#1 |
Member#: 4579
Vehicle:MY01 XxNiKi XxNiKi |
my car backfires now soemtimes when i put it into first gear and give it some gas? why? its sooo scary...sounds liek i am doign soemthign wrong.. and do you all get alot of water comign out of your exhausts? especially in teh mourning.... i let my car warm up all teh time.....what is it?
#2 |
Member#: 13282
Vehicle:2007 FXT WRB SPB Edition |
Stock exhaust?
Mine(non stock) does this when I had floored it then back off the gas rather quick. From what I understand it is unused gas hitting the Cat. The water coming out of the exhaust is from some kind of condensation I believe, a friend explained it before don't remember all of it though. Personally I don't worry about it to much. Buster |
#3 |
Member#: 9213
Vehicle:2000 RS Red |
In a sense, the water is condensation. Remember, all combustion reactions produce at least two things...Carbon Dioxide, and water. Water is normal.
#4 |
Member#: 13823
Vehicle:2009 Legacy 2.5i SE C A P S CAPS CAPS CAPS |
I was told that the cat changes the unfriendly carbon monoxide to a more friendly water vapor(condensation). Or something like that. It is normal.
#5 |
Member#: 6031
Vehicle:2001 Impreza RS 2.5 Sliver |
When the pipes heat up they cause condensation. This is then pushed out of the back of the car by the presser of the exhaust.
Its normal and will happen with all cars. The Cat only takes unused gass and burns it so that your exhaust is cleaner. No magic water tricks ![]() |
#6 |
Member#: 6570
South East
Vehicle:04 WRXSW 9.3 TRB0 CNV |
Ahh yes the mystery of Subaru!!
Mine backfires in 1st 2nd 3rd, and sometimes forth, and I like it. You're right from what I've heard... Raw fuel through the system hitting the hot exhaust results in a pop. Due to the system running rich. Steve |
#7 |
Member#: 4103
Vehicle:2003 WRX Wagon Reddish |
Or it will backfire real good if you have an exhaust leak like me.
#8 |
Member#: 4973
Vehicle:2000 2.5 RS Blue |
i get the same thing, i was somewhat worried about it but my mechanic told me its normal for scoobies.
| Thread Tools | |
| Display Modes | |
| Car stalls when in neutral | CoolRex | Factory 2.0L Turbo Powertrain | 68 | 10-17-2008 08:01 AM |
| Car Rolls When In Gear | NWA ARJ | Transmission (AT/MT) & Driveline | 10 | 10-27-2006 07:09 PM |
| when cancelling cruise, car decelerates slowly at first | Thirties | Outback Forum | 3 | 07-30-2006 05:10 PM |
| does your car move easily when engaged in first? | curly | Factory 2.0L Turbo Powertrain | 3 | 10-23-2002 01:45 PM |
| When you first turn on your car? | WR-REX | Texas Impreza Club Forum -- TXIC | 46 | 02-15-2002 12:03 PM |
