Old 04-30-2002, 10:39 PM   #1
rangere7
Member#: 1955
Default Egt??
What should the egts be with an aftermarket turbo??
under full boost and under no boost?
rangere7 is offline   Reply With Quote
Old 04-30-2002, 11:37 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
IIRC, 1550 is the highest you want to go if your tapped into the #3 header.
I'm tapped into the collector, so my readings are pretty much useless
kastle is offline   Reply With Quote
autometer egt gauges, what egt probe are you using? Tobey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 07-09-2004 11:19 PM
Issues with Stock EGT bung location and Omori / other EGT gauge probes? DTECH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-06-2004 08:24 PM
Autometer Ultra lite EGT with oem egt probe? dubRexn Electrical & Lighting 2 09-17-2003 05:43 PM
will a defi egt probe fit into the factory uppipe egt location? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-08-2003 12:32 PM
what to do with uppipe factory egt if using defi egt whiterabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 11-21-2002 04:57 PM
