Welcome to the North American Subaru Impreza Owners Club Wednesday January 28, 2015
Old 07-24-2009, 01:03 AM   #1
topguneagle1
Member#: 115620
2000 Impreza coupe
FALCON 9
Default replacing headgaskets: guess what else i found (need help)
replacing the headgaskets in my ej20k.
i'm taking off the bottom drivers side cam and look what i find....
what in the hell would cause this?
and look! coolant in the headers right after removal....
but seriously, are those heads screwed?
topguneagle1 is offline   Reply With Quote
Old 07-24-2009, 02:44 AM   #2
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
ouch. screwed.
Old 07-24-2009, 03:19 AM   #3
topguneagle1
Member#: 115620
2000 Impreza coupe
FALCON 9
Originally Posted by hybrid gti 2 View Post
ouch. screwed.
the heads and cams are no good right?
Old 07-24-2009, 09:14 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Lack of lubrication or contaminated lubrication. And yes, unfortunately that head is junk.
Old 07-24-2009, 10:15 AM   #5
topguneagle1
Member#: 115620
2000 Impreza coupe
FALCON 9
shoot
Old 07-26-2009, 02:05 AM   #6
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Luckily it is the driver side head. You can use USDM 2.5RS or Outback DOHC head and swap the valves and valvetrain as casting is the same. Not sure if that 20K cam can be salvaged though.
Marnix is offline   Reply With Quote
Old 07-26-2009, 11:49 AM   #7
kheff46
Member#: 66739
2002 WRX wagon
i have a forester with a DOHC(RS/LGT/outback2.5/ETC) that i may be parting out for my K car rebuild. please let me know when you are sure if you need a head or not. i'd like to help out if possible
--keith
kheff46 is offline   Reply With Quote
Old 07-26-2009, 04:21 PM   #8
topguneagle1
Member#: 115620
2000 Impreza coupe
FALCON 9
--keith
will these heads be able to withstand the higher hp?
Old 07-26-2009, 06:12 PM   #9
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
As said, the castings are the same you just have to swap the 20K valves, springs and retainers and re-adjust valve clearances! You can get underbucket shims from Japanpart.com or you could even try if the USDM EZ30 underbucket shims will fit!
Old 07-26-2009, 06:43 PM   #10
route69wrx
Member#: 111046
1996 STiL wagon
2002 MBP bugeye
i have a half set of jdm v4 sti valves, if you need them. i had my heads rebuilt and they found 8 bad valves, i couldnt afford the jdm valves so i put machined supertech valves in instead.
the jdm valves are $94/ea for the intake and $131 for the exhaust from grahamgooderacing or $455/intake and $497/exhaust from japanparts.
route69wrx is offline   Reply With Quote
Old 07-27-2009, 01:29 AM   #11
topguneagle1
Member#: 115620
2000 Impreza coupe
FALCON 9
ok i'll keep you in mind.
btw link to where i can check out the supertech valves
Old 07-28-2009, 06:21 PM   #12
route69wrx
Member#: 111046
1996 STiL wagon
2002 MBP bugeye
Thumbs up
pm subiking here on nasioc, he was the one that dealt with the head shop where my heads were rebuilt, he has all the info would about the vavles that were used. i do know they were supertech stainless steel udsm sti valves that were machined to the proper length for the 20k heads.
i started the engine that those heads are on now for the first time last night and they seem to be good...
Old 07-28-2009, 09:13 PM   #13
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Give Chris at EngineLogics (Houston,TX) a call. I've seen what he did to a Honda head that had a very similar issue - great work. Line bore (if needed) and repair the head. Of course it might be a cheaper if you have a line on a spare K head.
beaviscih is offline   Reply With Quote
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 04:45 PM
Guess what else I just got free? 24 Off-Topic 13 03-05-2008 02:15 PM
After Radiator Replace Car Overheating what else possible??? Please Help wrxspdr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 10-23-2005 09:42 PM
OMG... guess what I just found on my t3h intarweb! chkltcow Off-Topic 3 06-17-2005 06:30 PM
guess what i just found.... SubyObsessive Tri-State Area Forum 6 01-10-2002 04:54 PM
