Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 07-23-2009, 06:11 PM   #1
Scott_2.5TS
Member#: 163806
Default whiteline front 27/29 sway bar... is this what it's suppose to look like?
Edit: the bottom endlink bolt in the top pic is bent
I never saw any pics or anything... but i did the endlinks too and i'm unsure if this is the way it should look
Are the head/bolts in the correct place? the rubber yellow piece looks like it wants to slip over the washer, sort of
why does one endlink slant more than the other?
Scott_2.5TS is offline   Reply With Quote
Old 07-23-2009, 06:30 PM   #2
DrewDeezy
Member#: 160279
2004 STi
Crawford Performance
allignment?
DrewDeezy is offline   Reply With Quote
Old 07-23-2009, 06:51 PM   #3
Scott_2.5TS
Member#: 163806
no i just got one done
maybe the bar needs to slide the other way a bit... i'll drive for a bit and see if it settles in
Old 07-23-2009, 07:39 PM   #4
mslstixx
Member#: 101387
2006 2.5i Wagon
RBP
Remember, you have a bunch of grease in those bushings, so the bar will slide side to side. If it really bothers you, you can make your own "lock ring" out of some rubber and two hose clamps. Or you can add some thick spacer washers to even it up.
But unless you hear the bar clunking around, I wouldn't worry about it too much.
mslstixx is offline   Reply With Quote
Old 07-23-2009, 07:56 PM   #5
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
those are the whiteline light duty links huh? are those really the correct P/N for the application? are they longer than stock?
it may be an illusion but it *looks* like they are currently fouling on your tierods because they stand more vertical (whereas if they were shorter the bar would rotate down and back further to join to the links)
UkNuck is online now   Reply With Quote
Old 07-23-2009, 10:36 PM   #6
mslstixx
Member#: 101387
2006 2.5i Wagon
RBP
I just noticed what appear to me marks of contact between the bar and the tie-rods. OP, some shorter endlinks may be a good idea. I have had good luck with the kartboy links myself.
Old 07-23-2009, 10:42 PM   #7
STi-MAN
Member#: 70252
05 STI
blue
^ dont look like contact marks to me
more like the dirt being removed when the car got it's alignment.. those areas where the its polished is where an aligner typically puts the wrench to align.
STi-MAN is offline   Reply With Quote
Old 07-23-2009, 11:48 PM   #8
Scott_2.5TS
Member#: 163806
ding ding ding!! i just got an alignment.. so yes you're correct about the marks
and the endlinks are no where near the tie rod... it just looks like that
Old 07-24-2009, 01:19 PM   #9
mslstixx
Member#: 101387
2006 2.5i Wagon
RBP
That's good to hear, pics can be deceiving.
Old 07-24-2009, 01:23 PM   #10
sigurd
Member#: 128721
2002 impreza WRX
psm
looks fine to me
sigurd is offline   Reply With Quote
Old 07-26-2009, 03:38 PM   #11
Scott_2.5TS
Member#: 163806
OK, what sort of endlinks hsould i be using... look at the bottom bolt, it's bent!!
Old 07-26-2009, 05:36 PM   #12
Whiteline Jim
Member#: 212668
2008 Sti
G'day everyone,
Scott_2.5TS, looks like you may have the wrong part number here, could you please let me know what actual part number you were supplied?
We'll try and help work this out for you quickly.
Cheers
Whiteline Jim
www.whiteline.com.au
Whiteline Jim is offline   Reply With Quote
Old 07-26-2009, 06:00 PM   #13
Scott_2.5TS
Member#: 163806
i bought them used, but brand new never installed from a member here
they are for 1993 - 2007 imprezas... so i guess i can't use them on my 2002 bugeye WRX??
which ones do you recommend Jim? i still have the stock ones i can throw back on there
Originally Posted by Whiteline Jim View Post
G'day everyone,
Cheers
Whiteline Jim
Old 07-29-2009, 01:17 AM   #14
Whiteline Jim
Member#: 212668
2008 Sti
G'day Scott,
What you seem to have purchased was a KLC20 kit to suit the earlier steel control arm with stock rubber/plastic dogbone links (MY94-00), http://www.whiteline.com.au/product_..._number=KLC20A .
These use an 8mm mount and corresponding bolt on the control arm along with a yoke style double face mount tab where as you need a KLC32 which replaces a ball/ball style stock link, see http://www.whiteline.com.au/product_detail.php?part_number=KLC32. This is an alloy style link and the correct catalogued kit for your car.
One option is to drill the lower crush tube out to a 10mm bolt size and replace accordingly, other is to purchase a KLC32 kit.
Hope that makes sense.
Cheers
Whiteline Jim
Old 07-29-2009, 12:32 PM   #15
Scott_2.5TS
Member#: 163806
Thank you!!! Amazing!
Old 08-03-2009, 07:28 PM   #16
Whiteline Jim
Member#: 212668
2008 Sti
G'day there,
You're welcome and I hope that means all's well now?
Cheers
Whiteline Jim
Old 08-10-2009, 02:08 AM   #17
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
any updates Scott?
96accord is offline   Reply With Quote
Help!Is my airbag supposed to look like this? imprezin04 Interior & Exterior Modification 7 10-03-2006 11:47 AM
Is the Air Conditioning suppose to work like this? dauss Newbies & FAQs 5 04-15-2006 02:27 PM
I have no idea what my flasher relay is supposed to look like, any help? Krashtek1 Electrical & Lighting 1 09-18-2005 08:50 AM
Is carbon fiber supposed to look like crap?? (BIG pics inside) Hyper Interior & Exterior Modification 46 02-20-2005 08:44 AM
Is this what my spark plugs supposed to look like? 2000vfr800 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-19-2002 07:09 AM
