Old 07-23-2009, 11:36 PM   #1
The Crowd
Member#: 189231
2009 WRX Hatch
Default 2009 wrx 298 hp 355 tq
22.6 Psi @ 3700 rpm, today protuned at Church Auto. (Dynapack, about 40 hp lower than flywheel hp on awd cars per the website)
355 ft lbs @ 3363 rpm.
298 hp @ 4690 rpm.
I'm wondering why I peaked at so low in the rpm band? I made apprx. 277 hp at redline.
Boost tapered to about 16 psi at redline.
2009 WRX wagon
mods:
AEM CAI
Perrin TMIC
Cobb Catted DP
SPT exhaust
Walbro 255 fp
I don't know very much about tuning at all, but Shawn said I might possibly be able to hold boost a little better with a pill modification, but the turbo seems to be running out of breath up top. Overall, car seems much faster. It gained about 50 tq and 30 whp peak over the COBB OTS map.
Thoughts?
And my scanner is down so I'll have to get it scanned later.
The Crowd is offline   Reply With Quote
Old 07-24-2009, 01:09 AM   #2
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
those are good numbers for a WRX
u2_m4r1n3 is offline   Reply With Quote
Old 07-24-2009, 01:19 AM   #3
MTM Motorsports
Member#: 190914
2008 WRX
yeah, the dynapack is certainly no heart breaker dyno that's for sure.
MTM Motorsports is offline   Reply With Quote
Old 07-24-2009, 01:20 AM   #4
1cleenwrx
Member#: 170542
08 AGILEbuilt-STI
93Soarer/01RSTI/06SPEC-B
nice!!! plans? are you staying with the stock turbo? anyways, love the results.
1cleenwrx is offline   Reply With Quote
Old 07-24-2009, 01:23 AM   #5
MTM Motorsports
Member#: 190914
2008 WRX
jump on a set 850 cc injectors, run e 85 and up the boost you'll see even more power.
Old 07-24-2009, 01:31 AM   #6
[D.I.]WRX
Member#: 116314
Shawn Church. Dynapack. You probably peaked early because the stock turbo is small.
[D.I.]WRX is offline   Reply With Quote
Old 07-24-2009, 04:20 AM   #7
Danomite
Member#: 190449
2008 RAW motor/Ah2nD
nice torque #'s
Danomite is offline   Reply With Quote
Old 07-24-2009, 12:44 PM   #8
The Crowd
Member#: 189231
2009 WRX Hatch
I was thinking of doing this.
Old 07-24-2009, 12:46 PM   #9
The Crowd
Member#: 189231
2009 WRX Hatch
Originally Posted by Danomite View Post
nice torque #'s
Yeah, it's a blast.
Old 07-24-2009, 12:58 PM   #10
The Crowd
Member#: 189231
2009 WRX Hatch
Thanks. It all depends on if I get used to the power and get bored of it, then maybe I'll go FMIC with something bigger.
Going faster may be trouble though. I'll have to do some thinking.
Old 07-24-2009, 01:04 PM   #11
Lboogie
Member#: 171611
2014 FiST
Blk
mmmm, cowbell
Lboogie is offline   Reply With Quote
Old 07-24-2009, 01:09 PM   #12
PolarisSnT
Member#: 85905
2004 WRX
Originally Posted by The Crowd View Post
22.6 Psi @ 3700 rpm.
I hope thats a misprint.
PolarisSnT is offline   Reply With Quote
Old 07-24-2009, 01:12 PM   #13
The Crowd
Member#: 189231
2009 WRX Hatch
gains weren't terribly bad though. i'm imagining on a dynojet maybe 285 whp and 340 qt.
Old 07-24-2009, 01:14 PM   #14
The Crowd
Member#: 189231
2009 WRX Hatch
no miss print. i wish my scanner worked so i could post the graphs. i won't have access to one until i go back to work though. i could draw it on MS paint?
Old 07-24-2009, 01:16 PM   #15
The Crowd
Member#: 189231
2009 WRX Hatch
I do have a question though. I hear a fluttering noise under full boost. It's not super loud, but it is audible. I know that's not much to go by. I'll do a datalog today/tonight and post it.
Old 07-24-2009, 01:20 PM   #16
WRX34
Member#: 13364
1996 GM8 caged,
99 V8 RSTi, 11' FXT
It's ~10% lower depending on setup for dynopack vs. dynojet (mustang dyno's FTW). So I'd guess your #'s would be closer to 270 whp and 320 wtq. Still not bad though considering!
Flutter? Like your WG is going spastic trying to keep up w/ boost demands? It may be normal...hard to tell without being there or seeing logs/both. GL tho! (EDIT: 22.6 psi...eek...seems a bit high to me. No meth?)
WRX34 is offline   Reply With Quote
Old 07-24-2009, 01:22 PM   #17
Badler
Member#: 133597
Wastegate flutter. Normal.
Badler is online now   Reply With Quote
Old 07-24-2009, 01:29 PM   #18
The Crowd
Member#: 189231
2009 WRX Hatch
Originally Posted by WRX34 View Post
It's ~10% lower depending on setup for dynopack vs. dynojet. So I'd guess your #'s would be closer to 270 whp and 320 wtq. Still not bad though considering!
Yeah the boost at 22 psi I thought was high compared to what i have seen on the internet. I'll log today / tonight and post.
Old 07-24-2009, 01:52 PM   #19
testes1010
Member#: 47145
2012 Gas Saver
High boost for stock injectors but not 'too' high for the turbo considering its essentially a VF39/43 with a LGT/09WRX Compressor cover.
testes1010 is offline   Reply With Quote
Old 07-24-2009, 03:24 PM   #20
herewego311
Member#: 143860
Stock 09 WRX Turbo is the VF52, right?
herewego311 is offline   Reply With Quote
Old 07-24-2009, 03:29 PM   #21
testes1010
Member#: 47145
2012 Gas Saver
Yes. Its a VF39/43 with a LGT/09WRX(2bolt Compressor outlet at 12o'clock).
Old 07-24-2009, 03:31 PM   #22
mcganz121
Member#: 138569
2010 A4 Quattro <-
06STI <- 09WRX <- 06WRX
22.6 psi isnt maxing out fuel system??? wow. is the lgt style fp and injectors larger then the 06/07 stock fp and blues?
mcganz121 is offline   Reply With Quote
Old 07-24-2009, 03:33 PM   #23
herewego311
Member#: 143860
Ok, sounds good. Thank you!
Old 07-24-2009, 05:07 PM   #24
Bullwinkle1983
Member#: 172332
2006 WRX
22.6 PSI peak; which doesn't mean he is running 22.6 PSI at redline. Peak boost numbers really have nothing to do with the required size of injectors, boost at peak HP is a better indication.
Bullwinkle1983 is offline   Reply With Quote
Old 07-24-2009, 05:14 PM   #25
PolarisSnT
Member#: 85905
2004 WRX
Just saying full boost by 3700 seems very late.
06 WRX TR VF-43 -- Agile Tuned -- 311 HP / 354 TQ brain juice Proven Power Bragging 22 10-28-2008 08:36 AM
350 Hp 355 Tq Vf22 brocksdad Proven Power Bragging 25 04-29-2008 12:01 AM
05 WRX 291 hp / 316 tq snwman Proven Power Bragging 4 03-22-2008 05:47 PM
2007 WRX?!! Less HP and TQ?!?! gedlee Newbies & FAQs 2 10-18-2006 04:29 PM
Element Hydra + Element GT65 Turbo + Time Attack WRX = 534 HP 478 TQ! Element Tuning Proven Power Bragging 56 01-31-2006 08:28 PM
