Welcome to the North American Subaru Impreza Owners Club Friday April 18, 2014
Old 04-30-2002, 10:19 PM   #1
Dylan
Member#: 16537
96 Acura RL
Default Questions on spring rates
FHI Ver 5 strut w/ eibach springs is what I'm ridding on now, its a nice ride but bouncy more than I care for, I like the lowered profile of my car though. I was told that the struts i'm running are design for a lowered spring, True? What springs could I maybe give a try, and there ratings, Also would softer springs remedy the bouncing.
Thanks,
Dylan
Dylan is offline   Reply With Quote
Old 04-30-2002, 10:38 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
It depends on what you mean by bouncing, but if the car is continuing to move up and down after the "bump" the usually it would mean struts.
Either your struts are too weak, or they are way too stiff causing the car to sort of bob around as the chassis flex.
Old 04-30-2002, 10:41 PM   #3
froggert
Member#: 768
OB, legacy, 911,
ram 1500, 1098s, m620
i haven't ridden in that combination, but what sort of bounciness are you getting?
have you check your tire pressure? my car starts bouncing over everything when running lower than normal tire pressure with the winter all-seasons.
froggert is offline   Reply With Quote
Old 04-30-2002, 10:46 PM   #4
Dylan
Member#: 16537
96 Acura RL
I've had the struts for about a month maybe more, and its not bouncy from blown struts, Im aware of that cause I ran my stock struts for a while.
Old 04-30-2002, 10:49 PM   #5
Dylan
Member#: 16537
96 Acura RL
Haven't thought of the tire pressure, it's at were it should be, but u never know in minnesota hot one day snow the next
Actual lowering and wild guesses on spring rates Prodrive STi springs BIGSKYWRX Brakes, Steering & Suspension 3 09-01-2005 03:55 PM
Question about spring rates? JohnyS Vancouver Impreza Club Forum -- VIC 1 05-16-2004 02:54 AM
Question about spring rate measurement units edkwon Brakes, Steering & Suspension 3 05-04-2003 10:38 PM
Quick and easy question on spring rates DDMan Brakes, Steering & Suspension 5 10-15-2002 10:48 PM
Question about spring rates and dampening rates Memnoch Brakes, Steering & Suspension 7 02-02-2001 11:30 AM
