either the bulb or the sensor then.
Didnt get time to take it to Subaru yesterday but will get it there on Monday since they need to put a sticker on it anyway.
Old 07-25-2009, 12:11 PM   #12
tcat
Member#: 218325
2005 Baja Sport
Dark Blue
Default Fuel Filter Location
I just signed up here and doesn't look like I can start a new topic, so this one seemed "close". I bought a Fuel Filter to save some bucks on maintenance, but now can't find where it's at on the Baja. I've looked under the car and under the hood, nothing looks right. Is it hidden somewhere?
tcat is offline   Reply With Quote
Old 07-25-2009, 01:00 PM   #13
Slug71
Member#: 159963
2003 Subaru Baja
Black & Silver
On the right hand side of the engine by the strut housing.
Old 07-25-2009, 02:36 PM   #14
tcat
Member#: 218325
2005 Baja Sport
Dark Blue
Thanks... I see something "large" in that area that might be a fuel filter, connected with metal lines. It's twice as big as what I bought, which looks like the Bosch filter here: http://www.drivewire.com/products/su...-filter/18478/ which appears to need rubber lines.
OK, I went and took a shot: http://i.pbase.com/o6/13/3613/1/1153...aFuelLines.jpg
These are the fuel lines on the drivers side. They don't seem to trace to a Filter (unless those 2 "small" black things are filters). Nothing looking like the filter recommended for a 2005 Baja. Any other ideas where to look?
Old 07-26-2009, 01:06 AM   #15
Slug71
Member#: 159963
2003 Subaru Baja
Black & Silver
The bosch filter looks like what i have. That pic you have doesnt work. Ill take a look at mine in the morning and get back to you.
Old 07-26-2009, 07:45 AM   #16
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
Only the 2003 has the fuel filter in the engine bay everythign else has it built in to the gas tank and it's not serviceable..
holland_patrick is offline   Reply With Quote
Old 07-26-2009, 07:48 AM   #17
holland_patrick
Member#: 72014
05 Baja gone
Old 07-26-2009, 09:42 AM   #18
tcat
Member#: 218325
2005 Baja Sport
Dark Blue
Wow! Glad I decided to start doing most of the 15K service myself! They charge like $200, and list a lot stuff... like change air filter, change FUEL filter, rotate tires, change oil, add gas treatment, add oil treatment, inspect this and that.... Well I get free rotations at DT, just replaced the air filter for $12, and if they don't change the fuel filter they're a total rip off! I will let them keep changing my oil and oil filter, well worth $20-$30. Hopefully I can return the Fuel Filter I bought. Thanks for the answer!
Old 07-26-2009, 08:09 PM   #19
kev m
Member#: 128582
2011 Nissan Juke
<snip>
Bruno, you beat me to it, I remembered to check as I was leaving for the weekend (in the Baja) but was away from a computer until now - yeah, for some reason that circuit doesn't seem to self test. I do know mine is otherwise working normally.
K
How much gas is left when the low gas light comes on? catass STi Forum Archive 11 06-30-2003 06:21 PM
full tank of gas = gas light? Takashi Service & Maintenance 10 03-27-2003 03:35 AM
Anyone got a gas light?! Jazz95 Newbies & FAQs 9 03-30-2001 12:32 AM
