Old 07-23-2009, 09:25 PM   #1
xTourniquet
Member#: 177477
2006 WRX Limited
Legacy 2002 Legacy Rough Idle
I had originally thought that it might be a problem with the EGR valve but after searching I saw that Subaru stopped using them in 1996. Is that true?
Here's the problem. After the car is warm and I come to a stop at a stop light, or something of the sort, the car idles very low and very rough. It feels like it's barely running. This is made worse when the A/C is on. If you put the car in neutral or park when the rough idle presents it self it goes away. It's an automatic.
Do you think it could be something with the transmission? Or PCV valve?
The car was just in the shop for a torn CV boot and I had them replace the spark plugs and fuel filter. The oil was also just changed less than 1000 miles ago with Mobil 1.
Any help is greatly appreciated! Thanks.
xTourniquet is offline   Reply With Quote
Old 07-24-2009, 04:33 AM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
My 1998 has an EGR valve, I believe yours does to.
Did your idling issues start after the new plugs & wires were installed or was it like that before?
If the idling issues started after the plugs were installed, what brand plugs & wires went in? Were they OEM?
Old 07-24-2009, 04:57 AM   #3
iluvdrt
Member#: 46248
82 Brat
Tan
Mine is an automatic and does that too. Some times of I inch forward a hair or shift in and out of D it goes away. I would love to know the answer to that.
I have checked engine mounts, trans mounts, pitch rods, I cannot find the problem. Engine is smooth as glass in park or neutral even with the AC on. Sometimes its bad enough I have to put it into N or it will rattle apart LOL.
iluvdrt is offline   Reply With Quote
Old 07-24-2009, 09:22 AM   #4
xTourniquet
Member#: 177477
2006 WRX Limited
The idling issues started before the spark plugs. They didn't change the wires though, I guess I should check those out.
If I DO have an EGR valve, where is it?
Yep, sounds like we're both having the same problem. Have you checked for vacuum leaks? I might do that next.
Old 07-24-2009, 10:27 AM   #5
iluvdrt
Member#: 46248
82 Brat
Tan
No, but I did a complete top end rebuild about a year ago. I think it is trans related looking into the Haynes manual t-shooting section.
Old 07-25-2009, 01:22 AM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
I prefer to use OEM ignition wires as they work well.
EGR valve is on the rear of the engine, near the top, on the drivers side. It will have a ~3/8" dia SS tube out the bottom down to the exhaust port area
Old 07-26-2009, 01:19 PM   #7
xTourniquet
Member#: 177477
2006 WRX Limited
Thanks Charlie, I'll check that out next weekend when I have some time.
Old 07-28-2010, 11:56 AM   #8
rinna chan
Member#: 195927
Bringing this back from the dead, I'm having the exact same problems and am wondering if anyone ever figured out what it was. I've got a 2000 Outback a/t. Just did the plugs, grounds, cleaned the IAC, new air filter, lots of miles for any ecu idle re-learning. Pretty stumped at the moment and would rather not throw random parts at it to fix it. I'm thinking its electronic since it goes away in park and neutral and when the a/c is engaged.
rinna chan is offline   Reply With Quote
Old 07-28-2010, 12:04 PM   #9
xTourniquet
Member#: 177477
2006 WRX Limited
Unfortunately I never got this problem resolved and the car still does it if you guys have any more tips I will gladly give them a try.
Rough idle, intermitent and rough cold starts... carter_wrx Pre-2002 Factory Turbo Powertrain 26 10-28-2009 01:03 PM
2002 Wrx Cold Rough Idle narib2001 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-23-2009 08:58 PM
1996 legacy rough idle, tried everything I can find brian3676 Normally Aspirated Powertrain 6 09-30-2008 04:57 PM
98 Legacy starts, idles rough for ~3 sec then dies jasona Normally Aspirated Powertrain 3 04-16-2006 08:49 PM
2002 WRX misfiring and rough idle rallysport02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-20-2005 11:39 AM
