Old 07-23-2009, 06:53 PM   #1
thorne
Member#: 130063
2003 WRX
Silb
Default 2003 WRX vf39 93 VS e85
I finally got on the rollers. The e85 vs 93 at similar boost impressed the hell out of me. I want to thank ITPEric for giving me some feedback and IPS for donating the dyno time to see how subarus took to e85. I'm happy to say quite well.
If you notice the afr was being adjusted quite a bit. I need to sit down with TY again and scale the MAF some more. I left some power on the table I'm pretty sure but can you really complain when your 2.0 makes 330wtq?
I know allot of people have asked or had a intrest in E85. After running it I will say its definitely worth it.
I picked up 37hp and over 48ftlbs at the wheels. It's like having a bigger turbo with out the lag.
thorne is offline   Reply With Quote
Old 07-23-2009, 06:56 PM   #2
cszink
Member#: 163527
2009 09 WRX, 95 M3
White Power
Thanks for the info and chart...I was pretty curious about this myself.
cszink is offline   Reply With Quote
Old 07-23-2009, 06:58 PM   #3
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
So did you not scale the MAF correctly on 93 octane?
You shouldnt be using the MAF to change the AFR.
Old 07-23-2009, 07:27 PM   #4
thorne
Member#: 130063
2003 WRX
Silb
No I got a ebay intake and had not finished scaling it. The stock intake was maxed out.
Also you do scale the maf is your correction is off which will cause you afr to be off.
Old 07-23-2009, 07:37 PM   #5
Lboogie
Member#: 171611
2014 FiST
Blk
Did you run a full tank of E85 or enough to bring the avg octane to ~100?
Lboogie is offline   Reply With Quote
Old 07-23-2009, 07:39 PM   #6
4drcivicmaster
Member#: 211113
2004 STI
very nice! i am doing the same setup with an ewg and a vf48. i hope to hit atleast 310whp with them. this gives me hope.lol and it's also going to be on a dynojet.
4drcivicmaster is offline   Reply With Quote
Old 07-23-2009, 07:54 PM   #7
thorne
Member#: 130063
2003 WRX
Silb
I run 100% e85
Modded Stockers
Walbaro
vf39
up/down/catback
halman mbc
ebay tmic (NEVER AGAIN)
ebay intake (Junk)
Thats my power mods.
Old 07-24-2009, 12:11 AM   #8
4drcivicmaster
Member#: 211113
2004 STI
stock clutch holding alright??
Old 07-24-2009, 08:34 AM   #9
thorne
Member#: 130063
2003 WRX
Silb
The stock clutch did not hold up to 280wtq. I'm running a southbend stage 4.
Old 07-24-2009, 08:56 AM   #10
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
I have to say that you have one terrific graph there!! This is what a vf39 graph should look like, and you see very few of them. Holding 315 at 7k on a dyno jet is awsome. Even your pump map looks great in the higher RPM range.
This proves if your not afraid to run a good amount of timing those 50-75 whp vf turbo fall offs can be prevented. Who tuned your car? Great job who ever did
STi Mikey is offline   Reply With Quote
Old 07-24-2009, 09:11 AM   #11
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
what is your boost at? ..nvm 23 psi thats nice!
That torque curve is beautiful for the 39
BlackJavaPearl04 is offline   Reply With Quote
Old 07-24-2009, 09:14 AM   #12
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
nice numbers!
shadowmd is offline   Reply With Quote
Old 07-24-2009, 11:13 AM   #13
wrxhard
Member#: 108091
+1234
wrxhard is offline   Reply With Quote
Old 07-24-2009, 12:39 PM   #14
thorne
Member#: 130063
2003 WRX
Silb
I tuned the car. I had a few pointers from ITPEric and another tuner with experiance with E85.
the 93 octane is only running about 3 less degrees timing. After playing with thefoos timing tables I got a good feel what E85 likes and don't likes. You can have to much timing that does not knock but does not add power. I found this to be the case in a few spots.
This tune is honestly a mess to look at in the map. I've got a few hacks in place to get around my scaling issue just so i could see what the car did at the desired AFR. But this will be cleaned up on the street using the LC-1 and some help from willaty.
Once I clean up the map I will post it up for people to see.
I do have to give Master2192 some credit since with out all his help years ago I would not have been able to do this.
RIP SEAN
Old 07-24-2009, 08:18 PM   #15
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
very nice man! im not too familiar with the differences in dynos, how would you say the dynojet compares to airboys spreadsheet? the SS seems to put out very close to a mustang dyno i guess.
elevenpoint7five is offline   Reply With Quote
Old 07-24-2009, 08:22 PM   #16
JSarv
Member#: 163445
l33t *******
[email protected]
What kind of timing are you running at peak torque (highest load) and redline on E?
-Jerod
JSarv is offline   Reply With Quote
Old 07-24-2009, 08:34 PM   #17
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
-Jerod
im curious about this too. jerod, what are you running in those areas as well? i have a feeling im not running nearly enough. OP makes so much TQ! i made 310/259 on airboys spreadsheet with a 2.0, vf39, and E85. im obviously doing something wrong! haha!
Old 07-24-2009, 08:38 PM   #18
JSarv
Member#: 163445
l33t *******
[email protected]
15-16@ peak torque and 25-27@ redline
-Jerod
Old 07-24-2009, 09:02 PM   #19
thorne
Member#: 130063
2003 WRX
Silb
I'm running 16 pk tq 23-24 at redline.
11.5 obsesrved on lc-1 ( I have it in gas btw)
Old 07-24-2009, 09:06 PM   #20
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
14-15 at peak tq and 26-27 at redline... im only hitting 20 psi though, it just doesnt want to make more, i think i have a torn inlet. and my wbo2 died last weekend so AFRs still arent perfect(i HATE injector scaling). but still, hes making SO much more tq than i am!
side note, i found a thread on an e85 forum where you(jerod) talked about different latencies, im going to give that a try when my new sensor gets here. thanks! mine are about .05-.1 lower than what you posted up that worked for WH modded stockers with E. the heavier fuel thing makes sense.
Old 07-24-2009, 09:23 PM   #21
JSarv
Member#: 163445
l33t *******
[email protected]
Did you stop making power up top with more timing?
Have you tried leaning it out any?
I run mid 11's as well - most recommend leaner but I have found absolutely NO power gains or losses running it leaner - so I run it a bit richer and live with it.
-Jerod
Old 07-25-2009, 06:27 AM   #22
thorne
Member#: 130063
2003 WRX
Silb
yes I tried going leaner. I did not make any power. I actually lost it. I went richer and bam power back. The car no obsereved knock or anything. It just made more power when I was richer.
I added some timing up top and did not see any real change
Old 07-25-2009, 09:56 AM   #23
JSarv
Member#: 163445
l33t *******
[email protected]
figured... I see a bit but nothing overwhelming...
It seems to be a smoother pull running a bit rich as well
Old 07-25-2009, 10:09 AM   #24
aaronzgod
Member#: 196050
2002 VF-39 Rex
02C
wow i got same mods minus e85 and i made way less power ???? here is my graph here i dont know how to read but i know one includes a before and after
http://www.cardomain.com/ride/3034097/4
aaronzgod is offline   Reply With Quote
Old 07-25-2009, 10:32 AM   #25
crashtke
Member#: 120912
Yours is on a mustang dyno Not all dynos read the same.
crashtke is offline   Reply With Quote
08 STI Stage 2 pump 93 vs 08 STI stage 1 E85 Kastley85891 Proven Power Bragging 1 04-26-2009 11:43 PM
FS in CT: 2003 WRX vf39, cobb, sti, etc. 82k euro2jdm NESIC Private Classifieds 8 04-06-2009 05:53 PM
2003 WRX- VF39 or VF30 Joel21Wolter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-29-2008 02:08 PM
2003 WRX- VF39 or VF30 Joel21Wolter Newbies & FAQs 25 11-28-2008 08:25 PM
Cobb OTS Map - VF39 93 MT101 Vs. FP18G 93 MT101 rhinotech Engine Management & Tuning 23 06-21-2007 09:15 PM
