07-23-2009, 04:00 PM | #1 |
Member#: 201563
International
Vehicle:1998 impreza outback two tone |
I Need Technical Help
I have a 1998 Subaru impreza outback sport, right now th eknock sencor keeps going off i thought it may have been the fule pressure so i replaced the pump but it didnt fix it, befor i go any further i would like to know if anyong knows the standard PSI for the fule system in this modle. I would also like to know if anyone knows the good/bad resistanes for the o2 sencor and the cam sencor.
thank you for your time my spelling sucks.
07-23-2009, 05:39 PM | #2 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
you may try asking in the NA powertrain forum, they may know better. If you can, post the actual code. If the car really is knocking, try a higher octane fuel and see if it goes away.
you can search for O2 resistances. |
07-23-2009, 06:00 PM | #3 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
What do you mean by "going off" you are getting a knock sensor code? It is pretty common for them to go bad on that year vehicle.
07-23-2009, 08:02 PM | #4 |
Member#: 201563
International
yes knock censor code, I've been using high octane for the car and it went away for about 5 months but now its back and wont stop
07-23-2009, 09:55 PM | #5 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
07-23-2009, 11:20 PM | #6 |
Member#: 157987
Vehicle:2006 TR Sedan black |
yeah just replace the knock sensor. Maybe $120+ tax OEM from a dealership. If you install it yourself, take careful note of it's position. There's a recess in the block that it sits in; you dont want it to touch the sides of the recess. One 12mm bolt. Torque spec should be 18-19 ft. lbs.
anyone have a pioneer avic u310bt need some help | cosanostra | Car Audio, Video & Security | 5 | 06-04-2010 12:20 PM |
Need technical help w/'window lock' switch wiring... | UP2MTNS | Electrical & Lighting | 5 | 03-29-2010 12:57 PM |
need technical help to turn my 04 into a 07 sti minus the front end | ssweet08 | Southern California Impreza Club Forum -- SCIC | 27 | 01-09-2008 09:49 AM |
22RE toyota truck. Need technical help. | DoctorNick | Off-Topic | 9 | 09-30-2005 03:11 PM |
