#1 | |
Member#: 73805
![]() Quote:
#2 |
Member#: 8489
BAIC
Vehicle:1978 Plymouth Volare Maroon / White Vinyl |
Apocalypse
#3 |
Member#: 53222
Vehicle:'10 Genesis Coupe '99 Miata |
"16bhp with a turbo"? WOW!
#4 |
Member#: 175998
VIC
#5 |
Member#: 139813
Vehicle:2002 WRB WRX 07 UGM STi |
Well that will most likely be only in Europe, based off your guys' american responses I can almost garuntee you won't see it stateside.
And I think it's supposed to say 168 Hp. |
#6 |
Member#: 52189
Vehicle:2006 MINIiiiiii :) |
Perfect engine for a MINI
#7 |
Member#: 110330
Vehicle:2007 STI Limited 2012 MDX 2012 Golf TDI |
C120? Gross.
#8 |
Member#: 20325
NESIC
Vehicle:08 Yamaha WR250R 07 Suzuki DL650 |
#9 |
Member#: 102900
Vehicle:2005 Impreza STi Tuned by AGILE AUTO |
Wow imaging slapping two of those bad azz engines together, you'd have a ...oh wait
#10 |
Member#: 40989
Vehicle:OT vag inspector |
why don't we just "cut to the chase" and make a 1 cylinder direct injection, turbo, 4 active valved hybrid?
#11 |
Member#: 14611
So what's wrong with 168hp and 150-185lb ft??
Doesn't the Impreza RS (or whatever Subaru calls it now) have about that much power? Same with the base Camry, Fusion and Accord. For the most part, most people don't care how a car makes it's power if it has enough "pep" when they drive it. As long as M-B and BMW can find a way around a 3-cylinder engine's notorious shaking, most people are going to be perfectly fine with this. I would be curious to hear about any potential weight savings that a 3-cylinder might offer, because shedding pounds would be key in using smaller engines. |
#12 |
Member#: 36946
#13 |
Member#: 139813
Yea but when you think of everything else in the engine that is not required for a 3 cylinder vs. a 4 cylinder it might be quite a few pounds. But also based on the vehicles this engine will be in, it will most likely not make much of a difference. I'd much rather have a turbo 3 than an N/A 4 with a matching torque to HP.
Smaller block, less coolant, less oil, 1 less manifold port, 1 less intake manifold port, smaller head....it all might be enough to offset the baby snail that will be going in there. |
#14 |
Member#: 14611
^ Ya know, that's an interesting issue. Like at what point does the weight savings make it not worth it? There is the law of diminishing return - you can only reduce the displacement and the cylinder count so far before it makes it unusable/not worth it.
And at what point do these car makers have to look at more "radical" engine designs? There have been numerous engine designs posted here (and in the OT) that supposedly offer vastly superior mileage and/or power and/or some other benefit, yet many of them seem to be too radical to be taken seriously for car-use. At what point do the car makers start to take a more serious look at ICE designs that are "outside the box"? Or are they simply gonna ride the current ICE design till the electric motor completely takes over? |
#15 | |
Member#: 20325
NESIC
But we do look stuck with the ICE until electrics take over. The automakers have big investments (or sunk costs depending on your POV) in facilities for casting and machining engines and transmissions. Inertia... |
#16 | |
Member#: 935
Vehicle:Tony Pond Fan Club |
To make that work it's got to have insanely tight tolerances, even with a turbo. Which is why I'm currently looking for a pre-Ford Volvo with a non-interference engine. |
#17 |
RIP 1/19/64 - 7/23/11
Scooby Guru Member#: 24654
NESIC
Vehicle:1957 Taggart Comet atlasshruggedpart1.com |
#18 | ||
Member#: 14611
But yeah, I get what you are saying - that optimizing one component by 2% and 2% from a bunch of other parts will sometimes net you more than the total of the parts. But my points was that a 4 cylinder is not 1/2 the weight of an 8. Quote:
But alas, your point about inertia is probably why we continue to simply "tweak" the same design over and over again. There are billions of dollars worth of tooling and engineering that have been put into this design - even if it's not the bestest design out there (and no design will ever be "perfect"), any potential pay-off for coming up with something totally different would not be financially feasible. |
#19 |
Member#: 935
I thought with the type of hybrids that are being made today an opposed piston engine would be perfect; one crank to power the car while the other charges the batteries.
Of course the Volt's got all that beat. |
#20 | |
Member#: 14611
![]() The 1999 S-class. The big boy. No one would say that it wasn't luxurious. It weighed over 4500 lbs and it's base engine in the US was kicking out only |
#21 | |
Member#: 54772
You're also reducing the cylinder surface area which is beneficial in terms of thermal efficiency. As for all those novelty engines, most of them are designed to maximize access to venture capital rather than efficiency. Ye olde piston engine is pretty damn good at turning pressure into kinetic energy. The tricky part is turning the chemical energy stored in the fuel into pressure without generating too much waste heat in the process, and that's difficult as long as you're burning the stuff. |
#22 |
Member#: 17979
Vehicle:335i Blue |
I doubt these 3 cyls will make it to the states... maybe but I doubt it.
In terms of required power... Europe is a whole different story. Heck the 3 series came as a 316i with ~100hp over there until the mid 2000s. I remember seeing BMW 518i's too.... |
#23 | |
Member#: 8267
Vehicle:2011 Outback 6MT Black on Silver |
edit: found this review...hp is about the same, but, as expected, the torque in the diesel is pretty high... "It’s just about quick enough, too. A mere 175bhp and 258lb ft might not sound like much, but it’s enough providing you think ahead and are prepared to use the gearbox." Last edited by Jarvis; 07-23-2009 at 12:51 PM. Reason: quote |
#24 |
Member#: 169223
umm... did you forget how many extra parts you need to make FI work and how much easier things can break?...
#25 |
Member#: 139813
I should be saying Uhmmm to you. Extra parts to make FI work? Please explain these extra parts. Seriously...BMW and MB have used multiple engines with FI via superchargers and turbos. So it's not like they don't understand the technology. I don't know, I'm getting worked up over nothing I guess.
I think some of you guys are getting the wrong impression of what these engines will be going in. It will be only in europe and most likely A, B, and very low level C-class (plus the other BMW models) cars that we currently don't even have here. People in Europe and other countries are loving all these small engines being used in cars that don't even see alot of abuse. And things breaking? I would imagine things might break less seeing it's such a small engine ,not putting out a lot of power. Last edited by HybridBoxer; 07-23-2009 at 01:23 PM. |
| Thread Tools | |
| Display Modes | |
| Breaking News: Mercedes-Benz will drop CLC in favor of C-Class Coupe | AVANTI R5 | Non-Subaru News & Rumors | 0 | 11-18-2009 07:45 AM |
| Breaking News: Mercedes-Benz E63 AMG Coupe Black Series in the works | AVANTI R5 | Non-Subaru News & Rumors | 13 | 07-29-2009 01:50 PM |
| Breaking News: Mercedes-Benz CL Cabrio is ready | AVANTI R5 | Non-Subaru News & Rumors | 0 | 02-21-2009 11:28 AM |
| New Mercedes-Benz C-Class comes on market with Environmental Certificate | NYCshopper | Non-Subaru News & Rumors | 0 | 01-10-2007 09:51 AM |
| Subaru working on 8 cylinder Engine!!! | HB_Dad | News & Rumors | 34 | 11-22-2003 06:22 PM |
